Servo deployed probe on Duet Maestro
3.6k
    Blacksheep99 @Phaedrux
    @Phaedrux said in Servo deployed probe on Duet Maestro:
    @Blacksheep99 said in Servo deployed probe on Duet Maestro:
    it says probe is already deployed.
    In your homing files you may want to add a M401 at the start to ensure that the probe is retracted and so that the firmware is aware it's retracted.
    Then try again.
    Do you mean M402?
    undefined 1 Reply Last reply 13 Jan 2021, 18:36 Reply Quote 0
      @Phaedrux Thanks. Will do
        Phaedrux Moderator @Blacksheep99
        Do you mean M402?
        Yes, sorry. Retract the probe.
        undefined 1 Reply Last reply 13 Jan 2021, 18:37 Reply Quote 0
          Do you mean M402?
          Thanks, shows I'm paying attention if just a bit! ha
            Blacksheep99
            So I've got the probe showing '0' when retracted. I position the probe over the bed and run G30. The probe immediately deploys and the bed starts moving towards the print heads.
            Following this guide: https://duet3d.dozuki.com/Wiki/Test_and_calibrate_the_Z_probe
            I press the Z probe up expecting the bed to stop but it continues leaving me to use emergency stop to kill things. What have I got wrong?
              please share your current probe config and refresh me on your wiring.
              undefined 1 Reply Last reply 13 Jan 2021, 19:17 Reply Quote 0
                @Phaedrux full config.g
                The probe is wired as per this.
                https://www.thingiverse.com/thing:3303618
                So 5v to servo and sensor, shared ground, zprobe mod to the servo, probe.in to the sensor
                ; Configuration file for Duet Maestro (firmware version 3)
                ; generated by RepRapFirmware Configuration Tool v3.2.1 on Sat Jan 09 2021 18:02:08 GMT+0000 (Greenwich Mean Time)
                M550 P"ST3Di280 Duet" ; set printer name
                M586 P0 S1 ; enable HTTP
                M586 P1 S0 ; disable FTP
                M586 P2 S0 ; disable Telnet
                M569 P2 S0 ; physical drive 2 goes backwards
                M569 P4 S1 ; physical drive 4 goes forwards
                M584 X0 Y1 Z2 E3:4 ; set drive mapping
                M92 X91.13 Y106.84 Z1235.52 E420.00:420.00 ; set steps per mm
                M566 X900.00 Y900.00 Z60.00 E120.00:120.00 ; set maximum instantaneous speed changes (mm/min)
                M203 X6000.00 Y6000.00 Z180.00 E1200.00:1200.00 ; set maximum speeds (mm/min)
                M201 X500.00 Y500.00 Z20.00 E250.00:250.00 ; set accelerations (mm/s^2)
                M906 X800 Y800 Z800 E800:800 I30 ; set motor currents (mA) and motor idle factor in per cent
                M84 S30 ; Set idle timeout
                M208 X280 Y150 Z150 S0 ; set axis maxima
                M574 Z1 S1 P"zstop" ; configure active-high endstop for low end on Z via pin zstop
                M574 Z1 S1 ; Set endstops controlled by probe
                M950 S0 C"^zprobe.mod" ; create servo pin 0 for BLTouch
                M558 P8 C"^!zprobe.in" H150 F900 T6000 ; Set Z probe type to switch and the dive height + speeds
                G31 P50 X-50 Y-8 Z1.5 ;Set Z probe trigger value, offset and trigger height
                M557 X15:265 Y15:135 S20 ; define mesh grid
                M308 S0 P"bedtemp" Y"thermistor" T100000 B3950 ; configure sensor 0 as thermistor on pin bedtemp
                M308 S1 P"e0temp" Y"thermistor" T100000 B3950 ; configure sensor 1 as thermistor on pin e0temp
                M308 S2 P"e1temp" Y"thermistor" T100000 B3950 ; configure sensor 2 as thermistor on pin e1temp
                M950 H2 C"e1heat" T2 ; create nozzle heater output on e1heat and map it to sensor 2
                M307 H2 B0 S1.00 ; disable bang-bang mode for heater and set PWM limit
                M143 H2 S280 ; set temperature limit for heater 2 to 280C
                M106 P1 S1 H1:2 T45 ; set fan 1 value. Thermostatic control is turned on
                M563 P0 S"Right" D0 H1 F0 ; define tool 0
                M563 P1 S"Left" D1 H2 F0 ; define tool 1
                M501
                M911 S21 R23 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000" ; set voltage thresholds and actions to run on power loss
                  Phaedrux Moderator @Veti
                  @Veti said in Servo deployed probe on Duet Maestro:
                  change to C"^zprobe.in"
                  Veti suggested that, but you still have
                  C"^!zprobe.in"
                  undefined 1 Reply Last reply 13 Jan 2021, 19:32 Reply Quote 0
                    C"^!zprobe.in"
                    I tried it but when i then test G30 it fails immediately and tells me the probe is already triggered. Is this in relation to the G31 P500?
                      As I'm not familiar with this probe we might have to wait for Veti to weigh in as I'm not sure why it would be always detecting as triggered or never detecting as triggered.
                      undefined 1 Reply Last reply 13 Jan 2021, 19:37 Reply Quote 0
                        @Phaedrux Can I just ask clarification on two things. H for Dive height. I have this set to 150 which is the height of the build volume. My reasoning is that the Z needs to raise 150 to meet the print heads but should stop when it triggers the probe?
                        Trigger height, is this the height of the probe above the nozzles when contact is made?
                        Thanks for helping, i really appreciate it
                        FYI. Retracted is 1000 (red box), deployed is 0 (grey background)
                        undefined 2 Replies Last reply 13 Jan 2021, 19:39 Reply Quote 0
                          That's pretty excessive for dive height. As I mentioned before, the dive height should be just slightly more than your trigger height. So if your probe triggers when the nozzle is 3mm above the bed G31 Z3), you'd want you dive height to be at least 4mm for example (M558 H4).
                            I'm not familiar enough with the probe to say if that is normal or not. I would have guessed that it should stay as untriggered regardless of deploy or retract status and only shown triggered when actually pushed up to break the optical beam.
                            undefined 1 Reply Last reply 13 Jan 2021, 19:44 Reply Quote 0
                              That logic makes sense. The way it looks to operate is that when retracted it is breaking the end stop beam (essentially triggered) but one deployed it is not and hence the state changes. One the probe is touched it causes the flag to break the beam and state changes to triggered.
                                Blacksheep99
                                When I home X,Y,Z are all 0,0,0 on the dashboard. Setting a low dive height only moves the bed up that height when I run G30. I should be aiming for the tip of the nozzles to be 0 for Z surely? Would this explain the issue?
                                  The triggered status really only matters when doing the G30. So perhaps your probe isn't getting deployed early enough? When exactly are you getting the probe is triggered at start of probing move error?
                                  What do you have in your homeall now? Remember that you are in control of the deploy and retract state now, which is a bit different than the BLTouch which automates that.
                                  For homing and dive height you can also in control of how the print head is positioned before probing. If you need to raise the Z axis a bit to ensure that the probe has room you can do that in your homeall. It's already common to raise it a bit for clearance for X Y to home. Normally you'd only want to raise it just slightly more than the dive height to ensure there is clearance for the pin to drop.
                                    Veti
                                    look at the homeall script i posted
                                    you need to run a M401 before the G30 and run a M402 afterwards.
                                    the probe is always triggerd in the retracted state. this is a good thing because if you forget to deploy or there is a problem it does not cause damage as it is triggered immediately
                                    undefined 1 Reply Last reply 13 Jan 2021, 20:36 Reply Quote 1
                                      Blacksheep99 @Veti
                                      So sorry to clarify things but I'm changing a few things.
                                      I've done as you originally said and removed the inverted pin in the config.g for zprobe it now reports 1000 (red).
                                      M558 P8 C"^zprobe.in" H150 F900 T6000 ; Set Z probe type to switch and the dive height + speeds
                                      My home all
                                      G91 ; relative positioning
                                      G1 H1 X-285 Y-155 F1800 ; move quickly to X and Y axis endstops and stop there (first pass)
                                      G1 H2 X5 Y5 F6000 ; go back a few mm
                                      G1 H1 X-285 Y-155 F360 ; move slowly to X and Y axis endstops once more (second pass)
                                      G1 H1 Z-155 F360 ; move Z down stopping at the endstop
                                      G90 ; absolute positioning
                                      M402
                                      G92 Z0 ; set Z position to axis minimum (you may want to adjust this)
                                      When you say run M401 then G30 are you talking via the console to test its function? I just tried that and it reversed the bed down hitting the end stop and kept trying to go, I had to hit stop.
                                      undefined 1 Reply Last reply 13 Jan 2021, 20:41 Reply Quote 0
                                        Your homeall isn't using the probe at all at this point, still just the endstop. Trying to control the probing manually isn't going to work very well. Better to script it out in the homing file at this point.
                                        If you want to continue to use the Z endstop, that's fine. Here's what I would add.
                                        M402 ; retract the pin just incase
                                        G1 X105 Y150 Z5 F6000 ; move probe into position at bed center
                                        M401 ; deploy the probe
                                        G30 ; probe the bed
                                        M402 ; retract probe
                                        G1 X10 Y10 Z10 ; return to parked position
                                        undefined undefined 2 Replies Last reply 13 Jan 2021, 20:49 Reply Quote 0
                                          G30 ; probe the bed
                                          I feel stupid as the logic doesn't fit with my understanding. Home for the bed should be as far away from the nozzle as possible to my mind?
                                          I've just tried your homeall and I get the probe already triggered message.
                                          G28
                                          Error: Z probe already triggered at start of probing move
                                          Why do I need the G30 at all in the homeall? It's homeall just to park the head and bed out of the way?
                                          When I run a print that's when the printer should probe the bed shouldn't it? I thought this was G29 though.
                                          49 out of 86
