    Invitation to share your conditional GCode scripts
    Gcode meta commands
    14
    23
    4.8k
      We're looking for interesting ways to use the conditional GCode facility of RRF 3.01, both to look for possible enhancements to this feature and to highlight its benefits. So, if you are using conditional GCode on your printer, please share those scripts here if you are willing.
      If you are using RRF 3.01beta but you haven't yet used conditional GCode, here are a few application ideas to get you going:
      • Leadscrew bed levelling or delta printer calibration until deviation is below a certain amount
      • Homing the printer in certain contexts if and only if it hasn't been homed already
      • Taking some action (e.g. extruding) only if the extruder is hot enough
      • Repeated probing with the probe points approached from different directions, to detect backlash in the mechanics (especially useful for delta printers)
      • Adjusting the behaviour of the pause.g and resume.g file depending on whether a tool is selected, and which one
      • Doing different things depending on whether a switch is closed or not at the time
      • Lifting the head a few mm depending on whether or not the Z axis is already close to maximum
      • Changing the coordinates that pause.g moves to depending on the existing XYZ coordinates
      Please provide your own application ideas too!
      Post your examples and ideas as their own thread in the GCode Meta Commands sub-forum.
      Relevant documentation:
      https://duet3d.dozuki.com/Wiki/RepRapFirmware_3_overview
      https://duet3d.dozuki.com/Wiki/GCode_Meta_Commands
      https://duet3d.dozuki.com/Wiki/Object_Model_of_RepRapFirmware
      https://duet3d.dozuki.com/Wiki/Gcode#Section_M409_Query_object_model
      EducatingSavvasundefined 1 Reply Last reply Reply Quote 5
      • chas2706undefined
        chas2706
        @dc42 Is there a time frame when the DSF will be updated so us Duet3 + SBC users can take advantage?
        • deckingmanundefined
          deckingman
          I'm rather hoping that one or more of the clever people on these forums will come up with a simplified user guide for those of us who are academically challenged, when it comes to understanding such things as what an object model is. A simple list of the values that I can use would be great.
          Right now I'm recovering from surgery so am even more challenged than normal. Two things that I'd like to do but that I haven't yet looked at would be firstly to set the operation and standby temperatures for tools but only if they exist. Currently I have several configuration files for different multi-input hot ends with different numbers of tools defined. I use pre and post print macros which are called from my slicer start and end gcode but if I pick the wrong macro, it could attempt to set the temperature for a non-existent tool and throw an error. So a simple loop for say 20 tools containing "if tool n exists, set it's active and standby temperatures to xxx, yyy" else skip" would be great. Is this doable? Even better would be to have "and if filamentType = pla, set temps to xxx else if filament = PET-G set temps to yyy etc". But I've no idea if this is doable.
          Another use would be to run a purge macro on tool change but only if a certain tool hasn't been used for nnn amount of time. The usage case is that PLA will hydrolyse when held at print temperature for an extended period of time. So when using a mixing hot end, it can be be necessary to purge an unused but heated filament depending on how long it has been unused for. If the filament was last used say 20 minutes ago or less, then the purge is unnecessary and wasteful in time as well as filament. Again, no idea if this is possible.
          • chas2706undefined
            chas2706
            I would use this in my start.g and some other macro's to check if machine has been homed:
            M291P"Checking for homed axis!" T3
            if !move.axes[0].homed || !move.axes[1].homed || !move.axes[2].homed
            G28
            // rest of start code
            and this for my leadscrew levelling:
            ; If the printer hasn't been homed, home it
            G28
            while true
            if iterations = 5
            abort "Too many auto calibration attempts"
            G30 P0 X10 Y63 Z-99999 ; probe near a leadscrew
            if result != 0
            continue
            G30 P1 X290 Y63 Z-99999 ; probe near a leadscrew
            if result != 0
            continue
            G30 P2 X150 Y290 Z-99999 S3 ; probe near a leadscrew and calibrate 3 motors
            echo result
            if result != 0
            continue
            if move.calibrationDeviation.deviation <= 0.03
            break
            echo "Repeating calibration, Deviation is " ^ move.calibrationDeviation.deviation ^ "mm"
            echo "Auto calibration successful. Deviation = " ^ move.calibrationDeviation.deviation ^ "mm"
            G28 Z ; re-home z axis in case it has shifted
            But I can't use either because they don't work with Duet3 + SBC!
            • SpoonUnitundefined
              SpoonUnit
              I'm using the following in pause.g
              ; eject
              if state.currentTool=3
              	M98 P"eject-hemera.g"
              else
              	M98 P"eject.g"
              and correspondingly in resume.g
              ;prime nozzle
              	M98 P"prime-hemera.g"
              else
              	M98 P"prime.g"
              I'd really like to be able to only run G29 if that last G29 was run some length of time ago. At present, it runs every print, but could be handy to only run it if that last homing process ran over an hour ago (or some configurable time period).
              • OwenDundefined
                OwenD
                Perhaps a forum section dedicated to this might be in order?
                This is my stop.g which uses several of the examples listed.
                Essentially the only thing in my slicer end code is M0 to call stop.g
                Some of the popups aren't necessary, but provide feedback.
                ; stop.g
                ; called when M0 (Stop) is run (e.g. when a print from SD card is cancelled)
                ; generated by RepRapFirmware Configuration Tool v2.1.4 on Sat Jan 04 2020 09:46:45 GMT+1000 (Australian Eastern Standard Time)
                if {state.currentTool!=-1} ; check if any tools are active
                	G91 ; relative positioning
                ;check if any tools have heaters which are above cold extrude value
                	if #tools[state.currentTool].heaters > 0 & heat.heaters[tools[state.currentTool].heaters[0]].current > heat.coldRetractTemperature
                		G1 E-2 F300 ; retract the filament a bit before lifting the nozzle to release some of the pressure
                		M291 P"Retracted 2mm" R"Retracting" S0 T5
                		G4 S5 ; wait for popup
                	else
                		M291 P{"Not retracted...  Heater off or below extrude temp  " ^ heat.heaters[1].current ^ " : " ^ heat.coldRetractTemperature ^ "."} R"Retract" S0 T5
                else
                	M291 P"No active tool" R"Check tools" S0 T2
                if {!move.axes[0].homed || !move.axes[1].homed || !move.axes[2].homed} ; check if the machine is homed
                	M291 P"Insufficient axis homed.  Cannot raise or park" R"Parking" S0 T5
                else
                	G90 ; absolute positioning
                	if {(move.axes[2].machinePosition) < (move.axes[2].max - 10)} ; check if there's sufficient space to raise head
                		M291 P{"Raising head to...  " ^ move.axes[2].machinePosition+5}  R"Raising head" S0 T5
                		G1 Z+5 F9000 ; move Z up a bit
                	else
                		M291 P{"Cannot raise head- insufficient space  " ^ move.axes[2].machinePosition ^ " : " ^ (move.axes[2].max - 10) ^ "."} R"Raising head" S0 T5
                		G4 S5 ; wait for popup to display
                	G1 X10 Y150 ; parks X head pushes bed out to front so you can pull part
                	M400 ; wait for current moves to finish
                	G10 S0 R0 ; Set active and standby temps to zero
                	T-1 P0 ; if any tools selected, deselect all
                else
                	T0 ; Select a tool
                	G10 S0 R0 ; Set active and standby temps to zero to ensure nothing is on standby
                	T-1 P0; deselect all tools
                M140 S0 ; heated bed heater off
                M106 P0 S0 ; part fan off
                M84 ; steppers off
                M98 P"0:/macros/songs/itchyscratchy.g" ; play finish tune
                • OwenDundefined
                  OwenD
                  Is there any documentation being prepared that explains the intent of the various object model items and when they would return a value?
                  The closest I've found is the machine section of the API, but there's a lot of info in there that most don't need.
                  For example when working with probe deviation, at what point should we use move.calibration.initial.deviation vs move.calibration.final.deviation?
                    We plan to document the object model when it has settled down, after the RRF 3.01 release.
                    move.calibration.initialDeviation is the deviation reported by probing. finalDeviation is the expected deviation after the firmware had made the corrections. Both are set to zero if no auto calibration/true bed levelling has been done
                    • EducatingSavvasundefined
                      EducatingSavvas @dc42
                      Hi, I've had a couple ideas which I think might only be achieved with conditional g-code.
                      • Save waste-board location along z axis to be used when setting work-coordinate Z0 location during known stationary probe. This would be a useful for CNC router machines.
                      • Work out vector angle from x and y axis coordinates to control 5th axis motor. This could be toggled on/off in the web interface, and useful in implementing a tangential knife cutter or large scale concrete extrusion.
                      • Using switch state to control warning light system on 3D printer or CNC machine. Un-homed could be yellow, cutting or extruding will show red, and idle could be a white light.
                      • Safety enclosure door behaviour during different machine states. More specific for CNC but if cutting, pause job and display message 'enclosure has been opened,' if not cutting ignore switch state.
                      I'm not sure what is possible yet as I've only just updated to RRF3.01 RC6 but these are the type of behaviours I am interested in. Cheers.
                      • OwenDundefined
                        OwenD
                        I did this one for calibrating the trigger height on a BL Touch
                        I tried a bunch of ways to store a fake variable, but nothing was easy enough to make this useful for a newbie, so for now you have to average the results.
                        I'm not 100% sure homing first is the best way on a brand new machine, but it can be commented out or made conditional with another M291.
                        ;Calibrate BL Touch trigger height
                        ; When we get variables we can define one here
                        ; Uncomment when ready to use
                        ; var RunningTotal=0
                        ; var average=0
                          G28
                        M564 S0 H0 ; Allow movement beyond limits
                        if move.axes[2].machinePosition < 6 ; make sure we have probe clearance
                        	G1 Z6
                        M280 P0 S160 I1 ; reset BL Touch
                        G4 S0.5
                        M98 P"0:/sys/retractprobe.g" ; Ensure probe is retracted & reset
                        G4 S0.5
                        M290 R0 S0 ; clear any baby stepping
                        ; Jog head to position
                        M291 P"Jog nozzle to touch bed" R"Set nozzle to zero" S3 Z1
                        G92 Z0
                        M291 P"Press OK to begin" R"Ready?" S3;
                        ; carry out 10 probes
                        while iterations <= 9
                        	G1 Z6
                        	M400
                        	if sensors.probes[0].value[0]=1000 ; if probe is in error state
                        		echo "Probe in error state- resetting"
                        		G4 S0.5
                        		G4 S0.5
                        	G30 S-1
                        	M400
                        	; Uncomment when variables allowed
                        	; RunningTotal=RunningTotal + move.axes[2].machinePosition
                        	;average=RunningTotal/(iterations+1)
                        	G4 S0.5
                        ; Until variables come use this
                        M291 P"Check console for results and enter average value in G31 Z parameter of config.g"  R"Finished" S3
                        ;When variables come uncomment this
                        ;G31 Z{average}
                        ;M291 P"Trigger height set to : " ^ sensors.probes[0].triggerHeight ^ " Press OK to save to config, cancel to use until restart" R"Finished" S2
                        ;M500
                        M564 S0 H1 ; Reset limits
                        PaulHewundefined 1 Reply Last reply Reply Quote 1
                        • mwwhitedundefined
                          mwwhited
                          I was looking for a Thermostatic Fan trigger and was pointed to a post about daemon.g. Based RRF3.1-RC9 + SBC I now have my fan control for my power tied in.
                          This conditional logic is really powerful.. thanks for all the hard work.
                          daemon.g
                          M98 P"0:/macros/Special Scripts/Check Power Supply"
                          G4 S10 ; wait 10 seconds
                          if fans[3].actualValue > 0.0 && sensors.analog[3].lastReading < 25
                              ;echo "fan running and temp less than 25c... stop fan"
                              M106 P3 S0.0
                          elif fans[3].actualValue < 0.5 && sensors.analog[3].lastReading > 35
                              ;echo "fan stopped and temp greater than 35c... start fan"
                              M106 P3 S1.0
                          • OwenDundefined
                            OwenD
                            Another example using daemon.g
                            I'm in the process of adding some extra safety checks.
                            This will check the heater temps when idle and initiate action such as shutting off all power, activating an alarm (probably requires a latching relay)
                            As RRF checks this when printing there's no need to run this section of the code unless idle.
                            ; daemon.g
                            ; check temps every 10 seconds when not printing (i.e. Idle) and shut down if exceed max temps.  RRF checks when printing, but not when idle.
                            ; not all commands are required.  e.g. shutting off power by dropping a relay negates need for M112, M81 - un-comment or adjust as required for your configuration
                            ; assumes that the thermistor for each heater is monitor # zero as there is no way to do nested loops using "iterations" as identifier in both loops until variables are available in the object model
                            ; no checking done for null values! -
                            if state.status="idle"
                            	while iterations < #heat.heaters ;
                            		;if heat.heaters[iterations].current > heat.heaters[iterations].monitors[0].limit ; un-comment when ready to go live
                            		if heat.heaters[iterations].current > 50 ; uncomment for testing, comment out when going live
                            			M291 P"Heater over max temp" R"Temp Error!" S1 T0 ; Display message for testing
                            			;M112 ; Do emergency stop
                            			;M81  ; Turn PS_ON (ATX) off
                            			;M42 P5 S1 ; Set GPIO 5 (output) high to activate alarm relay. GPIO pin must be configured using M950
                            			;M42 P6 S0 ; Set GPIO 6 (output) low to cut power. GPIO pin must be configured using M950
                            ;if sensors.gpIn[6].value=1 ; check state of connected smoke detector - GPIO pin must be configured using M950
                            	;M291 P"Smoke detector active!" R"I'm on fire!" S1 T0 ; Display Nikki Lauder message for testing
                            G4 S10 ; wait 10 seconds before next check	(adjust S parameter as you see fit)
                            • PaulHewundefined
                              PaulHew @OwenD
                              @OwenD Please can I make a suggestion, at the beginning, issue a
                              M290 R0 S0
                              to reset baby stepping before you try to start performing jogging Z and trigger heights.
                              Just this minute made that mistake!
                              Paul
                              RailCore II - Duet Mini + 1LC, Voron V0.1 - Duet Mini
                              Voron 2.4 disassembled..... Waiting for the RailCore Mini....
                              OwenDundefined 1 Reply Last reply Reply Quote 0
                              • OwenDundefined
                                OwenD @PaulHew
                                @PaulHew said in Invitation to share your conditional GCode scripts:
                                M290 R0 S0
                                Paul
                                Good idea!
                                So let it be written...
                                • OwenDundefined
                                  OwenD
                                  Code to check if all axes are homed and optionally home them, or cancel macro.
                                  It iterates across ALL axes making it more portable code (for those with >3 axis)
                                  This saves manually listing them in an if || (or) statement such as
                                  I imagine this would be useful for tool changing printers where you might be doing something that may or may not require homing.
                                  For the rest of us, I'd just run G28 if any are not homed.
                                  ;first check if any axes are not homed and optionally home them
                                  while iterations < #move.axes
                                  	if !move.axes[iterations].homed ; check if each axis is homed
                                  		M291 P{"Axis " ^ move.axes[iterations].letter ^ " is not homed.  Home now?"} R"Axis un-homed" S3 ; continue or abort?
                                  		M98 P{"0:/sys/home" ^ (move.axes[iterations].letter) ^ ".g"} ; home axis if answer is OK - G28 doesn't accept object variable so run macro
                                  ; rest of code here
                                  • fškundefined
                                    fšk
                                    Here is what I use to choose machine type at startup depending on what tool is connected.
                                    I include a resistor connected to the sensor pin inside the tool connector. This gives a fixed temperature reading and lets the machine choose its type depending on what is connected at startup.
                                    M308 S23 P"e2temp" Y"thermistor" T100000 B3950 A"ModeSelector"   ;setup a thermistor input as config selection sensor
                                    ;wait for the sensor to start returning meaningful values (don't know if there is a better approach for this)
                                    while sensors.analog[23].lastReading==0||sensors.analog[23].lastReading==2000
                                      echo
                                    ;print the value detected (useful when adding a new mode)
                                    ;M117 ModeSelector value:{sensors.analog[23].lastReading}
                                    ;depending on sensor reading choose a system folder
                                    if sensors.analog[23].lastReading==-273.1
                                      M117 No Attachment Detected.
                                    elif sensors.analog[23].lastReading<155
                                      M117 Going to be a CNC.
                                      M505 P"CNC"
                                    else
                                      M117 Going to be a 3D printer.
                                      M505 P"Printer"
                                    ;load config.g from the chosen system folder
                                    M98 P"config.g"
                                    • mwwhitedundefined
                                      mwwhited
                                      That’s pretty cool. I’m considering my using a serial line with some tiny85 chips that I have laying around to do the same thing. For now I write out a script that I try to call from config.g that just sets up the last executed tool script.
                                      Setup 3 to 1
                                      M28 "0:/sys/lasttool.g"
                                      M98 P"0:/macros/Config Scripts/Setup 3 to 1 Hotend"
                                      M29
                                      I have a script that uses conditional code to clear out tools, fans, and heaters as well as de-energizing my relays (stepper bank switch).
                                      Change Toolhead
                                      ;echo "check temperature"
                                      while iterations < #sensors.analog
                                      	if sensors.analog[iterations] != null && sensors.analog[iterations].lastReading > 32 && sensors.analog[iterations].name != "PS"
                                      		if sensors.analog[iterations].name != "Bed"
                                      			abort "Must wait for tool head to cool down!!!"
                                      ;echo "set relays"
                                      M18 E ; Turn off Steppers for extruders
                                      G4 P100
                                      M42 P0 S0 ; Ensure relay 0 is off
                                      M42 P1 S0 ; Ensure relay 1 is off
                                      M42 P2 S0 ; Ensure relay 2 is off
                                      G4 P100
                                      ;echo "remove all tools"
                                      while iterations < #tools
                                      	;echo "Removing Tool ", tools[iterations].name, "T", iterations
                                      	M563 P{iterations} D-1 H-1
                                      ;echo "disable heaters"
                                      	if heat.bedHeaters[0] != iterations
                                      		;echo "Removing Temp Sensor and heater", sensors.analog[heat.heaters[iterations].sensor].name, "T", heat.heaters[iterations].sensor, "H", iterations
                                      		M308 S{heat.heaters[iterations].sensor} P"nil" Y"nil"
                                      		M950 H{iterations} C"nil"
                                      ;echo "remove fans"
                                      while iterations < #fans
                                      	if fans[iterations] != null && fans[iterations ].name != "Power Supply"
                                      		;echo "Removing Fan", fans[iterations].name, "F", iterations
                                      		M950 F{iterations} C"nil"
                                      M30 "0:/sys/lasttool.g"
                                      • fmaundefined
                                        fma
                                        Once reading I²C bus is implemented (it is maybe already done in current release, I didn't check yet), using a I²C EEPROM can be a way to identify a device; this is often used in consumer products (Gopro does or did that for their accessories).
                                        Frédéric
                                        • A Former User?
                                          A Former User @fma
                                          @fma said in Invitation to share your conditional GCode scripts:
                                          It also opens the possibility to store calibration data etc in the tool independent of the machine, ref IEEE1451-ish. Although Duet3d avoided using I2C for their fillament sensor (unlike Prusa) as the bus isn't intended for long runs. Maybe we'll see 1-wire or something in the future?
                                          • fmaundefined
                                            fma
                                            Well, the filement sensor needs continuous readings, which is not the case for calibration or so.
                                            Frédéric
