    Help me get connected to my Duet2Wifi
    6.3k
    • Kwad3dundefined
      Kwad3d @Phaedrux
      @Phaedrux said in Help me get connected to my Duet2Wifi:
      DHCP reservation
      Ok I figured it out and have it reserved
        What URL are you using to try and reach the Duet?
        Kwad3dundefined 3 Replies Last reply Reply Quote 0
        • Kwad3dundefined
          Kwad3d @Phaedrux
          @Phaedrux 192.168.1.3
          • Kwad3dundefined
            Kwad3d @Phaedrux
            @Phaedrux I connected to YAT and went through the steps in the guide and confirmed the URL
              Have you tried a new SD card yet in case the /www folder has been corrupted?
              • Kwad3dundefined
                Kwad3d @Phaedrux
                @Phaedrux I also turned off all other wifi devices and deleted them from my router for now untill I get the duet connected
                • Kwad3dundefined
                  Kwad3d
                  Just copy to a new card?
                    Yes you can copy to a new card, but I would manually replace the contents of the /www folder with a known good download of the DWc files just in case.
                    Assuming you're on 3.2, you should replace the contents of /www with the contents of this zip file.
                    https://github.com/Duet3D/RepRapFirmware/releases/download/3.2/DuetWebControl-SD.zip
                      If you're still getting the error after replacing the SD card, please open up the developer console of your browser so we can see exactly where the error is being thrown.
                      • Kwad3dundefined
                        Kwad3d
                        Yea same message. whats the developer console?
                          Assuming you're using chrome: https://developers.google.com/web/tools/chrome-devtools/open
                          control-shift-J
                          Kwad3dundefined 2 Replies Last reply Reply Quote 0
                          • Kwad3dundefined
                            Kwad3d @Phaedrux
                            @Phaedrux Ok I think I got it. There is a side bar now
                            • Kwad3dundefined
                              Kwad3d @Phaedrux
                              @Phaedrux let me know how to proceed
                                Try to go to the DWC and see what errors come up in the side bar. Take a screen shot and post it here.
                                Kwad3dundefined 1 Reply Last reply Reply Quote 0
                                • Kwad3dundefined
                                  Kwad3d @Phaedrux
                                    Can you try access the DWC ip address from an incognito chrome window?
                                    • Kwad3dundefined
                                      Kwad3d @Phaedrux
                                      @Phaedrux Ok for some reason it connected to the board with the incognito window
                                        I think you have a browser extension blocking the connection or somehow modifying it.
                                        • Kwad3dundefined
                                          Kwad3d @Phaedrux
                                          @Phaedrux yea has to be something like that. At least now I have the URL reserved on the router. I can get by on the incognito window until I figure out what is interrupting the connection
                                          • Kwad3dundefined
                                            Kwad3d
                                            So I ended up moving my operation into a commercial building and I need assistance getting the Duet connected to the new network. I installed YAT but M552 came back with "BAD Command"
