    Preview version of CNC optimized DWC.
    CNC
    40
    191
    22.2k
    • zendesignerundefined
      zendesigner
      wow Great,
      I just bought a WMD30LV mill and planning on converting it to CNC. i have some duet wifi boards lying around and would like to use them as i have them in all of my 3d printers.
      This certainly would make the special zero requirements and the jogwheel possible in a really nice way.
      Cool dude, really thanks.
      Zen
      tenajaundefined 1 Reply Last reply Reply Quote 0
      • tenajaundefined
        tenaja @zendesigner
        @zendesigner , until Duets get backlash compensation, it's not suitable for real (i.e. accurate) cnc work. If you want accurate work, you will want LinuxCNC. I think Marlin perhaps has backlash comp, but I've not verified or used it.
        I use Duet on a few desktop applications, but until it gets backlash comp, I won't put it on my mills.
        Once it does get it, I've got a couple machines that might benefit from it.
        • PCRundefined
          PCR
          @tenaja See this Thread
          Re: Backlash compensation
          • tenajaundefined
            tenaja @PCR
            @PCR said in Preview version of CNC optimized DWC.:
            Exactly! It has not been implemented, so a Duet is not suitable for real CNC machines.
            It might work fine for a "hobbyist cnc" unit , or a 3d printer-style router, but it is not suitable for machining accurate metal.
            There's nothing wrong with using a Duet as a hobbyist controller, or for routing out signs where a few thou of error is irrelevant. But for anyone who needs accuracy, it's not suitable. Heck, even the Sherline instructions tell you to set 0.002" to 0.005" of backlash so it's not too tight. I ran thousands of tight tolerance parts on a few of those, but they sure compensated for backlash so I could run the same code on them without hassle or loss of precision.
            And for the naive who claim a "real machine" won't have backlash, even the big name 3 to 5 ton machines have backlash compensation in them.
            • rilotundefined
              rilot
              I'm running the Workbee CNC fork on my router. Does this new experimental version of DWC support work edge finding like the Workbee Web Control? Yes, I know I can achieve the same with macros but the way that Workbee does it is very convenient with a single button to press and a box where you input your tool diameter.
              Sindariusundefined 1 Reply Last reply Reply Quote 0
              • Sindariusundefined
                Sindarius @rilot
                @rilot I have not used the Workbee CNC ui so I am not sure if it is a macro being fired or a custom wizard they made. I can certainly look into it.
                • rilotundefined
                  rilot
                  @Sindarius The work edge finding in the Workbee panel is a set of boxes you can fill in that automatically generate and then fire macros based on user input. It's very reliable and easy to trigger / configure. If this new version of DWC could do that then I would switch in a heartbeat as there are many functions of the newer Duet firmware I'd like to use but cannot due to needing the older 2.x based version to support the Workbee WC.
                  Sindariusundefined 1 Reply Last reply Reply Quote 1
                    Sindarius @rilot
                    @rilot I pulled down the Workbee Control and took a look at it. It looks like they are generating a probe.g macro on the fly based off those settings when you click probe corner. Since not everyone uses an xyz touch probe I may look into making something like this a plugin. I'll start looking at the gcode to see what needs to be done to generate the macros. The one item that popped out in one of the macros it generated was that it uses P999 for creating a tool and I believe from reading the new limit is 49. Didn't dig too much further into other differences.
                    UcantCNCmeundefined Hagridundefined 2 Replies Last reply Reply Quote 2
                    • rilotundefined
                      rilot
                      That's great. Thanks for your efforts with this.
                      • tooundefined
                        too
                        Hey @Sindarius, great work!
                        We have been looking for a way to clean up the interface for our concrete printers for a while now!
                        However, we still have an extruder axis that we need to control, do you think it will be possible to activate the CNC DWC with the nice work coordinate system handler and the big DRO also in FFF mode? (Or also show E axes in the jog button overview?)
                        Thanks a lot!
                        Cartesian Duet3+Raspberry pi 4 with 5x 1XD using servo drives printing mortars and concrete
                          Sindarius @too
                          @too the problem is that the cnc specific pages have had things like the extruder removed since they aren’t needed in cnc applications. It would likely come down to making a plugin that can bring both worlds together in a custom dashboard.
                          tooundefined 1 Reply Last reply Reply Quote 0
                          • tooundefined
                            too @Sindarius
                            @Sindarius Hmm.. I don't know about the inner workings of the DWC, but couldn't it be an option in settings to "show E axis control interface"?
                            Or would @dc42 have to ass something like this through the firmware?
                              Sindarius @too
                              @too Axes buttons on the dashboard are driven by the Object Model under Move > Axes. Extruders are in their own area in the Object Model. At some point I could look at bringing in extruders as E# axes but that would not be a focus for me at this moment.
                              • Alpenprinterundefined
                                Alpenprinter
                                I did not manage to install the CNC Webcontrol. The duetwebcontrol_sd.zip can be uploaded under „system“, the files are unzipped, but then nothing happens.
                                What is my mistake?
                                weed2allundefined 1 Reply Last reply Reply Quote 0
                                  Sindarius
                                  @Alpenprinter
                                  Do you have your machine configured for CNC?
                                  There should be an M453 somewhere in your config to enable CNC mode.
                                  • weed2allundefined
                                    weed2all @Alpenprinter
                                    @Alpenprinter you need to put M453 to activate cnc mode and with that the dwc for cnc will appear!!
                                    https://www.thingiverse.com/weed2all/designs
                                      Alpenprinter
                                      @Sindarius said in Preview version of CNC optimized DWC.:
                                      M453
                                      You are the best! Looking great!
                                      Could s.o. please post the config.g and the homing files, for a e axis mill, so I have a starting point for configuration?
                                      • neiloundefined
                                        neilo
                                        Hi All, hope you're well. I'm getting my head into this and have a couple of [newbie] questions:
                                        1. I'm setting up a z-probe but there is no z probe value on display - should I do the the calibration on the classic DWC then switch over to CNC? Same applies for endstop switches I guess.
                                        2. The set work Xyz button: does that link to a macro or does is just trigger a G92 command?
                                          Really think this is a great project!
                                          Thanks,
                                          Neil
                                          Sindarius @neilo
                                          @neilo said in Preview version of CNC optimized DWC.:
                                          Those are items that will be addressed in a future version of the DWC-CNC ui.
                                          1. The set work Xyz button: does that link to a macro or does is just trigger a G92 command?
                                          It is issuing a G10 L20 command to set the WCS.
                                          My understanding and someone please correct me if I am wrong G92 changes all of the WCS so I avoided it in this case.
                                          Thanks,
                                          Neil
                                            G92 does not affect WCS offsets.
