    Duet 3 losing connection whilst printing
    Beta Firmware
    1.8k
    • Thoma308undefined
      Thoma308
      @Thoma308 said in Duet 3 losing connection whilst printing:
      click around in the Web GUI (while printing) the problem comes back immediately
      Seems to be a problem when the Pi is busy with something else while printing
      I have now done another test:
      Raspberry PI without LAN and without WLAN (offline).
      I got the Lost connection message 2 times in about 2 hours - but without aborting the print ...
      still funny the whole thing
      • Thoma308undefined
        Thoma308
        Even after some more tests and an update to the latest versions, the problem is still there and unsolved.
        So I would be glad for more ideas
        RepRapFirmware for Duet 3 MB6HC version 3.2 running on Duet 3 MB6HC v1.01 or later (SBC mode)
        Board ID: 08DJM-956L2-G43S4-6J1FL-3SJ6J-186LG
        Used output buffers: 1 of 40 (10 max)
        Static ram: 149788
        Dynamic ram: 62488 of which 64 recycled
        Never used RAM 146492, free system stack 128 words
        Tasks: Linux(ready,71) HEAT(blocked,296) CanReceiv(blocked,927) CanSender(blocked,352) CanClock(blocked,352) TMC(blocked,19) MAIN(running,1217) IDLE(ready,19)
        Owned mutexes: HTTP(MAIN)
        Last reset 01:17:13 ago, cause: software
        Last software reset details not available
        Error status: 0x00
        Aux0 errors 0,0,0
        Aux1 errors 0,0,0
        MCU temperature: min 23.8, current 29.9, max 31.1
        Supply voltage: min 23.7, current 23.9, max 24.1, under voltage events: 0, over voltage events: 0, power good: yes
        12V rail voltage: min 12.1, current 12.1, max 12.2, under voltage events: 0
        Driver 0: position 111288, standstill, reads 17312, writes 59 timeouts 0, SG min/max 0/1023
        Driver 1: position 69098, standstill, reads 17312, writes 59 timeouts 0, SG min/max 0/1023
        Driver 2: position 102, standstill, reads 17312, writes 59 timeouts 0, SG min/max 0/1023
        Driver 3: position 0, standstill, reads 17308, writes 63 timeouts 0, SG min/max 0/340
        Driver 4: position 0, standstill, reads 17309, writes 63 timeouts 0, SG min/max 0/321
        Driver 5: position 0, standstill, reads 17329, writes 43 timeouts 0, SG min/max 0/461
        Date/time: 2021-01-24 10:59:34
        Slowest loop: 181.18ms; fastest: 0.03ms
        === Storage ===
        Free file entries: 10
        DMs created 125, maxWait 476875ms, bed compensation in use: none, comp offset 0.000
        === MainDDARing ===
        Scheduled moves 107, completed moves 107, hiccups 0, stepErrors 0, LaErrors 0, Underruns [16, 0, 42], CDDA state -1
        === AuxDDARing ===
        Bed heaters = -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1, chamberHeaters = -1 -1 -1 -1
        Segments left: 0
        Movement lock held by null
        Telnet is idle in state(s) 0
        File* is idle in state(s) 0
        USB is idle in state(s) 0
        Aux is idle in state(s) 0
        Queue* is idle in state(s) 0
        LCD is idle in state(s) 0
        SBC is idle in state(s) 0
        Daemon is idle in state(s) 0
        Aux2 is idle in state(s) 0
        Code queue is empty.
        === CAN ===
        Messages queued 18522, send timeouts 41688, received 0, lost 0, longest wait 0ms for reply type 0, free buffers 48
        === SBC interface ===
        State: 4, failed transfers: 149
        Last transfer: 1ms ago
        RX/TX seq numbers: 33443/55116
        SPI underruns 192, overruns 31
        Number of disconnects: 10, IAP RAM available 0x2c8a8
        Buffer RX/TX: 0/0-0
        === Duet Control Server ===
        Duet Control Server v3.2.0
        Code buffer space: 4096
        Full transfers per second: 35.68
        Maximum length of RX/TX data transfers: 2548/36
        24.1.2021, 11:01:28: M122 "DSF": === Duet Control Server ===
        Full transfers per second: 35.76
        24.1.2021, 11:15:39: M122: === Diagnostics ===
        Used output buffers: 2 of 40 (10 max)
        Static ram: 149788
        Tasks: Linux(ready,71) HEAT(blocked,296) CanReceiv(blocked,927) CanSender(blocked,352) CanClock(blocked,352) TMC(blocked,19) MAIN(running,1141) IDLE(ready,19)
        Last reset 01:33:18 ago, cause: software
        Error status: 0x00
        Aux0 errors 0,0,0
        Aux1 errors 0,0,0
        MCU temperature: min 29.6, current 30.0, max 30.3
        Supply voltage: min 23.8, current 23.9, max 24.0, under voltage events: 0, over voltage events: 0, power good: yes
        Driver 0: position 111288, standstill, reads 27870, writes 0 timeouts 0, SG min/max not available
        Driver 1: position 69098, standstill, reads 27870, writes 0 timeouts 0, SG min/max not available
        Driver 2: position 16102, standstill, reads 27870, writes 0 timeouts 0, SG min/max not available
        Driver 3: position 0, standstill, reads 27866, writes 4 timeouts 0, SG min/max 0/280
        Driver 4: position 0, standstill, reads 27866, writes 4 timeouts 0, SG min/max 0/274
        Driver 5: position 0, standstill, reads 27870, writes 0 timeouts 0, SG min/max not available
        Date/time: 2021-01-24 11:15:38
        Slowest loop: 0.45ms; fastest: 0.04ms
        === Storage ===
        DMs created 125, maxWait 1432576ms, bed compensation in use: none, comp offset 0.000
        === MainDDARing ===
        Scheduled moves 109, completed moves 109, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 1], CDDA state -1
        === AuxDDARing ===
        Segments left: 0
        === CAN ===
        Messages queued 3859, send timeouts 8682, received 0, lost 0, longest wait 0ms for reply type 0, free buffers 48
        Last transfer: 2ms ago
        RX/TX seq numbers: 2360/24033
        Buffer RX/TX: 0/0-0
        Full transfers per second: 35.72
        Maximum length of RX/TX data transfers: 4080/156
        • gloomyandyundefined
          gloomyandy
          Can you check your rPi syslog file (/var/log/syslog) and look for warnings/errors from duet control server. if there are any do they match up with when you had the lost connections?
          camcamnzundefined 1 Reply Last reply Reply Quote 1
          • camcamnzundefined
            camcamnz @gloomyandy
            @gloomyandy said in Duet 3 losing connection whilst printing:
            /varlog/syslog
            Yes, I just started the heater, and instantly saw warnings in that log file, as below
            Jan 24 13:17:49 duet3 DuetWebServer[564]: [DoCode] Executing code 'M140 P0 S60'
            Jan 24 13:17:49 duet3 DuetWebServer[564]: #033[40m#033[32minfo#033[39m#033[22m#033[49m: Microsoft.AspNetCore.Mvc.Infrastructure.ContentResultExecutor[1]
            Jan 24 13:17:49 duet3 DuetWebServer[564]: Executing ContentResult with HTTP Response ContentType of text/plain; charset=utf-8
            Jan 24 13:17:49 duet3 DuetWebServer[564]: #033[40m#033[32minfo#033[39m#033[22m#033[49m: Microsoft.AspNetCore.Mvc.Infrastructure.ControllerActionInvoker[2]
            Jan 24 13:17:49 duet3 DuetWebServer[564]: Executed action DuetWebServer.Controllers.MachineController.DoCode (DuetWebServer) in 121.9828ms
            Jan 24 13:17:49 duet3 DuetWebServer[564]: #033[40m#033[32minfo#033[39m#033[22m#033[49m: Microsoft.AspNetCore.Routing.EndpointMiddleware[1]
            Jan 24 13:17:49 duet3 DuetWebServer[564]: Executed endpoint 'DuetWebServer.Controllers.MachineController.DoCode (DuetWebServer)'
            Jan 24 13:17:49 duet3 DuetWebServer[564]: #033[40m#033[32minfo#033[39m#033[22m#033[49m: Microsoft.AspNetCore.Hosting.Diagnostics[2]
            Jan 24 13:17:49 duet3 DuetWebServer[564]: Request finished in 124.107ms 200 text/plain; charset=utf-8
            Jan 24 13:17:49 duet3 DuetControlServer[3086]: [warn] Restarting transfer because a bad data response was received (0x00000022)
            Jan 24 13:17:49 duet3 DuetControlServer[3086]: [warn] Restarting transfer because a bad data response was received (0x00000011)
            Jan 24 13:17:50 duet3 DuetControlServer[3086]: [warn] Restarting transfer because a bad header response was received (0x000000b2)
            Jan 24 13:17:50 duet3 DuetControlServer[3086]: [warn] Bad data CRC32 (expected 0xe20300be, got 0x02635649)
            Jan 24 13:17:50 duet3 DuetControlServer[3086]: [warn] Bad data CRC32 (expected 0xe20300be, got 0xabbbd02c)
            Jan 24 13:17:50 duet3 DuetControlServer[3086]: [warn] Bad data CRC32 (expected 0xe20300be, got 0x66f47fab)
            Jan 24 13:17:50 duet3 DuetControlServer[3086]: [warn] Restarting transfer because the number of maximum retries has been exceeded
            Jan 24 13:17:50 duet3 DuetControlServer[3086]: [warn] Restarting transfer because a bad header response was received (0x00000074)
            Jan 24 13:17:50 duet3 DuetControlServer[3086]: [warn] Lost connection to Duet (Board is not available (no header))
            Jan 24 13:17:50 duet3 DuetControlServer[3086]: [info] Connection to Duet established
            Jan 24 13:17:50 duet3 DuetControlServer[3086]: [warn] Bad data CRC32 (expected 0xfee53e33, got 0x29af8a10)
            Jan 24 13:17:50 duet3 DuetControlServer[3086]: [warn] Restarting transfer because a bad data response was received (0x0000002c)
            Jan 24 13:17:51 duet3 DuetControlServer[3086]: [warn] Restarting transfer because a bad header response was received (0xffffffe1)
            Jan 24 13:17:51 duet3 DuetControlServer[3086]: [warn] Restarting transfer because a bad header response was received (0x0000007a)
            Jan 24 13:17:51 duet3 DuetControlServer[3086]: [warn] Lost connection to Duet (Board is not available (no header))
            Jan 24 13:17:51 duet3 DuetControlServer[3086]: [warn] Bad data CRC32 (expected 0x147bc906, got 0x094245ad)
            Jan 24 13:17:51 duet3 DuetControlServer[3086]: [warn] Bad data CRC32 (expected 0x147bc906, got 0xb45e66d9)
            Jan 24 13:17:51 duet3 DuetControlServer[3086]: [info] Connection to Duet established
            Jan 24 13:17:51 duet3 DuetControlServer[3086]: [warn] Restarting transfer because a bad header response was received (0x00000070)
            Jan 24 13:17:51 duet3 DuetControlServer[3086]: [warn] Restarting transfer because a bad data response was received (0xffffff77)
            Jan 24 13:17:51 duet3 DuetControlServer[3086]: [warn] Bad data CRC32 (expected 0xf639780f, got 0x6abe97ec)
            Jan 24 13:17:51 duet3 DuetControlServer[3086]: [warn] Restarting transfer because a bad header response was received (0x000000de)
            Dan1990undefined 1 Reply Last reply Reply Quote 0
              gloomyandy
              Looks like your heater may be introducing noise into the Duet/SBC connection. Obvious things are to check how the various cables are routed. How long is the cable between the rPi and the Duet? Perhaps some photos of how you have things set up?
              camcamnzundefined 1 Reply Last reply Reply Quote 0
              • camcamnzundefined
                @gloomyandy That was my first thought as well, so I moved the rPi out of the enclosure with the other electronics until it was sorted. It is that cable that came with the Duet ![alt text]duet.jpg
                • Thoma308undefined
                  Thoma308
                  SOLVED:
                  The Heater is not the problem
                  I plugged everything back in on the PI, keyboard, mouse,
                  HDMI, USB touchscreen and connected the PI to the LAN.
                  Also reinstalled Anydesk as a remote terminal.
                  I accessed everything via http://duet3.local/ and locally via the screen on the PI again.
                  AND NOW THE SOLUTION:
                  The separtate power supply is the problem. You can power the SBC directly and power the Duet separately.
                  there are jumpers for that on the board.
                  And that was the problem with two separate power supplies.
                  I now have a 4A power supply directly on the PI and through that I also feed the 5V in the Duet.
                  -> and that was the solution
                  2h printing without any error message
                  https://duet3d.dozuki.com/Wiki/Duet_3_Mainboard_6HC_Hardware_Overview#Section_5V
                  SBC->5V and 5V -> SBC both are now connected
                  • camcamnzundefined
                    camcamnz @Thoma308
                    @Thoma308 In that case, your problem is different to mine, as I already tried all the variations of powering pi & duet
                    • Thoma308undefined
                      Thoma308
                      But it probably has to do with the power supply. I would make some more attempts in this direction. I use a Raspberry Pi 4 Model B 4GB
                      • Dan1990undefined
                        Dan1990
                        I have the same problem but when I did connect it via duet->SBC still giving the same issue.
                        • Thoma308undefined
                          Thoma308
                          For me it runs perfectly now, but only with the power supply from the Pi and both jumper set
                          SBC->5V
                          5V -> SBC
                          • Dan1990undefined
                            Dan1990 @camcamnz
                            @camcamnz
                            how did u access the:
                            /varlog/syslog
                            • camcamnzundefined
                              camcamnz @Dan1990
                              @Dan1990 via ssh/putty.
                              There is a typo it is actually /var/log/syslog
                              I ran the following command and watched the output once whilst testing:
                              tail -f /var/log/syslog
                              • Dan1990undefined
                                Dan1990 @camcamnz
                                @camcamnz
                                Thanks,
                                I have the same issue as you, and I think I have found a lead to solve it. I disconnected the bed and for now, everything looks fine.
