Trianglelab Matrix Extruder somebody?
Well, those gears are produced from some sort of tool steel anyway since it machines so much better than low-carbon unalloyed steel.
These shaft holders are made from 1.2510 tool steel (with aluminium the shafts would be loose in the holders at 150C, hence steel), hardness as delivered around HRC23. Bores and other features are nice and smooth after machining, even with a simple helical toolpath:
And this is simple hot-rolled steel, same machine, same endmill:
Difference in finish is well visible. Compare that to the picture of the drive gear, so they use at least something similar. Brass would be 1/2 the hardness.
On the other hand I hope they did not make the teeth too hard. That would fracture them over time.
Hi *,
Let me come back to the topic.
Does anybody have some infos about the shipped thermistor? (24V)
I have the golden (brass) tube and a spring at the end of the cable. It looks like :
https://de.aliexpress.com/item/33029709571.html?spm=a2g0x.12010612.8148356.14.2b3743aavUups2 but with a spring like https://de.aliexpress.com/item/4000907614466.html?spm=a2g0x.12010612.8148356.2.2b3743aavUups2I'm totally confused now.
Does anybody have some settings which work fine? Is anybody willing to share them and ideally the "M307" for the hotend. I have them connected to a toolboard which can not auto tune the pid.Cheers, Chriss
@Chriss said in Trianglelab Matrix Extruder somebody?:
the thermistor is not 24v. only the heating element is.
they write they ship the thermistor with a Thermistor Semitec 104NT-4-R025H42G.
this is the same as the e3d one.if you connected them to 24v, you will have destroyed the thermistor.
Hahaha.... well the amount of destruction depends of the current than.
Enough fun for today, I mentioned the 24V because I'm not convinced that the guys from copyland send the same thermistor whether it is a 12 or 24 Volt kit. Thanks for the hint, I did not see that. the German translation drives me creazy. -
if anything it would depend on time; as the thermistor has a negative temperature coefficient its resistance would decrease as it heats up, causing the temperature to increase. if left long enough both 12v and 24v directly connected to a ntc thermistor would cook it.
@bearer said in Trianglelab Matrix Extruder somebody?:
Not if your source will deliver 0.001mA only.
i don't suspect you'll find many of those on a duet
@bearer Well, at least @PCR has one.
@Chriss i am only using PT1000 ones ;D
P1000 (and PT100) have positive temperature coefficients so they're inherently safe in that regards.
Hey guys....
What do you guys use as steps at M92 for the matrix thingy? I use exactly 300 at the moment, they mention 336. :? I'm a bit lost now... My setting seemed to be OK in the past but I have a lot of problems since I changed the filament.
Cheers, Chriss
Hi there,
if some of you are still interestet in watercooling the Hemera, I might have something for you: https://www.dold-mechatronik.de/mebs-Hemera-WaCo-Mod-PRE-SALE-special-price-Available-from-2932021
Have a nice weekend.
