    New to the duet COMPLETE NEWBIE
    5.4k
      We're on a roll!
      gabrealekundefined 1 Reply Last reply Reply Quote 0
      • gabrealekundefined
        gabrealek @Phaedrux
        @Phaedrux Good morning from my end. we definitely were on a roll yesterday. I did a PID test for the heated bed and this is what I got,
        1/20/2021, 7:25:49 PM M500
        1/20/2021, 7:25:31 PM M307 H0 R0.208 C535.3 D7.42 S1.00 V12.0
        Warning: M307: Heater 0 appears to be over-powered. If left on at full power, its temperature is predicted to reach 136C
        1/20/2021, 7:23:29 PM Warning: heater behaviour was not consistent during tuning
        Auto tuning heater 0 completed after 3 idle and 25 tuning cycles in 4384 seconds. This heater needs the following M307 command:
        Send M500 to save this command in config-override.g
        At this point I don't know what to do.
        EDIT: indeed i do, Ill go back in to the shop and tune the hotend as well and try to run the min temps for PLA. . hopefully i dont get any errors. I will let you know once i am finished.
        • Vetiundefined
          Veti
          you send M500 to save the tuning parameters.
            gabrealek @Veti
            @Veti
            Yes i sent it after both test were performed. Here is the summary for both
            1/21/2021, 10:15:03 AM M500
            1/21/2021, 10:14:47 AM M307 H1 R2.273 C141.1 D6.29 S1.00 V12.0
            1/21/2021, 10:14:20 AM Auto tuning heater 1 completed after 3 idle and 5 tuning cycles in 401 seconds. This heater needs the following M307 command:
            1/21/2021, 10:11:54 AM Auto tune starting phase 3, fan off
            1/21/2021, 10:09:52 AM Auto tune starting phase 2, heater settling
            1/21/2021, 10:07:44 AM Auto tune starting phase 1, heater on
            1/21/2021, 10:07:39 AM M303 H1 S210
            Auto tuning heater 1 using target temperature 210.0°C and PWM 1.00 - do not leave printer unattended
            1/21/2021, 10:06:23 AM M106 S127
            1/21/2021, 10:00:22 AM Connection established
            1/20/2021, 7:27:51 PM Connection interrupted, attempting to reconnect...
            HTTP request timed out
            1/20/2021, 6:22:39 PM Auto tune starting phase 3, fan off
            1/20/2021, 6:14:17 PM Auto tune starting phase 2, heater settling
            1/20/2021, 6:10:31 PM Auto tune starting phase 1, heater on
            1/20/2021, 6:10:25 PM M303 H0 S60
            Auto tuning heater 0 using target temperature 60.0°C and PWM 1.00 - do not leave printer unattended
            • Vetiundefined
              Veti
              i was talking about the delta calibration
              • Vetiundefined
                Veti @Veti
                the new hotend tuning command is
                M303 T0 S210
                  gabrealek @Veti
                  @Veti Ohhh , Okay. Im about to do a new one now then . THANKKK YOUUUUUUU!!! 🙂
                    M303 T0 S210 will tune the hotend heater and take the part cooling fan into account.
                    For the bed heater, the M303 H0 S60 is correct.
                    Not sure why you're getting that though. What kind of bed heater do you have on the CR-10? Stock? Are you starting from room temp?
                    Do the saved tuning results allow for you to heat the bed to 60 in a reasonable time and keep a consistent temp? If so, that's all that really matters.
                    gabrealekundefined 2 Replies Last reply Reply Quote 0
                      gabrealek @Phaedrux
                      @Phaedrux Big baby is doing better, i got her up to 50 and she held it pretty well. Thank you!! Ill keep you updated though
                        gabrealek @Phaedrux
                        @Phaedrux should i be concerned if the MCU temp is up to 27.6?
                          Probably not, but first make sure it's an accurate temp.
                          https://duet3d.dozuki.com/Wiki/Calibrating_the_CPU_temperature
                          With a bit of forced air cooling even after a long print it doesn't get much above 35 for me. And you really only need to worry about 80+ The drivers get hotter and need more cooling than the MCU, but the MCU temp can be used as a proxy for the driver temps and allow for using a thermostatically controlled fan. All described in this link.
                          https://duet3d.dozuki.com/Wiki/Mounting_and_cooling_the_board
                            gabrealek @Phaedrux
                            @Phaedrux I hooked one up and its good now. .
                            I tried to print the calibration box and my Extruder wasn't close to my bed at all still trying to print. . also when i try to home XYZ it states its "busy" and waits about 3-5 mins to move at all. . . idk what to do. Is it something id have to change within my config?
                              Please post your current config.g and homeall.g and copy and paste the first 50 lines or so of your sliced gcode file you're trying to print.
                                gabrealek @Phaedrux
                                @Phaedrux
                                ; generated by RepRapFirmware Configuration Tool v3.2.1 on Tue Jan 19 2021 17:33:25 GMT-0500 (Eastern Standard Time)
                                M550 P"Creola" ; set printer name
                                M552 S1 ; enable network
                                M586 P0 S1 ; enable HTTP
                                M586 P1 S0 ; disable FTP
                                M586 P2 S0 ; disable Telnet
                                M569 P0 S0 ; physical drive 0 goes backwards
                                M92 X80.00 Y80.00 Z400.00 E97.08 ; set steps per mm
                                M203 X6000.00 Y6000.00 Z600.00 E1200.00 ; set maximum speeds (mm/min)
                                M201 X500.00 Y500.00 Z120.00 E250.00 ; set accelerations (mm/s^2)
                                M84 S30 ; Set idle timeout
                                M208 X300 Y300 Z400 S0 ; set axis maxima
                                M574 Z1 S1 P"!zstop" ; configure active-high endstop for low end on Z via pin !zstop
                                M558 P0 H18 F120 T480000 ; disable Z probe but set dive height, probe speed and travel speed
                                M557 X10:220 Y10:220 S20 ; define mesh grid
                                M308 S0 P"bedtemp" Y"thermistor" T98801 B4185 ; configure sensor 0 as thermistor on pin e0temp
                                M950 H0 C"bedheat" T0 ; create bed heater output on e0heat and map it to sensor 0
                                M143 H0 S80 ; set temperature limit for heater 0 to 80C
                                M308 S1 P"e1temp" Y"thermistor" T98801 B4185 ; configure sensor 1 as thermistor on pin e1temp
                                ; homeall.g
                                ; called to home all axes
                                G91 ; relative positioning
                                G1 H2 Z18 F480000 ; lift Z relative to current position
                                G1 H1 X-305 Y-305 F3000 ; move quickly to X and Y axis endstops and stop there (first pass)
                                G1 H2 X5 Y5 F480000 ; go back a few mm
                                G1 H1 X-305 Y-305 F3600 ; move slowly to X and Y axis endstops once more (second pass)
                                G1 H1 Z-405 F3600 ; move Z down stopping at the endstop
                                G90 ; absolute positioning
                                G92 Z0 ; set Z position to axis minimum (you may want to adjust this)
                                ;G91 ; relative positioning
                                ;G1 Z18 F8000 ; lift Z relative to current position
                                ;G90 ; absolute positioning
                                ;FLAVOR:Marlin
                                ;TIME:15708
                                ;Filament used: 30.0079m
                                ;Layer height: 0.32
                                ;MINX:87.5
                                ;MINY:87.5
                                ;MINZ:0.32
                                ;MAXX:212.5
                                ;MAXY:212.5
                                ;MAXZ:99.84
                                ;Generated with Cura_SteamEngine 4.8.0
                                M140 S45
                                M105
                                M190 S45
                                M104 S210
                                M105
                                M109 S210
                                M82 ;absolute extrusion mode
                                M201 X500.00 Y500.00 Z100.00 E5000.00 ;Setup machine max acceleration
                                M203 X500.00 Y500.00 Z10.00 E50.00 ;Setup machine max feedrate
                                M204 P500.00 R1000.00 T500.00 ;Setup Print/Retract/Travel acceleration
                                M205 X8.00 Y8.00 Z0.40 E5.00 ;Setup Jerk
                                M220 S100 ;Reset Feedrate
                                M221 S100 ;Reset Flowrate
                                G28 ;Home
                                G92 E0 ;Reset Extruder
                                G1 Z2.0 F3000 ;Move Z Axis up
                                G1 X10.1 Y20 Z0.28 F5000.0 ;Move to start position
                                G1 X10.1 Y200.0 Z0.28 F1500.0 E15 ;Draw the first line
                                G1 X10.4 Y200.0 Z0.28 F5000.0 ;Move to side a little
                                G1 X10.4 Y20 Z0.28 F1500.0 E30 ;Draw the second line
                                G92 E0
                                G92 E0
                                G1 F2700 E-5
                                ;LAYER_COUNT:312
                                ;LAYER:0
                                M107
                                G0 F6000 X96.919 Y97.136 Z0.32
                                ;TYPE:SKIRT
                                G1 F2700 E0
                                G1 F1200 X97.194 Y96.861 E0.05174
                                G1 X97.565 Y96.502 E0.12042
                                G1 X97.79 Y96.289 E0.16164
                                G1 X98.257 Y95.859 E0.2461
                                G1 X98.563 Y95.587 E0.30057
                                Phaedruxundefined 3 Replies Last reply Reply Quote 0
                                  Phaedrux Moderator @gabrealek
                                  @gabrealek said in New to the duet COMPLETE NEWBIE:
                                  Delete these lines from your cura start gcode.
                                  ;FLAVOR:Marlin
                                  Also in Cura change your gcode flavour to REPRAP
                                  Also change cura to use relative extrusion while you're at it.
                                  Then reslice and try again.
                                    gabrealek @Phaedrux
                                    @Phaedrux I feel like such a nube, thanks again!! Im about to try now and keep you updated.
                                      Don't feel too bad, 3D printing is probably one of the most complicated hobbies you can pick up.
                                      gabrealekundefined 1 Reply Last reply Reply Quote 1
                                        gabrealek @Phaedrux
                                        @Phaedrux Okay. . so it tried to print again . . but . the extruder isnt going up or down . .
                                          Is your Z endstop the same as the other endstops? Your config has it as inverted signal, which could cause it to act as triggered even when it's not, meaning your homing is off.
                                          Does homeall work to move all axis to their endstops correctly? Are you then able to jog all axis around correctly?
                                          -x to the left, +x to the right, -y moves head to front of bed, +y moves head back, -z moves nozzle towards bed, +z moves nozzle away from bed.
                                            gabrealek @Phaedrux
                                            @Phaedrux im not able to move to any - axis. I was able to this morning and i havent unplugged anything. Should i go into my config and change that?
