    Preview version of CNC optimized DWC.
    CNC
    40
    191
    22.2k
    • markzundefined
      markz @Sindarius
      @Sindarius These changes/plugins are just great.
      I've got a request for the Jog page plugin.
      Having home buttons imho makes little sense there. I maybe home once per day and in normal use if I hit home it's an at-best time-wasting mistake. Plus, I can already do it in the dashboard.
      Instead, I'd love it if we had a speed readout/control. Maybe it could have options like Travel, Feed, 20, 40, 60, 80 (mm/sec)?
      For the dashboard: I like to go to work 0,0 a lot, but rarely 0,0,0 - for whatever that's worth. My work Z=0 is usually the top of the workpiece, sometimes the top of the bed.
      Thanks again for all the work.
      Sindariusundefined 1 Reply Last reply Reply Quote 1
      • Sindariusundefined
        Sindarius @markz
        @markz Appreciate the feedback!
        On the jog control plugin I can look at adding a "go to work 0" button. I'll look into adding travel speed as a set of buttons like the distance that is on there. I have a couple ideas I plan to play with on the jog control but was looking forward to some feedback and ideas.
        • tntjetundefined
          tntjet
          @Sindarius how do I install your plugin for keyboard control?
          Sindariusundefined 1 Reply Last reply Reply Quote 0
            Sindarius @tntjet
            @tntjet You can download the plugin from my GitHub page
            https://github.com/Sindarius/DWC_GamepadJogger_Plugin/releases
            To install it take the zip file from the release and upload it using Files > System.
            Once the plugin is installed activate it by going to the "Machine Specific" page Plugins tab and start it.
            The latest version has the keyboard jogging setup.
            tntjetundefined 1 Reply Last reply Reply Quote 0
              A Former User @Sindarius
              @Sindarius said in Preview version of CNC optimized DWC.:
              -> ideas:
              Which protocol/standards are you planning to support -> USB and or D-Sub-9 ?
                Sindarius @A Former User
                @LB the gamepad jogger just picks up whatever gamepads it sees. Usb and bluetooth if available.
                markzundefined 1 Reply Last reply Reply Quote 0
                • tntjetundefined
                  tntjet @Sindarius
                  @Sindarius thankyou , great work!
                  • markzundefined
                    markz @Sindarius
                    @Sindarius Some more spontaneous feedback... since I'm just starting to use this.
                    1. The g-code viewer is just the coolest feature ever on my CNC.
                    2. I really like the gamepad jogger but
                      a) I had a small panic attack when I mapped Z today. My normal Z movement is much much smaller than X,Y and the auto-queued 'down' push at 50mm was scary - luckily I had no bit in the head. Having a separate Z distance would be very nice.
                      b) The feel when holding down a move key is great (the cnc just starts moving at speed) but because it's queueing up keystrokes when I release the button it keeps moving for some indeterminate number of steps.
                    by the way - I hacked the plugin to add a 25.4 distance option for something I needed to do in inches and it saved me hours of typing g codes and manually adding 3 digit numbers. Sweet!
                    1. The most important statistic in the G-code for a job for me is the surround box. It tells me if I did something stupid in the modeler like set the wrong origin for the material. Since you're already scanning the gcode is there some way in the viewer to quick-see the box values?
                    Thanks again. This stuff rocks.
                      Sindarius @markz
                      @markz glad you are enjoying the viewer!
                      It is funny you mention independent Z movement values, I had a similar experience with Openbuilds Control on my cnc some time back. I modded that software to add an independent z step because I managed to drive a v bit into my workpiece. I’ll look at making that an optional z step toggle in my gamepad jogger.
                      Because it is queueing gcode it does sometimes overshoot a step or two if you hold the stick down. I need to play with the timing more to avoid stuttering and not overshoot too much.
                      I can certainly look at adding some simple metrics to the 3D viewer in 3.3 or later. The first priority was getting all the gcode to render properly.
                      • zendesignerundefined
                        zendesigner
                        wow Great,
                        I just bought a WMD30LV mill and planning on converting it to CNC. i have some duet wifi boards lying around and would like to use them as i have them in all of my 3d printers.
                        This certainly would make the special zero requirements and the jogwheel possible in a really nice way.
                        Cool dude, really thanks.
                        Zen
                        tenajaundefined 1 Reply Last reply Reply Quote 0
                        • tenajaundefined
                          tenaja @zendesigner
                          @zendesigner , until Duets get backlash compensation, it's not suitable for real (i.e. accurate) cnc work. If you want accurate work, you will want LinuxCNC. I think Marlin perhaps has backlash comp, but I've not verified or used it.
                          I use Duet on a few desktop applications, but until it gets backlash comp, I won't put it on my mills.
                          Once it does get it, I've got a couple machines that might benefit from it.
                          • PCRundefined
                            PCR
                            @tenaja See this Thread
                            Re: Backlash compensation
                            • tenajaundefined
                              tenaja @PCR
                              @PCR said in Preview version of CNC optimized DWC.:
                              Exactly! It has not been implemented, so a Duet is not suitable for real CNC machines.
                              It might work fine for a "hobbyist cnc" unit , or a 3d printer-style router, but it is not suitable for machining accurate metal.
                              There's nothing wrong with using a Duet as a hobbyist controller, or for routing out signs where a few thou of error is irrelevant. But for anyone who needs accuracy, it's not suitable. Heck, even the Sherline instructions tell you to set 0.002" to 0.005" of backlash so it's not too tight. I ran thousands of tight tolerance parts on a few of those, but they sure compensated for backlash so I could run the same code on them without hassle or loss of precision.
                              And for the naive who claim a "real machine" won't have backlash, even the big name 3 to 5 ton machines have backlash compensation in them.
                              • rilotundefined
                                rilot
                                I'm running the Workbee CNC fork on my router. Does this new experimental version of DWC support work edge finding like the Workbee Web Control? Yes, I know I can achieve the same with macros but the way that Workbee does it is very convenient with a single button to press and a box where you input your tool diameter.
                                  Sindarius @rilot
                                  @rilot I have not used the Workbee CNC ui so I am not sure if it is a macro being fired or a custom wizard they made. I can certainly look into it.
                                  • rilotundefined
                                    rilot
                                    @Sindarius The work edge finding in the Workbee panel is a set of boxes you can fill in that automatically generate and then fire macros based on user input. It's very reliable and easy to trigger / configure. If this new version of DWC could do that then I would switch in a heartbeat as there are many functions of the newer Duet firmware I'd like to use but cannot due to needing the older 2.x based version to support the Workbee WC.
                                      Sindarius @rilot
                                      @rilot I pulled down the Workbee Control and took a look at it. It looks like they are generating a probe.g macro on the fly based off those settings when you click probe corner. Since not everyone uses an xyz touch probe I may look into making something like this a plugin. I'll start looking at the gcode to see what needs to be done to generate the macros. The one item that popped out in one of the macros it generated was that it uses P999 for creating a tool and I believe from reading the new limit is 49. Didn't dig too much further into other differences.
                                      UcantCNCmeundefined Hagridundefined 2 Replies Last reply Reply Quote 2
                                      • rilotundefined
                                        rilot
                                        That's great. Thanks for your efforts with this.
                                        • tooundefined
                                          too
                                          Hey @Sindarius, great work!
                                          We have been looking for a way to clean up the interface for our concrete printers for a while now!
                                          However, we still have an extruder axis that we need to control, do you think it will be possible to activate the CNC DWC with the nice work coordinate system handler and the big DRO also in FFF mode? (Or also show E axes in the jog button overview?)
                                          Thanks a lot!
                                          Cartesian Duet3+Raspberry pi 4 with 5x 1XD using servo drives printing mortars and concrete
                                            Sindarius @too
                                            @too the problem is that the cnc specific pages have had things like the extruder removed since they aren’t needed in cnc applications. It would likely come down to making a plugin that can bring both worlds together in a custom dashboard.
                                            tooundefined 1 Reply Last reply Reply Quote 0
