    Duet3 Mini + BLtouch - Z Homing problem
    615
    • Vetiundefined
      Veti
      my bad. i looked at the duet 3 pwm pins
        Phaedrux Moderator @karbo90x
        @karbo90x said in Duet3 Mini + BLtouch - Z Homing problem:
        The problem is still there...
        If you followed the guides I posted to use io3 and the config I posted it should work.
        Please post a photo of your wiring and post your current config files.
        What specifically doesn't work?
        • fcwiltundefined
          fcwilt @Sindarius
          @Sindarius said in Duet3 Mini + BLtouch - Z Homing problem:
          https://duet3d.dozuki.com/Wiki/Duet_3_Mini_5plus_Hardware_overview#Section_IO_port_pin_capabilities
          @Phaedrux - perhaps that information regarding pwm should be included in the section I mentioned.
          https://duet3d.dozuki.com/Wiki/Duet_3_Mini_5plus_Wiring#Section_Description_of_Connectors_and_indication_LEDs
            Phaedrux Moderator @fcwilt
            @fcwilt I've added a note that io_1,2,3 are PWM capable.
            • fcwiltundefined
              fcwilt @Phaedrux
              @Phaedrux said in Duet3 Mini + BLtouch - Z Homing problem:
              Grand. It can be a little confusing where different bits of information are here and there.
              Sindariusundefined 1 Reply Last reply Reply Quote 0
              • Sindariusundefined
                Sindarius @fcwilt
                @fcwilt
                M558 P9 C"^io2.in" H5 F200 T6000                   ; set Z probe type to bltouch and the dive height + speeds
                This line looks wrong I believe it should be
                M558 P9 C"io2.in" H5 F200 T6000
                Using a pullup doesn't seem to make a difference on my setup. So don't worry about changing it.
                karbo90xundefined 1 Reply Last reply Reply Quote 0
                • karbo90xundefined
                  karbo90x
                  My connection is the same as that in your guide of Ender3.Tomorrow i try to do a new complete wires connection from board to Bltouch.
                  The config file and Homing file are the same of the first post i write.Now the only difference is the IO_3.
                  The problems are the same of the first post.
                  • karbo90xundefined
                    karbo90x @Sindarius
                    @fcwilt
                    Yes,but i have try this modify.Thanks
                      M950 S0 C"io3.out"                                 ; create servo pin 0 for BLTouch
                      M558 P9 C"^io3.in" H5 F120 T6000                   ; set Z probe type to bltouch and the dive height + speeds
                      G31 P500 X-44 Y-17 Z2                              ; set Z probe trigger value, offset and trigger height
                      M557 X5:190 Y5:215 S10                             ; define mesh grid
                      M280 P0 S10 ; deploy BLTouch
                      M280 P0 S90 ; retract BLTouch
                      G1 H2 Z5 F6000          ; lift Z relative to current position
                      G1 H1 X-240 Y-240 F1800 ; move quickly to X and Y axis endstops and stop there (first pass)
                      G1 X5 Y5 F6000       ; go back a few mm
                      G1 H1 X-240 Y-240 F360  ; move slowly to X and Y axis endstops once more (second pass)
                      G90                     ; absolute positioning
                      G1 X100 Y100 F6000        ; go to first bed probe point and home Z
                      G30                     ; home Z by probing the bed
                      • fcwiltundefined
                        fcwilt
                        From your configuration file:
                        M574 Z1 S2					   ; configure Z-probe endstop for low end on Z
                        ; Z-Probe BLtouch
                        G30 S-2
                        dc42 has confirmed that M574 Z1 S2 is not correct.
                        See if M574 Z0 makes any difference. I don't think it will but it cannot hurt.
                        The G30 S-2 should not be there. You are trying to probe the bed during the "configuration phase". It may be ignored but remove it just the same.
                        You have the deployprobe.g and retractprobe.g files with the appropriate M280 command in each?
                        • karbo90xundefined
                          karbo90x
                          Hi friends, I solve the problem finally ...
                          I made the changes you told me and finished my homing and config files.
                          Unfortunately, even so and with a whole new wiring for the BLTOUCH...Not working yet...
                          Then I got an idea, but I wasn't sure it will work: I bought a new SD card, I copied the config files directly from "Original" SD. and WOOOOW all works magically at the first test!!!
                          How is it possible ???
                          Now I'm really happy!!
                          Thank you for yours suggestions which have been a great help to improve my knowledge and my configurations files.
                          Thanks so much to everyone!!!
                          fcwiltundefined adalton5683undefined 2 Replies Last reply Reply Quote 0
                          • fcwiltundefined
                            fcwilt @karbo90x
                            Glad to hear you got it working.
                            I have no idea why using a new SD card would fix it.
                            • adalton5683undefined
                              adalton5683 @karbo90x
                              @karbo90x Hello! Im having the same issue.
                              How exactly and what did you copy to the new SD?
                              I tried to copy the SYS folder over to a blank and it didnt work. also I tried to copy all files over and its not even getting to DWC now. Any help would be nice.
                                Phaedrux Moderator @adalton5683
                                @adalton5683 probably best to start a new thread with details of your full issue.
