New to the duet COMPLETE NEWBIE
5.4k
    Don't feel too bad, 3D printing is probably one of the most complicated hobbies you can pick up.
    undefined 1 Reply Last reply 21 Jan 2021, 20:15 Reply Quote 1
      gabrealek @Phaedrux
      @Phaedrux Okay. . so it tried to print again . . but . the extruder isnt going up or down . .
        Phaedrux Moderator @gabrealek
        @gabrealek said in New to the duet COMPLETE NEWBIE:
        M574 Z1 S1 P"!zstop" ; configure active-high endstop for low end on Z via pin !zstop
        Is your Z endstop the same as the other endstops? Your config has it as inverted signal, which could cause it to act as triggered even when it's not, meaning your homing is off.
        Does homeall work to move all axis to their endstops correctly? Are you then able to jog all axis around correctly?
        -x to the left, +x to the right, -y moves head to front of bed, +y moves head back, -z moves nozzle towards bed, +z moves nozzle away from bed.
        undefined 1 Reply Last reply 21 Jan 2021, 20:28 Reply Quote 0
          gabrealek @Phaedrux
          @Phaedrux im not able to move to any - axis. I was able to this morning and i havent unplugged anything. Should i go into my config and change that?
            G1 H2 X5 Y5 F480000 ; go back a few mm
            In your homeall can you change this line from G1 H2 to remove the H2 completely?
            What does it do when you tell it to home all?
            Does it move towards the endstops?
            I'm not sure what you mean by not able to move to any - axis.
            undefined 1 Reply Last reply 21 Jan 2021, 20:38 Reply Quote 0
              gabrealek @Phaedrux
              @Phaedrux whew . . Uhm so i went and took the "!" from in front of the zstop
              M574 Z1 S1 P"zstop" ; configure active-high endstop for low end on Z via pin zstop
              and now i'm able to move everything accordingly. It wouldn't let me use any of the negative machine movements. I dont know why it inverted it like that. . Do you think i should still go and remove the H2?
                Yes, still remove the H2. Glad that ! took care of the homing.
                undefined 1 Reply Last reply 21 Jan 2021, 20:59 Reply Quote 0
                  gabrealek @Phaedrux
                  @Phaedrux i took off the H2 and it wouldnt let me home all it gave me
                  G28
                  Error: G0/G1: insufficient axes homed
                  I put it back on and homed all again and it homed correctly . . . idk whats going on.
                    That's kind of why H2 shouldn't be in there. H2 will let it proceed even if there is a problem.
                    Looking at the printer from the front (so that the bed motor is at the rear) the 0,0 origin point should be the front left of the bed. -x should move to the left etc as I mentioned above.
                    We can test this without trying to home the printer first. Turn off the printer, move the print head and bed to the center point. Now turn the printer on and send g92 x150 y150 z1. Now you should be able to jog the axis around with the buttons to test that they move in the correct directions.
                    Then we need to know where the endetops are physically located on the cr10. IF it matches the ender3 the x should be on the left and y at the back by the motor. Is that right?
                    Then send m119 to get the status of the endstops. They should all say not triggered. And when you press them and send m119 it should say triggered.
                    undefined 5 Replies Last reply 21 Jan 2021, 21:52 Reply Quote 0
                      gabrealek @Phaedrux
                      @Phaedrux
                      ; homeall.g
                      ; called to home all axes
                      ; generated by RepRapFirmware Configuration Tool v3.2.1 on Tue Jan 19 2021 17:33:25 GMT-0500 (Eastern Standard Time)
                      G91 ; relative positioning
                      G1 H2 Z18 F480000 ; lift Z relative to current position
                      G1 H1 X-305 Y-305 F3000 ; move quickly to X and Y axis endstops and stop there (first pass)
                      G1 H1 X-305 Y-305 F3600 ; move slowly to X and Y axis endstops once more (second pass)
                      G1 H1 Z-405 F3600 ; move Z down stopping at the endstop
                      G90 ; absolute positioning
                      G92 Z0 ; set Z position to axis minimum (you may want to adjust this)
                      ;G91 ; relative positioning
                      ;G1 Z18 F8000 ; lift Z relative to current position
                      ;G90 ; absolute positioning
                      So just the first H2 right?
                      undefined 1 Reply Last reply 21 Jan 2021, 22:46 Reply Quote 0
                        gabrealek @Phaedrux
                        @Phaedrux
                        1/21/2021, 4:54:38 PM m119
                        Endstops - X: not stopped, Y: not stopped, Z: at min stop, Z probe: at min stop
                          gabrealek @Phaedrux
                          @Phaedrux
                          yes. Z is still triggered .
                          undefined 1 Reply Last reply 21 Jan 2021, 22:00 Reply Quote 0
                            gabrealek @gabrealek
                            @gabrealek
                            Endstops - X: not stopped, Y: at min stop, Z: at min stop, Z probe: at min stop
                            Y is triggered but Z is not at the moment and it still reads as "triggered". .
                              gabrealek @Phaedrux
                              @Phaedrux They are all moving correctly . im about to move it to the center to see if its still triggered. .
                              m119
                              Endstops - X: not stopped, Y: not stopped, Z: not stopped, Z probe: at min stop
                              YAYYYYYY
                                gabrealek @Phaedrux
                                @Phaedrux
                                1/21/2021, 5:04:08 PM G28
                                Does this mean i have to home them all individually at this point?
                                G1 (H1) Z18 F480000 ; lift Z relative to current position
                                would this work?
                                  Nope, just the one for the XY axis move. G1 H2 X5 Y5 F480000 ; go back a few mm
                                  undefined 1 Reply Last reply 21 Jan 2021, 23:20 Reply Quote 0
                                    gabrealek @Phaedrux
                                    @Phaedrux So do i change the value for F480000?
                                    As in go back a few MM i took it down to
                                    G1 Z18 F480000 ; lift Z relative to current position
                                    G1 H1 X-300 Y-300 F3000 ; move quickly to X and Y axis endstops and stop there (first pass)
                                    G1 H1 X-300 Y-300 F3600 ; move slowly to X and Y axis endstops once more (second pass)
                                    G1 H1 Z-400 F3600 ; move Z down stopping at the endstop
                                    So now when i try to homeall i cannot, it gives me
                                    G28
                                    So now its
                                    G1 X5 Y5 F480000 ; go back a few mm
                                    undefined undefined 2 Replies Last reply 22 Jan 2021, 00:49 Reply Quote 0
                                      fcwilt @gabrealek
                                      I think this should work. Since you have a Z end stop you can start by homing Z.
                                      My printers don't allow for homing X and Y at the same time - so I don't even know if it is possible. If not just do them one axis at a time.
                                      Add/Adjust F params as desired.
                                      JOOC where did the 480,000 value come from? That is rather fast.
                                      G91
                                      G1 H1 Z-400 F3000
                                      G92 Z0 ; change Z0 to match the actual Z co-ordinate at which the Z end stop triggers
                                      G1 Z10
                                      G1 H1 X-300 Y-300
                                      G1 X5 Y5
                                      G1 H1 X-6 Y-6 F300
                                      G90
                                      undefined 1 Reply Last reply 22 Jan 2021, 02:59 Reply Quote 0
                                        gabrealek @fcwilt
                                        @fcwilt they were generated with the config tool . . what should it be set to?
                                          The reason for the error is because you've taken the H2 off of the Z move at the start and end. Those were ok. I just wanted you to remove it from the XY move in the middle.
                                          This would work, but @fcwilt provided a better option anyway that homes the Z axis first.
                                          G1 H2 Z18 F6000 ; lift Z relative to current position
                                          G1 Z5 ; back off
                                          G1 H1 Z-400 F600 ; home z again slowly
                                          F480000 is 8000mm/s which is really fast. But it wouldn't actually be able to use that speed because the max speed limit set in config.g is 6000mm/min which is a good cruising around speed (100mm/s)
                                          undefined 1 Reply Last reply 22 Jan 2021, 03:18 Reply Quote 0
                                          53 out of 101
