    Mini5+ Wi-Fi Cad files
    • carcamerarigundefined
      carcamerarig
      Hi All
      Waiting for my delivery and wanted to mock up a case for a Caribou 3030 T slot frame. I checked in the online specs but says 3D model “to do”, is there a drawing I can use to draw up and model a case?
      Justin.
        The size and placement of the screws is identical to the Maestro, if that helps at all.
          carcamerarig
          @Phaedrux said in Mini5+ Wi-Fi Cad files:
          I have the screw placements already I was hoping there would be a 3d file of the board but that's not ready yet so I wondered if anyone had some 2d drawing to make life a bit easier.
            T3P3Tony administrators
            Here they are!
            Duet3_mini5_Wifi_step.zip
            Duet3_mini5_Ethernet_step.zip
            Luke'sLaboratoryundefined piperswundefined 2 Replies Last reply Reply Quote 2
            • Luke'sLaboratoryundefined
              Luke'sLaboratory @T3P3Tony
              @T3P3Tony Thanks! Very useful 😄
              Luke
              http://lukeslab.online
                also for those coming later, the documentation now contains links:
                https://duet3d.dozuki.com/Wiki/Duet_3_Mini_5plus_Hardware_overview#Section_3D_Model
                • piperswundefined
                  pipersw @T3P3Tony
                  This post is deleted!
