RRF3 How to display the height map ?
@JayJay
the height map is now a plugin under general and then plugins -
@jay_s_uk said in RRF3 How to display the height map ?:
@JayJay
the height map is now a plugin under general and then pluginsStill no worky. I can go general->plugin's and press "start" on the the height map button, it says started but nothing else shows or pops up section tried switching browsers incase it was that, no map showing on any of the chrome variants, FF or IE/Edge
Why is there no mention of the change in the documentation ?
When I enabled the plug-in this was the result.
@fcwilt said in RRF3 How to display the height map ?:
Well that worked. Thank you.
But this highlights Documentation.
This is the fatal flaw of the duet, new features get added/changed but the documentation is not even an after thought, it just plain not updated, instead of being proactive things are only fixed in a reactive manner after people point out the problem, and there is far too much reliance on the good people of the forum to dig them out of the holes they dig for themselves.
And im sorry to be so frank but duet documentation is just a mess.
@Phaedrux
How is documentation for plugins going to be handled now that 3.2 is stable? -
Hmm, what's weird is that according to the DWC release notes from 3.2beta 2 "Height Map plugin is loaded by default" which doesn't appear to be the case.
Good question.
@Phaedrux Its definitely not loaded by default
I've been told that the auto load is only set on a fresh install of 3.2, as in going from 3.1.1 to 3.2. If a previous beta had been installed it would need to be loaded manually. @JayJay what version were you on previous to 3.2?
https://github.com/Duet3D/DuetWebControl/blob/master/WHATS_NEW.md
The DWC what's new notes are here. They should be linked along with the main release notes as well especially now that DWC/DSF/RRF are intertwined, but separate.
@Phaedrux said in RRF3 How to display the height map ?:
The board (duet-3-mini-5+) came with what duet3d released it with.
I updated to Firmware: 3.2-RC2 (2020-12-24) just after i received it. -
@JayJay said in RRF3 How to display the height map ?:
I updated to Firmware: 3.2-RC2 (2020-12-24) just after i received it.Thanks. That may be enough then. Sorry about that. The SD cards get burned ahead of time and the early production runs had to be ready before 3.2 was final.
