    Weird problem in my tool chain
    3D Printing General Chat
    • o_lampeundefined
      o_lampe
      My tool chain: fusion360 => PrusaSlic3r2.2 => Duet1.02 with rrf3.2 and DWC3.2
      I've designed some parts in Fusion 360, exported them as .stl or .obj. Then sliced them in Slic3r.
      There was the first oddity, the layer count was off, after slicing, the sliced part wasn't shown and the scrollbar went from 9999 to -999 or the like.
      I can print the part and DWC shows the correct part height, but also the layer count is going nuts. last layer time toggles between 0-1sec.
      When I close DWC and reopen it, it shows the right layer time.
      I'm not blaming DWC or RRF, but Fusion360.
      Slic3r shows no errors, when opening the part, but something is wrong with the files...
      • oliofundefined
        oliof
        Are you slicing with variable layer height? That's known to confuse DWC
          Would need to see your start and end gcode. Can you share a sliced gcode file?
          • o_lampeundefined
            o_lampe @oliof
            @oliof
            Good point, but not that I'm aware of.
            Slic3r itself got confused by the .stl file I designed.
            I'm currently working in a different way to build the sketch/extrusion scheme. Since then, the problems in DWC are solved.
            I didn't use fusion360 for a few years now, and the latest update always complains I'm still using Win7. Maybe the hiccups in the tool chain are caused by that?
            • o_lampeundefined
              o_lampe @Phaedrux
              @Phaedrux
              Now that I have a working homeAll procedure, I've edited the existing gcode-files and the slicer start/end procedures. The wrong layercount is history now.
