Pause/Resume print
2.3k
    fcwilt @Touchthebitum
    @Touchthebitum said in Pause/Resume print:
    @fcwilt
    yes
    Great - now I fully understand what you are doing and seeing.
    What I don't understand is why pausing from the slicer isn't working. I have an idea but I need to try to verify it.
    Perhaps we will get lucky and @dc42 will jump in here.
    undefined 1 Reply Last reply 24 Jan 2021, 14:51 Reply Quote 0
      Touchthebitum @fcwilt
      @fcwilt
      Pausing is working but resuming not ...
      Sparkcube XL V 1.1 300x300x190, Radds, Raspberry, Keenovo silicone bedheat 220v, Big Booster Extruder, DIY building
      BLV Cube 665mm Direct Drive with Duet3/SBC (RPi 4) Mosquito Magnum/Bond Tech Extruder/Vanadium Nozzle, Keenovo silicone bedheat 220v
      undefined 1 Reply Last reply 24 Jan 2021, 15:04 Reply Quote 0
        DIY-O-Sphere @Touchthebitum
        if state.currentTool != -1
        Can you try to remove that from the resume.g?
        (UTC+1)
        undefined 1 Reply Last reply 24 Jan 2021, 14:57 Reply Quote 0
          Touchthebitum @DIY-O-Sphere
          @DIY-O-Sphere
          Tried but nothing changed
            @fcwilt
            Sorry - I meant that pausing from the slicer is not resuming correctly as opposed to pausing from the DWC which does resume correctly.
            That suggests to me that the way the firmware handles a M226 or M600 pause is different from how it handles the pause initiated by the DWC.
            Here is something to try - just a long shot.
            Replace the M226 or M600 in the slicer with M400 followed by M25.
            undefined 1 Reply Last reply 24 Jan 2021, 15:10 Reply Quote 0
              @fcwilt
              same result
              undefined 1 Reply Last reply 24 Jan 2021, 15:12 Reply Quote 0
                @fcwilt
                same result
                Not really surprised at that.
                Have you tried pressing the DWC Resume button a second time?
                undefined 1 Reply Last reply 24 Jan 2021, 15:13 Reply Quote 0
                  @fcwilt
                  yes , three, four times 😉
                    @fcwilt
                    And each time it returns to the paused state?
                    undefined 1 Reply Last reply 24 Jan 2021, 15:14 Reply Quote 0
                      @fcwilt
                      yes
                        fcwilt
                        Can you open the gcode file generated by the slicer and find the place where it issues the M226/M600?
                        I would like to see, say, 10 lines of the gcode before and after that place.
                        undefined 1 Reply Last reply 24 Jan 2021, 15:19 Reply Quote 0
                          @fcwilt
                          I copied the last requested modifications (M400/M25):
                          G0 F7200 X119.901 Y137.202
                          G0 X123.484 Y131.281
                          G0 X124.451 Y129.87
                          G0 X125.512 Y128.529
                          G0 X126.639 Y127.282
                          G0 X127.866 Y126.092
                          G0 X129.172 Y124.987
                          G0 X130.548 Y123.972
                          G0 X131.989 Y123.051
                          G0 X133.489 Y122.23
                          G0 X138.746 Y120.054
                          G0 X139.123 Y119.677
                          G1 F1500 X139.672 Y119.552 E0.02789
                          G1 X142.19 Y119.156 E0.12626
                          G1 X144.892 Y118.999 E0.13406
                          G1 X146.137 Y119.026 E0.06168
                          G0 F7200 X145.873 Y119.084
                          G1 F1800 E-1
                          ;MESH:NONMESH
                          ;TYPE:CUSTOM
                          ;added code by post processing
                          ;script: ChangeAtHeight.py
                          ;current z: 0.600000
                          M300 ;Beep
                          M400
                          M25
                          ;LAYER:2
                          ;TYPE:WALL-OUTER
                          ;MESH:imbuto.stl
                          G1 F1800 E1.08315
                          G1 F1500 X123.597 Y131.358 E0.08025
                          G1 X122.73 Y132.824 E0.07987
                          G1 X121.964 Y134.345 E0.07987
                          G1 X121.3 Y135.914 E0.0799
                          G1 X120.76 Y137.475 E0.07746
                          G1 X120.743 Y137.53 E0.0027
                          G1 X120.308 Y139.122 E0.0774
                          G1 X119.967 Y140.791 E0.07989
                          G1 X119.741 Y142.48 E0.07991
                          G1 X119.629 Y144.179 E0.07985
                          G1 X119.631 Y145.882 E0.07987
                          undefined 1 Reply Last reply 24 Jan 2021, 15:27 Reply Quote 0
                            @Touchthebitum
                            I don't see anything odd there - all looks fine.
                            Hmm... My slicer allows me to add my own gcode at different points in the printing
                            • the beginning
                            • the end
                            • layer change
                            • tool change
                            • filament retraction
                            Does yours have different places? If so is there anything in them?
                            undefined 1 Reply Last reply 24 Jan 2021, 15:28 Reply Quote 0
                              @fcwilt
                              it seems not 🙂
                              I can only edit the gcode on dwc
                              undefined 1 Reply Last reply 24 Jan 2021, 15:30 Reply Quote 0
                                @fcwilt
                                it seems not 🙂
                                So that code at the point of a layer change is being inserted by something the the DWC?
                                I didn't know that was possible.
                                undefined 1 Reply Last reply 24 Jan 2021, 15:32 Reply Quote 0
                                  @fcwilt
                                  no, I can do it manually on the DWC
                                    fcwilt
                                    I did my testing with a Duet 3 Mini 5 - no SBC attached.
                                    I created a ultra simple test print file - you could do it in notepad if that is all you have.
                                    G91
                                    G1 X100
                                    G1 X-100
                                    G1 X100
                                    G1 X-100
                                    M226
                                    G1 X100
                                    G1 X-100
                                    G1 X100
                                    G1 X-100
                                    the pause file:
                                    M291 P"PAUSE" R"PAUSE" T1
                                    the resume file
                                    M291 P"RESUME" R"RESUME" T1
                                    It all worked fine.
                                    I suggest you do the same and see if you have a different result
                                    undefined 1 Reply Last reply 24 Jan 2021, 16:28 Reply Quote 0
                                      @fcwilt
                                      The solution was M226 instead of M600.
                                      I had to edit and place M226 at the right layer.
                                      I kepts my pause and resume files and it worked.
                                      Thanks for your help 😉
                                      undefined 1 Reply Last reply 24 Jan 2021, 16:40 Reply Quote 1
                                        @fcwilt
                                        I kepts my pause and resume files and it woked.
                                        Glad to hear you got it working.
                                        I will need to test M600 as it is documented as being the same as M226 with the exception that if a file filament_change.g is present that is run instead of instead of pause.g.
                                        So in theory if filament_change.g is NOT present it should work just like M226.
                                        undefined 1 Reply Last reply 24 Jan 2021, 16:41 Reply Quote 0
                                          @fcwilt
                                          ok
                                          26 out of 41
