    Changing pt100 to standard thermistor
    3.1k
    • Atraedesundefined
      Atraedes
      @Atraedes said in Changing pt100 to standard thermistor:
      ; Tool 0
      M307 H1 A1230.8 C312.7 D7.2 S1.00 V26.3 B0
      M305 P1 X200 ; Set PT100 + ADC parameters for heater 1
      great, thanks, so change it here in config :
      ; Tool 0
      So change M305 to the code you said, change M143 to new max temp on new hotend, thanks again for all
      • Atraedesundefined
        Atraedes
        Hi @Phaedrux, thanks again for your help, it worked great, however, after i did the pid tune i tried to save it with M500 but it says "Warning: No M501 command was executed in config.g", ive since done a couple test prints also and it has flagged up "Error: Heating fault on heater 1" a couple of times, im stumped, the wiring is fine and checked, not sure where to go or why it doesnt take the M500 command
        Stephen6309undefined 1 Reply Last reply Reply Quote 0
        • Stephen6309undefined
          Stephen6309 @Atraedes
          @Atraedes You need a M510 at the end of config,g.
          • Atraedesundefined
            Atraedes
            thanks, tried it, it says "Warning: M510 command is not supported"
              https://duet3d.dozuki.com/Wiki/Gcode#Section_M500_Store_parameters
              M500 saves to config-override.g, and M501 loads it. You need to add M501 to the end of config.g to load the saved values at startup.
              • Atraedesundefined
                Atraedes
                the sd card is buried deep in the machine also so i cant easily get to it without taking the bottom of etc.., i just assumed i could do everything via the console?
                  @Atraedes Oops, i ment M501. The keyboard keeps reversing things. 🙂
                  • Atraedesundefined
                    Atraedes
                    thanks again, so i made the changes you advised straight to the config files incl the config in sys folder on the sd card, loaded back into the machine, then ran pid tune, got this - "Auto tune heater 0 completed in 1489 sec
                    Use M307 H0 to see the result, or M500 to save the result in config-override.g", but then when i entered M500 via the console it answered - "M500
                    Warning: No M501 command was executed in config.g". Did i do something wrong?
                    • Atraedesundefined
                      Atraedes
                      i then tried M501, and got this - "M501
                      Warning: Heater 1 appears to be over-powered. If left on at full power, its temperature is predicted to reach 692C.", feels like im back to square one lol, but the whole hotend, cables and all, are new, and confirmed 24v
                      • Vetiundefined
                        Veti @Atraedes
                        add M501 to the end of your config.g
                        • Atraedesundefined
                          Atraedes
                          so remove the SD card from the machine and type M501 at the very end of the config file? Can i not send that via the console?
                          • Vetiundefined
                            Veti @Atraedes
                            @Atraedes
                            just edit the file using the web ui
                            • Atraedesundefined
                              Atraedes
                              sorry i dont know how to do that, im still learning the ropes with the duet3d board i have
                              • Vetiundefined
                                Veti
                                please read
                                https://duet3d.dozuki.com/Wiki/Duet_Web_Control_Manual
                                  Oh wow, I didn't realize you weren't even connected to the web interface yet.
                                  https://duet3d.dozuki.com/Guide/1.)+Getting+Connected+to+your+Duet/7
                                  It definitely makes a world of difference.
                                  • Atraedesundefined
                                    Atraedes
                                    so if i understood correctly, ive gone into system in the web ui, found config.g, opened and typed M501 at the end of the file, and its asking if do i want to reset the board and apply the update? is that correct?
                                    • Atraedesundefined
                                      Atraedes
                                      no sorry, i probably didnt explain, i am using the web ui, all the time,and running these commands via the console in the web ui, but i thought it was a simple M500 via the console in web ui to save it, and it doesnt
                                        Yes you have to edit config.g and add M501 at the end.
                                        As I said, M500 saves SOME settings (like PID tuning or other measured values) to the file config-override.g. And M501 loads that files.
                                        • Atraedesundefined
                                          Atraedes
                                          ok thanks, so to try solve these spurious heating faults, run my pid tune, after it shows results then go into system in the web ui, into config.g, M501 at the end of the file, and reset the board and apply the update?
                                            Phaedrux Moderator @Atraedes
                                            That's not a heater fault. It's a warning.
                                            https://duet3d.dozuki.com/Wiki/FAQ#Section_M307_Heater_1_appears_to_be_over_powered_If_left_on_at_full_power_its_temperature_is_predicted_to_reach_521C
