    Help me get connected to my Duet2Wifi
    6.3k
    • Kwad3dundefined
      Kwad3d @Phaedrux
      @Phaedrux So Im having trouble with the Wifi connection again. Guessing my router reset or something. I identified the new address for the board but when I connect it says "Your Duet rejected the HTTP request: overflow". I went through the guide again and also referred to our previous messages on this chain but I can not figure it out. My research only comes up with a SD card problem but nothing changed besides the address on the router
        So your router gave the duet a new IP address? Can you set a DHCP reservation in the router so that the duet can keep the same ip long term?
        Kwad3dundefined 1 Reply Last reply Reply Quote 0
        • Kwad3dundefined
          Kwad3d @Phaedrux
          @Phaedrux said in Help me get connected to my Duet2Wifi:
          DHCP reservation
          Ok I figured it out and have it reserved
            What URL are you using to try and reach the Duet?
            Kwad3dundefined 3 Replies Last reply Reply Quote 0
            • Kwad3dundefined
              Kwad3d @Phaedrux
              @Phaedrux 192.168.1.3
              • Kwad3dundefined
                Kwad3d @Phaedrux
                @Phaedrux I connected to YAT and went through the steps in the guide and confirmed the URL
                  Have you tried a new SD card yet in case the /www folder has been corrupted?
                  • Kwad3dundefined
                    Kwad3d @Phaedrux
                    @Phaedrux I also turned off all other wifi devices and deleted them from my router for now untill I get the duet connected
                    • Kwad3dundefined
                      Kwad3d
                      Just copy to a new card?
                        Yes you can copy to a new card, but I would manually replace the contents of the /www folder with a known good download of the DWc files just in case.
                        Assuming you're on 3.2, you should replace the contents of /www with the contents of this zip file.
                        https://github.com/Duet3D/RepRapFirmware/releases/download/3.2/DuetWebControl-SD.zip
                          If you're still getting the error after replacing the SD card, please open up the developer console of your browser so we can see exactly where the error is being thrown.
                          • Kwad3dundefined
                            Kwad3d
                            Yea same message. whats the developer console?
                              Assuming you're using chrome: https://developers.google.com/web/tools/chrome-devtools/open
                              control-shift-J
                              Kwad3dundefined 2 Replies Last reply Reply Quote 0
                              • Kwad3dundefined
                                Kwad3d @Phaedrux
                                @Phaedrux Ok I think I got it. There is a side bar now
                                • Kwad3dundefined
                                  Kwad3d @Phaedrux
                                  @Phaedrux let me know how to proceed
                                    Try to go to the DWC and see what errors come up in the side bar. Take a screen shot and post it here.
                                    • Kwad3dundefined
                                      Kwad3d @Phaedrux
                                        Can you try access the DWC ip address from an incognito chrome window?
                                        • Kwad3dundefined
                                          Kwad3d @Phaedrux
                                          @Phaedrux Ok for some reason it connected to the board with the incognito window
                                            I think you have a browser extension blocking the connection or somehow modifying it.
