    Delta to Toolchanger -> Core X/Y or H-Bot framekit?
    core xy delta frame kit
    795
    • Vetiundefined
      Veti
      the seckit is not a tool changer.
      there is this one
      https://jubilee3d.com/index.php?title=Main_Page
      • sungod3kundefined
        sungod3k @fcwilt
        @fcwilt yes core xy all the way.
        200-300 ish i would spend now.
        http://www.42dimensions.de/
        https://printnewworlds.blogspot.com/
        Vetiundefined fcwiltundefined 2 Replies Last reply Reply Quote 0
        • sungod3kundefined
          sungod3k @Veti
          @Veti alright thats now too bad.
          • Vetiundefined
            Veti @sungod3k
            @sungod3k said in Delta to Toolchanger -> Core X/Y or H-Bot framekit?:
            for that price toolchange is not an option.
            • fcwiltundefined
              fcwilt @sungod3k
              I don't think that will be enough for a tool changing printer.
              • sungod3kundefined
                sungod3k
                my 300 budget is for the frame only.
                • Vetiundefined
                  Veti
                  here is a brackdown of the jubilee
                  https://docs.google.com/spreadsheets/d/1pRzBQxVzL9c4T9b1RrKvSjlSwJJhJ7NcbSV6iJUv0X0/edit#gid=0
                  have a look
                  sungod3kundefined 1 Reply Last reply Reply Quote 0
                  • sungod3kundefined
                    sungod3k @Veti
                    @Veti
                    Im just looking at the railcore 2 vs the jubilee for they use linear rails. I like the jubilees way of having the carriages ride on top of the printer. that saves quite some z space.
                    i also figured i probably can use all my delta frame parts to make a core xy frame, i only need z screws.
                    you seem to know the jubilee a bit, what would be the reason for the x and y motors to have an extra pulley just before the motor? why not end the belt loop directly on the motors driver pulley?
                    fcwiltundefined dc42undefined 2 Replies Last reply Reply Quote 0
                    • fcwiltundefined
                      fcwilt @sungod3k
                      It reduces the overall depth of the printer while still allowing a good range of belt tension adjustment.
                      • theruttmeisterundefined
                        theruttmeister @fcwilt
                        @fcwilt said in Delta to Toolchanger -> Core X/Y or H-Bot framekit?:
                        Just so you know a CoreXY is considered to be a superior design in relation to the H-Bot.
                        Isolate, substitute, verify.
                          dc42 administrators @sungod3k
                          Keep your delta intact, unless you have a another printer. You will need it to make parts for your new printer.
                          • sungod3kundefined
                            sungod3k @dc42
                            @dc42 yes 🙂 already printing parts
                            RIP delta but now i cant wait to saw it in half^^
