    G30 S-1 is giving me heart stitches [SOLVED]
    4.4k
    • Vetiundefined
      Veti
      post your config
      • o_lampeundefined
        o_lampe @Veti
        @Veti said in G30 S-1 is giving me heart stitches:
        post your config
        Just thought the same...
        config.g
        ; Configuration file for Duet Ethernet and Wifi
        ; Communication and general
        M111 S0                            		; Debug off
        M550 PDuetCNC					; Machine name and Netbios name (can be anything you like)
        M551 Preprap                   			; Machine password (used for FTP)
        ;*** If you have more than one Duet on your network, they must all have different MAC addresses, so change the last digits
        M540 P0xBE:0xEF:0xDE:0xAD:0xFE:0xED		; MAC Address
        ;*** Networking - Enable for both WiFi and Ethernet boards.
        M552 S1						; Turn network on
        M555 P2			; Set output to look like Marlin
        G21				; Work in millimetres
        G90				; Send absolute coordinates...
        M83				; ...but relative extruder moves
        M667 S1						; set CoreXY mode
        M92 X200 Y200 Z2500			; Set axis steps/mm
        M92 E400					; Set extruder steps per mm for Titan 1.8degree
        M201 X1000 Y1000 Z100 E1000      	; Accelerations (mm/s^2)
        M203 X15000 Y15000 Z1200 E3600  	; Maximum speeds (mm/min)
        M566 X600 Y600 Z30 E20          	; Maximum jerk speeds mm/minute
        M208 X280 Y170 Z250					; set axis maxima (adjust to suit your machine)
        M208 X0 Y0 Z-2 S1					; set axis minima (adjust to make X=0 and Y=0 the edges of the bed)
        M906 X1500 Y1500 Z1200 E800 I40		; Set motor currents (mA) and increase idle current to 40
        ; Axis and motor configuration
        M569 P0 S1					; Drive 0 goes forwards
        M569 P1 S0					; Drive 1 goes backwards
        M569 P2 S1					; Drive 2 goes forwards
        M569 P3 S0					; Drive 3 goes forwards
        M569 P4 S1					; Drive 4 goes forwards
        M574 X Y S3					; set endstop config (x y sensorless homing)
        M574 Z1 S2					; z endstop is on zprobe
        M584 X0 Y1 Z2 E3			; drive mapping
        M350 X16 Y16 Z16 E16 I1		; Set 16x microstepping with interpolation
        ; Thermistors
        M305 P0 T100000 B3950 R4700 H30 L0		; Put your own H and/or L values here to set the bed thermistor ADC correction
        M305 P1 T100000 B3974 R4700 H30 L0		; Put your own H and/or L values here to set first nozzle thermistor ADC correction
        M570 S180					; Hot end may be a little slow to heat up so allow it 180 seconds
        ; Adjustments for J-heads used as dummy heaters on test rig
        M307 H0 A145 C904 D2.5 B1
        M307 H1 A250 C140 D5.5 B0
        M106 P1 S-1					; disable thermostatic mode for fan 1
        ; Tool definitions
        M563 P0 D0 H1					; Define tool 0
        G10 P0 S0 R0					; Set tool 0 operating and standby temperatures
        ; Z probe and compensation definition
        ;*** If you have a switch instead of an IR probe, change P1 to P4 in the following M558 command
        M558 P5 I1 F500 T5000 A3 H5			; Z probe is an capacitive NPN sensor
        G31 X55 Y10 Z0 P500					; Set the zprobe height and threshold (put your own values here)
        T0						; select first hot end
        • chrishammundefined
          chrishamm administrators
          Please share your full config file and your deploy/retract macros if you use them. DWC 3.2 supports RRFv2 so you may try that as well.
          Do you run G30 S-1 or S-3 from the console or from a macro file?
          Duet software engineer
          • o_lampeundefined
            o_lampe @chrishamm
            @chrishamm
            I use the console, but also tried to setup a probe grid and use the menu run mesh bed levelling
            The funny thing is, beside doing these false horizontal moves, it probes the bed succesfully, but still the last move crashes into the leadscrew outside the printbed...
            • Vetiundefined
              Veti
              @o_lampe said in G30 S-1 is giving me heart stitches:
              this is incorrect . its missing the S parameter
              the correct dwc version is part of the release
              find it here
              https://github.com/Duet3D/RepRapFirmware/releases/tag/2.05.1
              • Vetiundefined
                Veti @o_lampe
                i see no M557 definition in your config for the mesh bed leveling
                • o_lampeundefined
                  o_lampe @Veti
                  find it here
                  Thanks!
                  I'll try S0 for maxima, but the examples in the gcode wiki only use S1 for minima ( S0 is default?)
                  Regarding the firmware, I did a full update earlier, but the DWC version was still 2.04?!
                  • Vetiundefined
                    Veti
                    did you download and install this?
                    https://github.com/Duet3D/RepRapFirmware/releases/download/2.05.1/DuetWebControl-SD-2.0.7.zip
                    • Vetiundefined
                      Veti @o_lampe
                      you really should be using the https://configtool.reprapfirmware.org/Start to generate your config
                      • o_lampeundefined
                        o_lampe @Veti
                        Right,
                        It's defined through the autoleveling menu in DWC.
                        That's why I tried to update DWC to 2.07...
                        I can try to put it in the config.g and then simply send G29 from the console?
                        • Vetiundefined
                          Veti @o_lampe
                          again the configtool will generate a config for you that has all the relevant parameters set.
                          even M557
                          i suggest that you put your existing values in there.
                          this will also make the migration to version 3 a lot easier as you can just import he json
                          • o_lampeundefined
                            o_lampe
                            OK, thanks to both of you @Veti and @chrishamm
                            for the qiuck responses.
                            I now have the confidence to solve it.
                            Will report later
                            • o_lampeundefined
                              o_lampe
                              Ok, no changes in behaviour so far...
                              I changed the maxima setting to 208 ...S0
                              I added M557 X10:250 Y10:170 S40:40 to specify the mesh grid
                              I copied DWC 2.07 to the SD card. ( What a relieve)
                              But still it does these funny moves and crashes into the leadscrew.
                              Any other suggestions?
                              • o_lampeundefined
                                o_lampe
                                Oh, there's one thing I want to ask:
                                I have a negative number for Zmin in the M208 S1.
                                Now, when I home Z, the homed height is set to -2 or whatever I set in M208.
                                I haven't found the right way to compensate that other than overwriting it with G92 Z0.
                                Does it matter if my G31 Z-probe definition is before or after M208?
                                • Vetiundefined
                                  Veti @o_lampe
                                  post you home script
                                  • fcwiltundefined
                                    fcwilt
                                    M574 X Y S3 - where are the values for X and Y specify the location of the end stop?
                                    You have specified the Z trigger height in G31 as 0. Usually a capacitive probe triggers a few mm off the surface.
                                    Also capacitive probes can be slow to respond so you might need to change the F value in M558.
                                    When you home any axis the position is set to the axis min/max based on the axis parameter in M574.
                                    You have specified that the end stop of Z is at the low end so it gets set to Z min which you have as -2.
                                    Why do you have Z min as -2?
                                    • o_lampeundefined
                                      o_lampe @Veti
                                      G91
                                      G29 S2
                                      G1 S1 Z-300 F800
                                      G1  Z5 F800
                                      G1 S1 Z-10
                                      ;G92  Z0.0
                                      G90
                                      ;G29 S1
                                      What does it mean, when DWC is giving me a warning about Z=0 datum isn't set everytime i load the heightmap?
                                      Is it trying to do that, when it crashes against the leadscrew?
                                      I've made two short videos to show what happens, but I'm not sure when I find the nerve to upload them to u-tube.
                                      • Vetiundefined
                                        Veti
                                        that is not a home script. as it disregards any endstop
                                        nevermind. it used the old S syntax.
                                        that is the reason why its set to S-1
                                        when the endstop is triggered the axis is set to the endstop position.
                                        with a G30 this will not happen as this sets the current positon to z=0
                                        that would also get rid of the Z=0 datum message.
                                        o_lampeundefined 2 Replies Last reply Reply Quote 0
                                        • o_lampeundefined
                                          o_lampe @Veti
                                          @Veti
                                          To be clear, it uses the Z-probe as endstop.
                                          • Vetiundefined
                                            Veti
                                            that is wrong.
                                            try a default homez.
                                            ; homez.g
                                            ; called to home the Z axis
                                            ; generated by RepRapFirmware Configuration Tool v3.2.2 on Wed Jan 20 2021 13:31:39 GMT+0100 (Central European Standard Time)
                                            G91 ; relative positioning
                                            G90 ; absolute positioning
                                            G1 X15 Y15 F6000 ; go to first probe point
                                            ;G91 ; relative positioning
                                            ;G90 ; absolute positioning
