Problem with rear side of Test Cube
@dmbgo said in Problem with rear side of Test Cube:
But the issue remains. Any other helpful suggestions, they've been good so far?
Instead of printing a cube can you create a model of a disc, say, 50 mm in diameter and 5 mm thick?
If you can print it using you normal settings.
Sorry Fredrick, but my modelling capability is V low. Could you please suggest a model from thingiverse or somewhere?
Here you go.
Slice it normally but keep the layer cooling fan(s) off.
Thanks Fredrick
Printing now
I will check back in a bit.
Where are you Fredrick? If it is too late at night, we can leave it until tomorrow.
@dmbgo I'm here.
The disk is printing at 30 mm/s. It will probably take about 20mins more.
What does it look like so far?
OK.
I'll check back in 15 mins.
The bed levelling is a bit out now, but I dont think it will affect the disc
Just covering the top now.
is your bed level? looks like the nozzle is closer on one side of the print than the other. a bad first layer can make trouble for the rest of the print in abs, especially if you are printing small items with short layer times. I would try leveling the bed so the first layer looks perfect and printing 2 test cubes instead of one to give each layer enough time to cool off before the next layer hits. I forgot to ask how ridged is your carriage? is there any play or slop in any direction?
Fredrick, it has printed.
I think you may just be seeing ABS shrinkage.
You do have a bed adhesion issue on one section and I imagine you can see that.
If you have some PLA perhaps print the same object and see what you get.
Have you got any PETG you could try? It's a good alternative to ABS and it doesn't have the kind of shrinkage issue that ABS has.
