    Air pump too fast at minimum pwm
    1.4k
    • Nxt-1undefined
      Nxt-1
      The last two tests I did before going to bed are 1) connecting a 1N4001 in parallel, just to try it out, 0 difference. 2) remove all diodes completely, voltage spikes up 50V, yikes.
      Duet3D and delta printer enthousiast. Buildlog
      Looking for Duet3D configuration support, check out Nxt-3D
      • alankilianundefined
        alankilian
        You've got the pump (or 1KOhm resistor) connected from the heater-out to ground right?
        And the scope connected from the heater-out to ground also right?
        I'm trying to understand that slowly-falling edge first and I'm confused, so I want to check.
        Nxt-1undefined 1 Reply Last reply Reply Quote 0
        • fcwiltundefined
          fcwilt
          I don't know if it really matters but according to the docs the I parameter in M106 is not supported in v3 firmware.
          From the docs:
          Innn Invert PWM (I1), disable fan (I-1), or normal mode (I0, default) (not supported in RRF_3, use M950)
          Could you connect just the 1K on the output and show the waveform for 1% at 1000 Hz?
            Do those traces you posted show the voltage at the Heater- terminal? Or did you take a differential measurement of the voltage across the pump motor?
            • Nxt-1undefined
              Nxt-1 @alankilian
              @alankilian said in Air pump too fast at minimum pwm:
              Forgive the crudity of the schematic, apparently I did not renew my DaveCAD licence 😞
              @dc42 said in Air pump too fast at minimum pwm:
              I believe the above sketch answers your question as well? If it makes a difference, I physically connected the scopemeter probes at the pump terminals.
              @fcwilt said in Air pump too fast at minimum pwm:
              From the docs:
              Are you sure M106 is not supported in rrf3? Because the docs I read here specifically mention that is how it should be done with rrf3
              I will post the trace of the 1K or similar at 1kHz tomorrow.
              • Nxt-1undefined
                Nxt-1 @fcwilt
                @fcwilt I see I read your post to quickly and missing that you specifically called the I paramter in M106. Good spot, I removed it but no difference.
                  alankilian
                  Yeah, that's going to give you some strange traces.
                  Connect the scope ground to a Ground pin, not to E1-
                  Since E1- is connected to the drain-side of a FET, it becomes floating when the output is not being driven and you lose your ground reference.
                  I think things will look better if you connect the scope ground to ground and scope-signal to E1-.
                  You'll see a zero-volt signal when the pump is "on" and a woozy-doozy signal probably getting up to 24 Volts when the pump is "off".
                  fcwiltundefined Nxt-1undefined 2 Replies Last reply Reply Quote 1
                  • fcwiltundefined
                    fcwilt @alankilian
                    It depends on the design of the scope.
                    I use a battery powered scope and I could connect it as shown and get a pseudo-differential view of the voltage across the motor.
                    A line powered scope can be designed to allow the same though a true differential probe would be preferred.
                    How you connect the scope depends mostly on the signal you wish to view.
                      alankilian @fcwilt
                      @fcwilt True, but the voltage across the motor without a ground reference isn't going to tell you things about the risetime and falltime of the control signal.
                      That's likely why you see 39 Volts across the motor. It's just inductive kickback.
                      Maybe you should add a very small value series resistor attached to the VIN side of the motor and measure from VIN to the other side of the resistor. That would get you motor current which is probably what you're looking for.
                      To get back to your problem, what kind of motor is in the air pump?
                      It might not even be able to be speed-adjusted much by varying the PWM of it's power supply.
                      Maybe you'd be better off looking into an adjustable blowoff valve to toss some of the air overboard.
                      I'm thinking as hard as I can about how to get you what you want and I'm not coming up with great ideas, I'm sorry.
                        alankilian
                        One other thought is to use a high-current medium-value inductor in series with your pump motor.
                        I've used those in systems where the motor's armature inductance was too low to get good speed control from a PWM signal.
                        Something to try anyway.
                        • Nxt-1undefined
                          Nxt-1 @alankilian
                          @alankilian You are right, the low side switching has gotten me several times over the years. Below is a trace of the motor running at 1% pwm with the scope gnd connected to actual gnd and the signal probe to the negative terminal of the motor.
                          For those who requested it, here a link to the pump I got.
                          • fcwiltundefined
                            fcwilt @Nxt-1
                            @Nxt-1
                            How are you setting the 1%?
                            The scope image simple doesn't look like 1% to me - unless I'm completely looking at it wrong.
                            • Nxt-1undefined
                              Nxt-1 @fcwilt
                              @fcwilt I am setting the 1% in the DWC machine control dashboard tab
                              • fcwiltundefined
                                fcwilt
                                I wonder if this is part of the problem.
                                This is a screen shot of the DWC Object Model showing the fan data for a Duet 3 Mini 5 I am testing running firmware 3.2.
                                Notice the min and max values.
                                IF they are being enforced this fan cannot be set to 1%.
                                That might explain why the scope image doesn't look like 1% to me.
                                I need to do some testing.
                                • fcwiltundefined
                                  fcwilt
                                  OK I issued M106 P0 S0.01
                                  This is what the object model shows now.
                                  Does this object model reflect what the fan output is actually doing?
                                  I don't know.
                                  But if the object model DOES correctly indicate what the fan output is doing it would explain why 1% is as not slow as you expected.
                                  • fcwiltundefined
                                    fcwilt
                                    To the M106 command in my config.g file for this fan I added this parameter and value L0.
                                    Then I issued the M106 P0 S0.01.
                                    This is the object model now.
                                    At this point it might help if @dc42 would jump in and clarify default fan settings like min speed when no M106 L parameter is present.
                                    In the meantime add L0 to the appropriate M106 in your config.g file and see it it makes a difference in the behavior of the pump.
                                    • fcwiltundefined
                                      fcwilt
                                      OK I took the time to configure out1 on the Duet 3 Mini as a fan.
                                      M950 F0 C"out1" Q500
                                      M106 P0 S0 H-1 C"F0"
                                      Notice there is no L parameter.
                                      I connected a 1K resistor across the outputs and connected my battery powered scope leads across the resistor.
                                      The scope has the ability to measure the duty cycle of a waveform and I enabled that feature.
                                      I re-booted the board and issued a M106 P0 S0.01 command.
                                      The object model reported that the actual value was 0.1.
                                      The scope reported the duty cycle to be 10%.
                                      I changed the fan setup to this:
                                      M106 P0 S0 H-1 C"F0" L0
                                      The object model reported that the actual value was 0.01.
                                      The scope reported the duty cycle to be 1%.
                                      So at least with firmware 3.2 on a Duet 3 Mini 5, the default L value for a fan is 0.1.
                                      And that explains why the pump would not go as slow as you wanted.
                                      Add the L parameter using whatever min value is suitable and you should be good to go.
                                      That was fun.
                                        Is scope ground connected to Duet ground, i.e. VIN- or the GND pin of any of the I/O connectors? I have a feeling that it isn't, which is why the trace is still odd.
                                        • Nxt-1undefined
                                          Nxt-1 @fcwilt
                                          @dc42 In the last trace I posted the scope ground was connected with a wire straight to the psu negative terminal.
                                          @fcwilt I never knew that there was a default min value, thanks for pointing that out. I have put it at 0 now and that definitely helped. The trace looked quite similar though, ie. as saw tooth.
                                          At this point I was ready to call it a day and slap a power resistor in series (which I tried and worked decently well) to drop the voltage. Out of curiosity and recalling that dc pointed out that the 22.5kHz switching frequency was very high, I tested again at 1kHz. (this was at like 4% or something similar). The trace speaks for itself I guess.
                                          I draw two conclusions from this. 1) The previous trace was not a measurement error as the setup did not change, only the frequency of operation. 2) The E1 mosfet on the duet cannot switch fast enough, there are unwanted capacitances or something in that area. At least the conclusion is something does not like higher switching speeds.
                                          EDIT: just to avoid confusion, all the traces I post here are scope gnd to actual gnd and scope signal to the negative terminal of the pump.
                                          • Nxt-1undefined
                                            Nxt-1
                                            Here are two more traces:
                                            5% @2kHz
                                            5% @5kHz
