    G30 S-1 is giving me heart stitches [SOLVED]
    4.6k
    • Vetiundefined
      Veti @o_lampe
      @o_lampe said in G30 S-1 is giving me heart stitches:
      It's defined through the autoleveling menu in DWC.
      again the configtool will generate a config for you that has all the relevant parameters set.
      even M557
      i suggest that you put your existing values in there.
      this will also make the migration to version 3 a lot easier as you can just import he json
      • o_lampeundefined
        o_lampe
        OK, thanks to both of you @Veti and @chrishamm
        for the qiuck responses.
        I now have the confidence to solve it.
        Will report later
        • o_lampeundefined
          o_lampe
          Ok, no changes in behaviour so far...
          I changed the maxima setting to 208 ...S0
          I added M557 X10:250 Y10:170 S40:40 to specify the mesh grid
          I copied DWC 2.07 to the SD card. ( What a relieve)
          But still it does these funny moves and crashes into the leadscrew.
          Any other suggestions?
          • o_lampeundefined
            o_lampe
            Oh, there's one thing I want to ask:
            I have a negative number for Zmin in the M208 S1.
            Now, when I home Z, the homed height is set to -2 or whatever I set in M208.
            I haven't found the right way to compensate that other than overwriting it with G92 Z0.
            Does it matter if my G31 Z-probe definition is before or after M208?
            • Vetiundefined
              Veti @o_lampe
              post you home script
              • fcwiltundefined
                fcwilt
                M574 X Y S3 - where are the values for X and Y specify the location of the end stop?
                You have specified the Z trigger height in G31 as 0. Usually a capacitive probe triggers a few mm off the surface.
                Also capacitive probes can be slow to respond so you might need to change the F value in M558.
                When you home any axis the position is set to the axis min/max based on the axis parameter in M574.
                You have specified that the end stop of Z is at the low end so it gets set to Z min which you have as -2.
                Why do you have Z min as -2?
                • o_lampeundefined
                  o_lampe @Veti
                  @Veti said in G30 S-1 is giving me heart stitches:
                  G91
                  G29 S2
                  G1 S1 Z-300 F800
                  G1  Z5 F800
                  G1 S1 Z-10
                  ;G92  Z0.0
                  G90
                  ;G29 S1
                  What does it mean, when DWC is giving me a warning about Z=0 datum isn't set everytime i load the heightmap?
                  Is it trying to do that, when it crashes against the leadscrew?
                  I've made two short videos to show what happens, but I'm not sure when I find the nerve to upload them to u-tube.
                  • Vetiundefined
                    Veti
                    that is not a home script. as it disregards any endstop
                    nevermind. it used the old S syntax.
                    that is the reason why its set to S-1
                    when the endstop is triggered the axis is set to the endstop position.
                    with a G30 this will not happen as this sets the current positon to z=0
                    that would also get rid of the Z=0 datum message.
                    o_lampeundefined 2 Replies Last reply Reply Quote 0
                    • o_lampeundefined
                      o_lampe @Veti
                      @Veti
                      To be clear, it uses the Z-probe as endstop.
                      • Vetiundefined
                        Veti
                        that is wrong.
                        try a default homez.
                        ; homez.g
                        ; called to home the Z axis
                        ; generated by RepRapFirmware Configuration Tool v3.2.2 on Wed Jan 20 2021 13:31:39 GMT+0100 (Central European Standard Time)
                        G91 ; relative positioning
                        G90 ; absolute positioning
                        G1 X15 Y15 F6000 ; go to first probe point
                        ;G91 ; relative positioning
                        ;G90 ; absolute positioning
                        • o_lampeundefined
                          o_lampe @Veti
                          So, I should use G30 instead of G1 S1?
                          • Vetiundefined
                            Veti @o_lampe
                            @o_lampe
                            yes
                            you REALLY need to use a standard config that is generated by the config tool.
                            • o_lampeundefined
                              o_lampe @Veti
                              @o_lampe
                              yes
                              I started filling out the config wizard, but then got stuck with the stepper settings. I would have to copy my existing config settings into the wizard, so what is it good for?
                              I'd just copy any possible mistake into the new file, if there's any...
                              • Vetiundefined
                                Veti @o_lampe
                                @o_lampe
                                well it would have generated a correct homing script for once.
                                and as i said it will make the migration to version 3 easier
                                • o_lampeundefined
                                  o_lampe
                                  The head moves to that first probe point and then throws an error insufficient axes homed
                                  As always I homed X/Y before homeZ with G92 X0 Y0.
                                  Do I really have to install endstops for X/Y axis?
                                  I never needed them for my CNC. I just parked the toolhead at 0,0 before I switched off and went the G92 way to start...
                                  I checked the homeX/Y files. They all look similar to the one I originally posted. (I had this SD-card backup from my CNC machine)
                                  • Vetiundefined
                                    Veti
                                    the G30 command give you insufficient axis homed?
                                    • fcwiltundefined
                                      fcwilt @o_lampe
                                      The would work IF the actual positions of X and Y were zero. How do you know they are?
                                      No - you can use sensor-less homing.
                                      I don't care for that myself. To me using physical end stop sensors for homing is like stopping your car using the brakes. Sensor-less homing seems like stopping your car by running into the car in front of you. 😉
                                      As to using G30: did you read the docs on what each variant of G30 does?
                                      o_lampeundefined 1 Reply Last reply Reply Quote 1
                                      • o_lampeundefined
                                        o_lampe @Veti
                                        No, the macro doesn't run G30 because of the error message.
                                        I used jumpers on X/Y endstops and defined them as active high
                                        When I ask M119 it reports X/Y at min endstops. Now I should be able to use the homeall macro. But it stops after the same line as above mentioned.
                                        • Vetiundefined
                                          Veti
                                          post your homeall then
                                          • o_lampeundefined
                                            o_lampe @fcwilt
                                            @fcwilt said in G30 S-1 is giving me heart stitches:
                                            Yes, and I also tried some other versions with various Px and Sx parameters.
