Is this a genuine Duet 2 Wifi?
post a picture of the back. but it looks good.
@Veti added to first post. Thanks
that looks like a genuine board.
clones are not allowed to use the logos on the back.
@Veti Good to know. Having got to grips with the Maestro I plan to upgrade my other printer with this. Is it possible to buy the connectors etc separately? Assume they're a standard?
Thanks. Any UK suppliers?
https://duet3d.dozuki.com/Wiki/Connector_and_spare_part_numbers
there are the partsand you can get the connectors here
https://www.digikey.co.uk/products/en?keywords=22-01-3027 -
Just one unrelated comment: I get worried when there's a metal bolt running through a PCB with a metal nut on the other side.
That is an invitation to short from the front layer to the back over time as they wear through the solder mask. Sometimes that's no big deal, and sometimes it's an invitation to cause real problems.
Nylon washers can help, but I personally prefer using full nylon bolts and nuts for mounting.
Just something to think about.
@alankilian I noted the lack of nylon washers but I appreciate your comment. I'll definitely have it in mind.
