    Changing pt100 to standard thermistor
    3.1k
    • Atraedesundefined
      Atraedes
      so remove the SD card from the machine and type M501 at the very end of the config file? Can i not send that via the console?
      • Vetiundefined
        Veti @Atraedes
        @Atraedes
        just edit the file using the web ui
        • Atraedesundefined
          Atraedes
          sorry i dont know how to do that, im still learning the ropes with the duet3d board i have
          • Vetiundefined
            Veti
            please read
            https://duet3d.dozuki.com/Wiki/Duet_Web_Control_Manual
              Oh wow, I didn't realize you weren't even connected to the web interface yet.
              https://duet3d.dozuki.com/Guide/1.)+Getting+Connected+to+your+Duet/7
              It definitely makes a world of difference.
              • Atraedesundefined
                Atraedes
                so if i understood correctly, ive gone into system in the web ui, found config.g, opened and typed M501 at the end of the file, and its asking if do i want to reset the board and apply the update? is that correct?
                • Atraedesundefined
                  Atraedes
                  no sorry, i probably didnt explain, i am using the web ui, all the time,and running these commands via the console in the web ui, but i thought it was a simple M500 via the console in web ui to save it, and it doesnt
                    Yes you have to edit config.g and add M501 at the end.
                    As I said, M500 saves SOME settings (like PID tuning or other measured values) to the file config-override.g. And M501 loads that files.
                    https://duet3d.dozuki.com/Wiki/Gcode#Section_M500_Store_parameters
                    • Atraedesundefined
                      Atraedes
                      @Atraedes said in Changing pt100 to standard thermistor:
                      ok thanks, so to try solve these spurious heating faults, run my pid tune, after it shows results then go into system in the web ui, into config.g, M501 at the end of the file, and reset the board and apply the update?
                        Phaedrux Moderator @Atraedes
                        Warning: Heater 1 appears to be over-powered. If left on at full power, its temperature is predicted to reach 692C.",
                        That's not a heater fault. It's a warning.
                        https://duet3d.dozuki.com/Wiki/FAQ#Section_M307_Heater_1_appears_to_be_over_powered_If_left_on_at_full_power_its_temperature_is_predicted_to_reach_521C
                          PID tune, send M500 in console, add M501 to config.g. done.
                          • Atraedesundefined
                            Atraedes
                            awesome thanks, much appreciated
                            • Atraedesundefined
                              Atraedes
                              oh my good lord i am losing my mind...I've done everything, seemed fine, heated up hotend to 200c to do a test cube, and "M501
                              Warning: Heater 1 appears to be over-powered. If left on at full power, its temperature is predicted to reach 612C.", and then "Error: Heating fault on heater 1, temperature excursion exceeded 15.0°C", and it cools down the hotend. I know the first is a warning which i could live with but it then goes into error! Sorry I know i seem like a noob and keep asking questions but i dont get it lol, cables seem fine and ive rechecked everything, do you think there may be another fault elsewhere or is it likely the cables?
                              • Vetiundefined
                                Veti
                                post a picture of the temperature graph.
                                also do you have the silicone sock on?
                                • Atraedesundefined
                                  Atraedes
                                  Yes got a sock on, and thanks for your assistance
                                  • Atraedesundefined
                                    Atraedes
                                    sorry did you want me to rest the hotend and heat again first?
                                    • Atraedesundefined
                                      Atraedes
                                      reset the hotend even
                                      • Vetiundefined
                                        Veti
                                        when the error occured
                                        • Atraedesundefined
                                          Atraedes
                                          it happened when i was heating the hotend to 205c to do a test cube
                                          • Atraedesundefined
                                            Atraedes
                                            I've got it heated to 200c now and for the last 15mins or so and it seems ok, but this is probably the 3rd or so time its had a hotend error since i made the changes earlier today
