    Problem with rear side of Test Cube
    2.4k
    • dmbgoundefined
      dmbgo
      On the filament roll, it recommends Extruder 220 to 260C Bed 100 to 110C
      Regards David Maher
      • dmbgoundefined
        dmbgo
        Regards David Maher
        • fcwiltundefined
          fcwilt @dmbgo
          @dmbgo said in Problem with rear side of Test Cube:
          I am using ABS filament.
          Do you have a heated enclosure?
          • alankilianundefined
            alankilian
            I'm afraid I'm out of my experience zone with ABS.
            I have read not to use fans for the first 3 layers, but that's not your problem.
            Do you see filament extruding on the back cornets?
            Do you hear your extruder struggling/clicking when that happens?
            Can you rotate the cube 180-degrees to see if it then happens on the front?
            Can you rotate the entire printer 180-degrees to see if it changes due to airflow?
            Do you have an enclosure?
            My only ABS experience is using a Stratasys where everything is controlled for me and it works perfectly.
            Someone with more ABS experience will probably jump in next and hopefully be able to help you more than I can.
            • dmbgoundefined
              dmbgo
              I do have, but the printer isn't in it at present while I'm working on it. I usually drop the bed temp down when the printer's in there.
              Regards David Maher
              • fcwiltundefined
                fcwilt
                From what I have read ABS really needs a heated enclosure BUT I don't know if that is related to your problem.
                • dmbgoundefined
                  dmbgo
                  @alankilian said in Problem with rear side of Test Cube:
                  1/ Do you see filament extruding on the back cornets?
                  2/ Do you hear your extruder struggling/clicking when that happens?
                  3/ Can you rotate the cube 180-degrees to see if it then happens on the front?
                  4/Can you rotate the entire printer 180-degrees to see if it changes due to airflow?
                  5/Do you have an enclosure?
                  1/ Back cornets?
                  2/No clicking, extruding nicely when I move it up and extrude some filament.
                  3/I should have mentioned that I had done that, it still happens on the rear (mainly)
                  4/The pinter is on a wheeled trolley, I have tried that. Ambient temp is 18.4C atm.
                  Regards David Maher
                  • dmbgoundefined
                    dmbgo
                    "From what I have read ABS really needs a heated enclosure BUT I don't know if that is related to your problem. Frederick"
                    Yes, I found that out a while ago, which is why I made the one in the pic. It is made from 50mm expanded foam, coated with thin fiberglass panels. The material came from an old coolroom.
                    Regards David Maher
                    • dmbgoundefined
                      dmbgo
                      But the issue remains. Any other helpful suggestions, they've been good so far?
                      Regards David Maher
                      • fcwiltundefined
                        fcwilt @dmbgo
                        Instead of printing a cube can you create a model of a disc, say, 50 mm in diameter and 5 mm thick?
                        If you can print it using you normal settings.
                        • dmbgoundefined
                          dmbgo
                          Here's a pic of the printer:
                          Regards David Maher
                          • dmbgoundefined
                            dmbgo
                            Sorry Fredrick, but my modelling capability is V low. Could you please suggest a model from thingiverse or somewhere?
                            Regards David Maher
                            • fcwiltundefined
                              fcwilt @dmbgo
                              Here you go.
                              Slice it normally but keep the layer cooling fan(s) off.
                              Disc 050 x 005.stl
                              • dmbgoundefined
                                dmbgo
                                Thanks Fredrick
                                Regards David Maher
                                • dmbgoundefined
                                  dmbgo
                                  Thanks Fredrick
                                  Printing now
                                  Regards David Maher
                                  • fcwiltundefined
                                    fcwilt @dmbgo
                                    Printing now
                                    I will check back in a bit.
                                    • dmbgoundefined
                                      dmbgo
                                      Where are you Fredrick? If it is too late at night, we can leave it until tomorrow.
                                      Regards David Maher
                                      • fcwiltundefined
                                        fcwilt @dmbgo
                                        @dmbgo I'm here.
                                        • dmbgoundefined
                                          dmbgo
                                          The disk is printing at 30 mm/s. It will probably take about 20mins more.
                                          Regards David Maher
                                          • fcwiltundefined
                                            fcwilt @dmbgo
                                            What does it look like so far?
