Pause/Resume print
2.3k
    fcwilt @Touchthebitum
    @Touchthebitum said in Pause/Resume print:
    Extensions --> post processing --> modify g-code
    Sorry - I meant what commands are you issuing.
    undefined 1 Reply Last reply 24 Jan 2021, 13:58 Reply Quote 0
      Touchthebitum @fcwilt
      @fcwilt
      Sparkcube XL V 1.1 300x300x190, Radds, Raspberry, Keenovo silicone bedheat 220v, Big Booster Extruder, DIY building
      BLV Cube 665mm Direct Drive with Duet3/SBC (RPi 4) Mosquito Magnum/Bond Tech Extruder/Vanadium Nozzle, Keenovo silicone bedheat 220v
      undefined 1 Reply Last reply 24 Jan 2021, 14:02 Reply Quote 0
        @Touchthebitum
        Sorry again - what GCODE commands are being generated by the slicer to perform the filament change?
          Touchthebitum
          sorry 😉
          ;TYPE:CUSTOM
          ;added code by post processing
          ;script: PauseAtHeight.py
          ;current layer: 2
          M83 ; switch to relative E values for any needed retraction
          G1 F300 Z1.6 ; move up a millimeter to get out of the way
          G1 F9000 X50 Y50
          G1 F300 Z15 ; too close to bed--move to at least 15mm
          M104 S0 ; standby temperature
          M226 ; Do the actual pause
          M17 E0
          M109 S215 ; resume temperature
          G1 F300 Z1.6
          G1 F9000 X138.263 Y119.525
          G1 F300 Z0.6 ; move back down to resume height
          G1 F1800 ; restore extrusion feedrate
          M82 ; switch back to absolute E values
          G92 E0.06168
          undefined 1 Reply Last reply 24 Jan 2021, 14:14 Reply Quote 0
            @Touchthebitum
            Can you edit that code?
            Since the firmware is trying to handle the pause/resume operations on it's own using the pause/resume files it would seem that the slicer generated code should not include any code that duplicates what those two files do.
            So if the firmware pause/resume files do EVERYTHING that is needed then the slicer code should only be M226 or M600 for pause and nothing for resume.
            undefined 1 Reply Last reply 24 Jan 2021, 14:16 Reply Quote 0
              @fcwilt
              Yes I can edit it.
              Ok, thanks, I'll check that 😉
                Touchthebitum
                nothing to do 😞
                I only placed M600 on the gcode. The pause is perfect but when I press on "resume" it goes on the print point and turns back on the pause location ...
                undefined 1 Reply Last reply 24 Jan 2021, 14:41 Reply Quote 0
                  I don't understand what you mean by "goes on the print point" or "turns back on the pause location".
                  Can you phrase that another way?
                  undefined 1 Reply Last reply 24 Jan 2021, 14:43 Reply Quote 0
                    @fcwilt
                    the carriage turns back on the last printed position BUT doesn't print, then it turns back on the "pause" location
                    undefined 1 Reply Last reply 24 Jan 2021, 14:46 Reply Quote 0
                      @Touchthebitum
                      Still not clear.
                      Are you saying the carriage moves to the correct location for resuming BUT the printer returns to the paused state?
                        @fcwilt
                        exactly
                        undefined 1 Reply Last reply 24 Jan 2021, 14:47 Reply Quote 0
                          @fcwilt
                          exact
                          Great.
                          And if you pause then resume using the Pause and Resume buttons on the DWC it all works correctly?
                          undefined 1 Reply Last reply 24 Jan 2021, 14:48 Reply Quote 0
                            @fcwilt
                            yes
                            undefined 1 Reply Last reply 24 Jan 2021, 14:50 Reply Quote 0
                              @fcwilt
                              yes
                              Great - now I fully understand what you are doing and seeing.
                              What I don't understand is why pausing from the slicer isn't working. I have an idea but I need to try to verify it.
                              Perhaps we will get lucky and @dc42 will jump in here.
                              undefined 1 Reply Last reply 24 Jan 2021, 14:51 Reply Quote 0
                                @fcwilt
                                Pausing is working but resuming not ...
                                undefined 1 Reply Last reply 24 Jan 2021, 15:04 Reply Quote 0
                                  DIY-O-Sphere @Touchthebitum
                                  if state.currentTool != -1
                                  Can you try to remove that from the resume.g?
                                  (UTC+1)
                                  undefined 1 Reply Last reply 24 Jan 2021, 14:57 Reply Quote 0
                                    Touchthebitum @DIY-O-Sphere
                                    @DIY-O-Sphere
                                    Tried but nothing changed
                                      @fcwilt
                                      Sorry - I meant that pausing from the slicer is not resuming correctly as opposed to pausing from the DWC which does resume correctly.
                                      That suggests to me that the way the firmware handles a M226 or M600 pause is different from how it handles the pause initiated by the DWC.
                                      Here is something to try - just a long shot.
                                      Replace the M226 or M600 in the slicer with M400 followed by M25.
                                      undefined 1 Reply Last reply 24 Jan 2021, 15:10 Reply Quote 0
                                        @fcwilt
                                        same result
                                        undefined 1 Reply Last reply 24 Jan 2021, 15:12 Reply Quote 0
                                          @fcwilt
                                          same result
                                          Not really surprised at that.
                                          Have you tried pressing the DWC Resume button a second time?
                                          undefined 1 Reply Last reply 24 Jan 2021, 15:13 Reply Quote 0
                                          13 out of 41
