Problem with rear side of Test Cube
Thanks Fredrick, I am using ABS.
No worries @alankilian here it is:
[0_1610836772941_xyzCalibration_cube.factory](Uploading 100%) -
@dmbgo Try that upload again please.
Also, what filament are you using?
I print PLA at 60C bed and 205C extruder, so you're significantly hotter than I am.
I'll try renaming it to *.txt, you'll have to change it to *.factory:
xyzCalibration_cube.factory.txt -
I am using ABS filament.
On the filament roll, it recommends Extruder 220 to 260C Bed 100 to 110C
@dmbgo said in Problem with rear side of Test Cube:
Do you have a heated enclosure?
I'm afraid I'm out of my experience zone with ABS.
I have read not to use fans for the first 3 layers, but that's not your problem.
Do you see filament extruding on the back cornets?
Do you hear your extruder struggling/clicking when that happens?
Can you rotate the cube 180-degrees to see if it then happens on the front?
Can you rotate the entire printer 180-degrees to see if it changes due to airflow?
Do you have an enclosure?
My only ABS experience is using a Stratasys where everything is controlled for me and it works perfectly.
Someone with more ABS experience will probably jump in next and hopefully be able to help you more than I can.
I do have, but the printer isn't in it at present while I'm working on it. I usually drop the bed temp down when the printer's in there.
From what I have read ABS really needs a heated enclosure BUT I don't know if that is related to your problem.
@alankilian said in Problem with rear side of Test Cube:
1/ Do you see filament extruding on the back cornets?
2/ Do you hear your extruder struggling/clicking when that happens?
3/ Can you rotate the cube 180-degrees to see if it then happens on the front?
4/Can you rotate the entire printer 180-degrees to see if it changes due to airflow?
5/Do you have an enclosure?1/ Back cornets?
2/No clicking, extruding nicely when I move it up and extrude some filament.
3/I should have mentioned that I had done that, it still happens on the rear (mainly)
4/The pinter is on a wheeled trolley, I have tried that. Ambient temp is 18.4C atm. -
"From what I have read ABS really needs a heated enclosure BUT I don't know if that is related to your problem. Frederick"
Yes, I found that out a while ago, which is why I made the one in the pic. It is made from 50mm expanded foam, coated with thin fiberglass panels. The material came from an old coolroom.
But the issue remains. Any other helpful suggestions, they've been good so far?
Instead of printing a cube can you create a model of a disc, say, 50 mm in diameter and 5 mm thick?
If you can print it using you normal settings.
Here's a pic of the printer:
Sorry Fredrick, but my modelling capability is V low. Could you please suggest a model from thingiverse or somewhere?
Here you go.
Slice it normally but keep the layer cooling fan(s) off.
Thanks Fredrick
