Delta to Toolchanger -> Core X/Y or H-Bot framekit?
core xy delta frame kit
796
    sungod3k
    i want to get into toolchanging but on a budget, and not with my delta. I have good parts but the frame i cant use.
    I looked a bit around for framekits. Openbuilds/Ratrig has some interesting frames in their library but those are expensive and https://seckit3dp.design/price/sk-go is of course nice, but also a bit pricy for the project.
    Buying a cheap printer for the parts like this is almost worth it, but I wonder if someone came across a decent framekit somewhere? (and then i can use my delta frame parts to stabilize it.)
    Cheers
    http://www.42dimensions.de/
    https://printnewworlds.blogspot.com/
      Veti
      the tronxy frame is terrible.
      if you just want a frame, you can buy extrusion from places like
      https://www.dold-mechatronik.de/Aluminum-profile-20x20-B-type-groove-6
      they even sell kits
      https://www.dold-mechatronik.de/BLV-MGN-Cube-Profile-groove-6
      undefined 1 Reply Last reply 30 Jan 2021, 14:06 Reply Quote 0
        fcwilt
        What's you budget?
        Just so you know a CoreXY is considered to be a superior design in relation to the H-Bot.
        undefined undefined 2 Replies Last reply 30 Jan 2021, 14:06 Reply Quote 0
          Veti
          the seckit is not a tool changer.
          there is this one
          https://jubilee3d.com/index.php?title=Main_Page
            sungod3k @fcwilt
            @fcwilt yes core xy all the way.
            200-300 ish i would spend now.
            undefined undefined 2 Replies Last reply 30 Jan 2021, 14:09 Reply Quote 0
              sungod3k @Veti
              @Veti alright thats now too bad.
                Veti @sungod3k
                @sungod3k said in Delta to Toolchanger -> Core X/Y or H-Bot framekit?:
                for that price toolchange is not an option.
                  fcwilt @sungod3k
                  I don't think that will be enough for a tool changing printer.
                    sungod3k
                    my 300 budget is for the frame only.
                      Veti
                      here is a brackdown of the jubilee
                      https://docs.google.com/spreadsheets/d/1pRzBQxVzL9c4T9b1RrKvSjlSwJJhJ7NcbSV6iJUv0X0/edit#gid=0
                      have a look
                      undefined 1 Reply Last reply 2 Feb 2021, 17:38 Reply Quote 0
                        sungod3k @Veti
                        @Veti
                        Im just looking at the railcore 2 vs the jubilee for they use linear rails. I like the jubilees way of having the carriages ride on top of the printer. that saves quite some z space.
                        i also figured i probably can use all my delta frame parts to make a core xy frame, i only need z screws.
                        you seem to know the jubilee a bit, what would be the reason for the x and y motors to have an extra pulley just before the motor? why not end the belt loop directly on the motors driver pulley?
                        undefined undefined 2 Replies Last reply 2 Feb 2021, 17:41 Reply Quote 0
                          fcwilt @sungod3k
                          It reduces the overall depth of the printer while still allowing a good range of belt tension adjustment.
                            theruttmeister @fcwilt
                            @fcwilt said in Delta to Toolchanger -> Core X/Y or H-Bot framekit?:
                            Isolate, substitute, verify.
                              dc42 administrators @sungod3k
                              Keep your delta intact, unless you have a another printer. You will need it to make parts for your new printer.
                              undefined 1 Reply Last reply 3 Feb 2021, 20:05 Reply Quote 0
                                sungod3k @dc42
                                @dc42 yes 🙂 already printing parts
                                RIP delta but now i cant wait to saw it in half^^
                                3 out of 15
