    RRF3 How to display the height map ?
    527
    • JayJayundefined
      JayJay
      As per the title.
      I have just attempted to display the height map in RRF3
      Im on the latest stable firmware & D.W.C.
      Im following ther instructions from the dozuki Here
      G29 doesnt display the height map, it only starts probing.
      And in D.W.C. if I click on the drop down menu "Auto Bed Compensation" there is no option to "Show Mesh Grid" in the drop down menu.
      anyone any ideas ?
        jay_s_uk @JayJay
        @JayJay
        the height map is now a plugin under general and then plugins
        JayJayundefined 1 Reply Last reply Reply Quote 1
        • JayJayundefined
          JayJay @jay_s_uk
          @jay_s_uk said in RRF3 How to display the height map ?:
          @JayJay
          Still no worky. I can go general->plugin's and press "start" on the the height map button, it says started but nothing else shows or pops up section tried switching browsers incase it was that, no map showing on any of the chrome variants, FF or IE/Edge
          Why is there no mention of the change in the documentation ?
          • fcwiltundefined
            fcwilt @JayJay
            @JayJay
            When I enabled the plug-in this was the result.
            JayJayundefined 1 Reply Last reply Reply Quote 0
            • JayJayundefined
              JayJay @fcwilt
              @fcwilt said in RRF3 How to display the height map ?:
              @JayJay
              Well that worked. Thank you.
              But this highlights Documentation.
              This is the fatal flaw of the duet, new features get added/changed but the documentation is not even an after thought, it just plain not updated, instead of being proactive things are only fixed in a reactive manner after people point out the problem, and there is far too much reliance on the good people of the forum to dig them out of the holes they dig for themselves.
              And im sorry to be so frank but duet documentation is just a mess.
                jay_s_uk
                @Phaedrux
                How is documentation for plugins going to be handled now that 3.2 is stable?
                  Hmm, what's weird is that according to the DWC release notes from 3.2beta 2 "Height Map plugin is loaded by default" which doesn't appear to be the case.
                  Good question.
                  jay_s_ukundefined 1 Reply Last reply Reply Quote 1
                    jay_s_uk @Phaedrux
                    @Phaedrux Its definitely not loaded by default
                      I've been told that the auto load is only set on a fresh install of 3.2, as in going from 3.1.1 to 3.2. If a previous beta had been installed it would need to be loaded manually. @JayJay what version were you on previous to 3.2?
                      https://github.com/Duet3D/DuetWebControl/blob/master/WHATS_NEW.md
                      The DWC what's new notes are here. They should be linked along with the main release notes as well especially now that DWC/DSF/RRF are intertwined, but separate.
                      • JayJayundefined
                        JayJay @Phaedrux
                        @Phaedrux said in RRF3 How to display the height map ?:
                        The board (duet-3-mini-5+) came with what duet3d released it with.
                        I updated to Firmware: 3.2-RC2 (2020-12-24) just after i received it.
                          Phaedrux Moderator @JayJay
                          @JayJay said in RRF3 How to display the height map ?:
                          Thanks. That may be enough then. Sorry about that. The SD cards get burned ahead of time and the early production runs had to be ready before 3.2 was final.
