Pause/Resume print
2.3k
    Touchthebitum
    nothing to do 😞
    I only placed M600 on the gcode. The pause is perfect but when I press on "resume" it goes on the print point and turns back on the pause location ...
    Sparkcube XL V 1.1 300x300x190, Radds, Raspberry, Keenovo silicone bedheat 220v, Big Booster Extruder, DIY building
    BLV Cube 665mm Direct Drive with Duet3/SBC (RPi 4) Mosquito Magnum/Bond Tech Extruder/Vanadium Nozzle, Keenovo silicone bedheat 220v
    undefined 1 Reply Last reply 24 Jan 2021, 14:41 Reply Quote 0
      fcwilt @Touchthebitum
      @Touchthebitum said in Pause/Resume print:
      I don't understand what you mean by "goes on the print point" or "turns back on the pause location".
      Can you phrase that another way?
      undefined 1 Reply Last reply 24 Jan 2021, 14:43 Reply Quote 0
        Touchthebitum @fcwilt
        @fcwilt
        the carriage turns back on the last printed position BUT doesn't print, then it turns back on the "pause" location
        undefined 1 Reply Last reply 24 Jan 2021, 14:46 Reply Quote 0
          @Touchthebitum
          Still not clear.
          Are you saying the carriage moves to the correct location for resuming BUT the printer returns to the paused state?
            @fcwilt
            exactly
            undefined 1 Reply Last reply 24 Jan 2021, 14:47 Reply Quote 0
              @fcwilt
              exact
              Great.
              And if you pause then resume using the Pause and Resume buttons on the DWC it all works correctly?
              undefined 1 Reply Last reply 24 Jan 2021, 14:48 Reply Quote 0
                @fcwilt
                yes
                undefined 1 Reply Last reply 24 Jan 2021, 14:50 Reply Quote 0
                  @fcwilt
                  yes
                  Great - now I fully understand what you are doing and seeing.
                  What I don't understand is why pausing from the slicer isn't working. I have an idea but I need to try to verify it.
                  Perhaps we will get lucky and @dc42 will jump in here.
                  undefined 1 Reply Last reply 24 Jan 2021, 14:51 Reply Quote 0
                    @fcwilt
                    Pausing is working but resuming not ...
                    undefined 1 Reply Last reply 24 Jan 2021, 15:04 Reply Quote 0
                      DIY-O-Sphere @Touchthebitum
                      if state.currentTool != -1
                      Can you try to remove that from the resume.g?
                      (UTC+1)
                      undefined 1 Reply Last reply 24 Jan 2021, 14:57 Reply Quote 0
                        Touchthebitum @DIY-O-Sphere
                        @DIY-O-Sphere
                        Tried but nothing changed
                          @fcwilt
                          Sorry - I meant that pausing from the slicer is not resuming correctly as opposed to pausing from the DWC which does resume correctly.
                          That suggests to me that the way the firmware handles a M226 or M600 pause is different from how it handles the pause initiated by the DWC.
                          Here is something to try - just a long shot.
                          Replace the M226 or M600 in the slicer with M400 followed by M25.
                          undefined 1 Reply Last reply 24 Jan 2021, 15:10 Reply Quote 0
                            @fcwilt
                            same result
                            undefined 1 Reply Last reply 24 Jan 2021, 15:12 Reply Quote 0
                              @fcwilt
                              same result
                              Not really surprised at that.
                              Have you tried pressing the DWC Resume button a second time?
                              undefined 1 Reply Last reply 24 Jan 2021, 15:13 Reply Quote 0
                                @fcwilt
                                yes , three, four times 😉
                                  @fcwilt
                                  And each time it returns to the paused state?
                                  undefined 1 Reply Last reply 24 Jan 2021, 15:14 Reply Quote 0
                                    @fcwilt
                                    yes
                                      fcwilt
                                      Can you open the gcode file generated by the slicer and find the place where it issues the M226/M600?
                                      I would like to see, say, 10 lines of the gcode before and after that place.
                                      undefined 1 Reply Last reply 24 Jan 2021, 15:19 Reply Quote 0
                                        @fcwilt
                                        I copied the last requested modifications (M400/M25):
                                        G0 F7200 X119.901 Y137.202
                                        G0 X123.484 Y131.281
                                        G0 X124.451 Y129.87
                                        G0 X125.512 Y128.529
                                        G0 X126.639 Y127.282
                                        G0 X127.866 Y126.092
                                        G0 X129.172 Y124.987
                                        G0 X130.548 Y123.972
                                        G0 X131.989 Y123.051
                                        G0 X133.489 Y122.23
                                        G0 X138.746 Y120.054
                                        G0 X139.123 Y119.677
                                        G1 F1500 X139.672 Y119.552 E0.02789
                                        G1 X142.19 Y119.156 E0.12626
                                        G1 X144.892 Y118.999 E0.13406
                                        G1 X146.137 Y119.026 E0.06168
                                        G0 F7200 X145.873 Y119.084
                                        G1 F1800 E-1
                                        ;MESH:NONMESH
                                        ;TYPE:CUSTOM
                                        ;added code by post processing
                                        ;script: ChangeAtHeight.py
                                        ;current z: 0.600000
                                        M300 ;Beep
                                        M400
                                        M25
                                        ;LAYER:2
                                        ;TYPE:WALL-OUTER
                                        ;MESH:imbuto.stl
                                        G1 F1800 E1.08315
                                        G1 F1500 X123.597 Y131.358 E0.08025
                                        G1 X122.73 Y132.824 E0.07987
                                        G1 X121.964 Y134.345 E0.07987
                                        G1 X121.3 Y135.914 E0.0799
                                        G1 X120.76 Y137.475 E0.07746
                                        G1 X120.743 Y137.53 E0.0027
                                        G1 X120.308 Y139.122 E0.0774
                                        G1 X119.967 Y140.791 E0.07989
                                        G1 X119.741 Y142.48 E0.07991
                                        G1 X119.629 Y144.179 E0.07985
                                        G1 X119.631 Y145.882 E0.07987
                                        undefined 1 Reply Last reply 24 Jan 2021, 15:27 Reply Quote 0
                                          @Touchthebitum
                                          I don't see anything odd there - all looks fine.
                                          Hmm... My slicer allows me to add my own gcode at different points in the printing
                                          • the beginning
                                          • the end
                                          • layer change
                                          • tool change
                                          • filament retraction
                                          Does yours have different places? If so is there anything in them?
                                          undefined 1 Reply Last reply 24 Jan 2021, 15:28 Reply Quote 0
                                          19 out of 41
