Servo deployed probe on Duet Maestro
This is the bed and head setup. Excuse the chaos behind it!
@Blacksheep99 said in Servo deployed probe on Duet Maestro:
Is the inverted pin causing an issue?
Could be. Your description makes it sound like it assumes that it's triggered as soon as it deploys? Correct?
My probe in the dashboard shows 0 when retracted and 1000 when deployed. Is the inverted pin causing an issue?
What happens if you don't invert the pin? Does probing work then?
yes it needs to be inverted
change to C"^zprobe.in"
@Veti said in Servo deployed probe on Duet Maestro:
Ok, I've changed this. The probe itself is off the bed. Do I need to add a move command for X and Y to move the head over the bed?
I current have the mesh compensation commented out in the config.g not sure if that should be active?
Probe now shows 1000 when retracted.
To test the probe is working I moved X and Y over the bed and tried to run G30. It doesn't run as it says probe is already deployed.
yes.
what exactly do you have commented out?
In your homing files you may want to add a M401 at the start to ensure that the probe is retracted and so that the firmware is aware it's retracted.
Then try again.
@Phaedrux said in Servo deployed probe on Duet Maestro:
;M557 X15:265 Y15:135 S20 ; define mesh grid
Yes you should uncomment that line out. It tells the firmware where to probe when doing a G29.
Then try again.
Do you mean M402?
@Phaedrux Thanks. Will do
Do you mean M402?
Yes, sorry. Retract the probe.
Do you mean M402?
Thanks, shows I'm paying attention if just a bit! ha
So I've got the probe showing '0' when retracted. I position the probe over the bed and run G30. The probe immediately deploys and the bed starts moving towards the print heads.
Following this guide: https://duet3d.dozuki.com/Wiki/Test_and_calibrate_the_Z_probe
I press the Z probe up expecting the bed to stop but it continues leaving me to use emergency stop to kill things. What have I got wrong?
please share your current probe config and refresh me on your wiring.
@Phaedrux full config.g
The probe is wired as per this.
https://www.thingiverse.com/thing:3303618So 5v to servo and sensor, shared ground, zprobe mod to the servo, probe.in to the sensor
; Configuration file for Duet Maestro (firmware version 3) ; executed by the firmware on start-up ; ; generated by RepRapFirmware Configuration Tool v3.2.1 on Sat Jan 09 2021 18:02:08 GMT+0000 (Greenwich Mean Time) ; General preferences G90 ; send absolute coordinates... M83 ; ...but relative extruder moves M550 P"ST3Di280 Duet" ; set printer name ; Network M552 P0.0.0.0 S1 ; enable network and acquire dynamic address via DHCP M586 P0 S1 ; enable HTTP M586 P1 S0 ; disable FTP M586 P2 S0 ; disable Telnet ; Drives M569 P0 S1 ; physical drive 0 goes forwards M569 P1 S0 ; physical drive 1 goes backwards M569 P2 S0 ; physical drive 2 goes backwards M569 P3 S0 ; physical drive 3 goes backwards M569 P4 S1 ; physical drive 4 goes forwards M584 X0 Y1 Z2 E3:4 ; set drive mapping M350 X16 Y16 Z16 E16:16 I1 ; configure microstepping with interpolation M92 X91.13 Y106.84 Z1235.52 E420.00:420.00 ; set steps per mm M566 X900.00 Y900.00 Z60.00 E120.00:120.00 ; set maximum instantaneous speed changes (mm/min) M203 X6000.00 Y6000.00 Z180.00 E1200.00:1200.00 ; set maximum speeds (mm/min) M201 X500.00 Y500.00 Z20.00 E250.00:250.00 ; set accelerations (mm/s^2) M906 X800 Y800 Z800 E800:800 I30 ; set motor currents (mA) and motor idle factor in per cent M84 S30 ; Set idle timeout ; Axis Limits M208 X0 Y0 Z0 S1 ; set axis minima M208 X280 Y150 Z150 S0 ; set axis maxima ; Endstops M574 X1 S1 P"xstop" ; configure active-high endstop for low end on X via pin xstop M574 Y1 S1 P"ystop" ; configure active-high endstop for low end on Y via pin ystop M574 Z1 S1 P"zstop" ; configure active-high endstop for low end on Z via pin zstop ; Z-Probe M574 Z1 S1 ; Set endstops controlled by probe M950 S0 C"^zprobe.mod" ; create servo pin 0 for BLTouch M558 P8 C"^!zprobe.in" H150 F900 T6000 ; Set Z probe type to switch and the dive height + speeds G31 P50 X-50 Y-8 Z1.5 ;Set Z probe trigger value, offset and trigger height M557 X15:265 Y15:135 S20 ; define mesh grid ; Heaters M308 S0 P"bedtemp" Y"thermistor" T100000 B3950 ; configure sensor 0 as thermistor on pin bedtemp M950 H0 C"bedheat" T0 ; create bed heater output on bedheat and map it to sensor 0 M307 H0 B0 S1.00 ; disable bang-bang mode for the bed heater and set PWM limit M140 H0 ; map heated bed to heater 0 M143 H0 S120 ; set temperature limit for heater 0 to 120C M308 S1 P"e0temp" Y"thermistor" T100000 B3950 ; configure sensor 1 as thermistor on pin e0temp M950 H1 C"e0heat" T1 ; create nozzle heater output on e0heat and map it to sensor 1 M307 H1 B0 S1.00 ; disable bang-bang mode for heater and set PWM limit M143 H1 S280 ; set temperature limit for heater 1 to 280C M308 S2 P"e1temp" Y"thermistor" T100000 B3950 ; configure sensor 2 as thermistor on pin e1temp M950 H2 C"e1heat" T2 ; create nozzle heater output on e1heat and map it to sensor 2 M307 H2 B0 S1.00 ; disable bang-bang mode for heater and set PWM limit M143 H2 S280 ; set temperature limit for heater 2 to 280C ; Fans M950 F0 C"fan0" Q500 ; create fan 0 on pin fan0 and set its frequency M106 P0 S0 H-1 ; set fan 0 value. Thermostatic control is turned off M950 F1 C"fan1" Q500 ; create fan 1 on pin fan1 and set its frequency M106 P1 S1 H1:2 T45 ; set fan 1 value. Thermostatic control is turned on ; Tools M563 P0 S"Right" D0 H1 F0 ; define tool 0 G10 P0 X0 Y0 Z0 ; set tool 0 axis offsets G10 P0 R0 S0 ; set initial tool 0 active and standby temperatures to 0C M563 P1 S"Left" D1 H2 F0 ; define tool 1 G10 P1 X0 Y0 Z0 ; set tool 1 axis offsets G10 P1 R0 S0 ; set initial tool 1 active and standby temperatures to 0C ; Custom settings are not defined M501 M911 S21 R23 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000" ; set voltage thresholds and actions to run on power loss
Veti suggested that, but you still have
C"^!zprobe.in"
C"^!zprobe.in"
I tried it but when i then test G30 it fails immediately and tells me the probe is already triggered. Is this in relation to the G31 P500?
As I'm not familiar with this probe we might have to wait for Veti to weigh in as I'm not sure why it would be always detecting as triggered or never detecting as triggered.
