    Servo deployed probe on Duet Maestro
    3.6k
      Now that you have it working give this a shot
      https://duet3d.dozuki.com/Wiki/Test_and_calibrate_the_Z_probe
      Your dive height should be slightly higher than your trigger height.
      • Blacksheep99undefined
        Blacksheep99 @Veti
        @Veti said in Servo deployed probe on Duet Maestro:
        i am using this
        https://www.thingiverse.com/thing:3303618
        and it works on the maestro.
        all the connections are going to the z probe header.
        gnd is combined and 5v is combined in this case.
        So I've ditched my old probe and made one of these today. I've connected it up and it seems to be working as it should. I just can't get my head around what I need to get this to work with my printer. By that I mean bring the bed up, probe deploy and then bed probed.
        I'd appreciate some guidance, just to help my understanding.
        • Vetiundefined
          Veti @Blacksheep99
          @Blacksheep99
          its pretty close to bltouch. just select P8 instead of p9.
          same retract and deploy scripts (might have to adjust the angles slightly)
          although you need to add a M401 if you want to deploy it before and M402 when you want to retract.
          example homeall
          ; homeall.g
          ; called to home all axes
          ; generated by RepRapFirmware Configuration Tool v3.2.0 on Fri Jan 01 2021 18:39:48 GMT+0100 (Central European Standard Time)
          G1 H2 Z5 F6000          ; lift Z relative to current position
          G1 H1 X-240 Y-240 F3000 ; move quickly to X and Y axis endstops and stop there (first pass)
          G1 H2 X5 Y5 F6000       ; go back a few mm
          G1 H1 X-240 Y-240 F240  ; move slowly to X and Y axis endstops once more (second pass)
          G90                     ; absolute positioning
          G1 X10 Y10 F6000        ; go to first bed probe point and home Z
          M401
          G30                     ; home Z by probing the bed
          M402
          ;G91                    ; relative positioning
          ;G1 Z5 F100             ; lift Z relative to current position
          ;G90                    ; absolute positioning
          Blacksheep99undefined 2 Replies Last reply Reply Quote 0
            Blacksheep99 @Veti
            @Veti Thanks, I'll give this a try when I finish work. What about my config.g file? or does this replace what's currently in there?
              Blacksheep99 @Veti
              @Blacksheep99
              example homeall
              ; homeall.g
              M401
              M402
              So taking your example I modified my home all to try this. I changed the X and X to my bed size. Sending just the M401 command deploys the probe fine, the M402 retracts it.
              This is my config.g code.
              M574 Z1 S1 ; Set endstops controlled by probe
              M950 S0 C"^zprobe.mod" ; create servo pin 0 for BLTouch
              M558 P8 C"^!zprobe.in" H2 F900 T6000 ; Set Z probe type to switch and the dive height + speeds
              G31 P50 X50 Y-8 Z2.43 ; Set Z probe trigger value, offset and trigger height
              When I home all the head moves out as expected, the bed starts to raise, probe deploys and the immediately retracts and the z stops.
              My probe in the dashboard shows 0 when retracted and 1000 when deployed. Is the inverted pin causing an issue?
              Phaedruxundefined dc42undefined Vetiundefined 3 Replies Last reply Reply Quote 0
                Blacksheep99
                This is the bed and head setup. Excuse the chaos behind it!
                  Phaedrux Moderator @Blacksheep99
                  @Blacksheep99 said in Servo deployed probe on Duet Maestro:
                  Could be. Your description makes it sound like it assumes that it's triggered as soon as it deploys? Correct?
                    dc42 administrators @Blacksheep99
                    What happens if you don't invert the pin? Does probing work then?
                    • Vetiundefined
                      Veti @Blacksheep99
                      yes it needs to be inverted
                      change to C"^zprobe.in"
                      Blacksheep99undefined Phaedruxundefined 2 Replies Last reply Reply Quote 0
                        Blacksheep99 @Veti
                        Ok, I've changed this. The probe itself is off the bed. Do I need to add a move command for X and Y to move the head over the bed?
                        I current have the mesh compensation commented out in the config.g not sure if that should be active?
                          Blacksheep99
                          Probe now shows 1000 when retracted.
                          To test the probe is working I moved X and Y over the bed and tried to run G30. It doesn't run as it says probe is already deployed.
                            yes.
                            what exactly do you have commented out?
                            Blacksheep99undefined 1 Reply Last reply Reply Quote 0
                              In your homing files you may want to add a M401 at the start to ensure that the probe is retracted and so that the firmware is aware it's retracted.
                              Then try again.
                                Blacksheep99 @Phaedrux
                                @Phaedrux said in Servo deployed probe on Duet Maestro:
                                ;M557 X15:265 Y15:135 S20                        ; define mesh grid
                                  Yes you should uncomment that line out. It tells the firmware where to probe when doing a G29.
                                    Then try again.
                                    Do you mean M402?
                                      @Phaedrux Thanks. Will do
                                        Do you mean M402?
                                        Yes, sorry. Retract the probe.
                                          Do you mean M402?
                                          Thanks, shows I'm paying attention if just a bit! ha
                                            Blacksheep99
                                            So I've got the probe showing '0' when retracted. I position the probe over the bed and run G30. The probe immediately deploys and the bed starts moving towards the print heads.
                                            Following this guide: https://duet3d.dozuki.com/Wiki/Test_and_calibrate_the_Z_probe
                                            I press the Z probe up expecting the bed to stop but it continues leaving me to use emergency stop to kill things. What have I got wrong?
