    Delta to Toolchanger -> Core X/Y or H-Bot framekit?
    core xy delta frame kit
    851
    • sungod3kundefined
      sungod3k
      i want to get into toolchanging but on a budget, and not with my delta. I have good parts but the frame i cant use.
      I looked a bit around for framekits. Openbuilds/Ratrig has some interesting frames in their library but those are expensive and https://seckit3dp.design/price/sk-go is of course nice, but also a bit pricy for the project.
      Buying a cheap printer for the parts like this is almost worth it, but I wonder if someone came across a decent framekit somewhere? (and then i can use my delta frame parts to stabilize it.)
      Cheers
      http://www.42dimensions.de/
      https://printnewworlds.blogspot.com/
      • Vetiundefined
        Veti
        the tronxy frame is terrible.
        if you just want a frame, you can buy extrusion from places like
        https://www.dold-mechatronik.de/Aluminum-profile-20x20-B-type-groove-6
        they even sell kits
        https://www.dold-mechatronik.de/BLV-MGN-Cube-Profile-groove-6
        sungod3kundefined 1 Reply Last reply Reply Quote 0
        • fcwiltundefined
          fcwilt
          What's you budget?
          Just so you know a CoreXY is considered to be a superior design in relation to the H-Bot.
          sungod3kundefined theruttmeisterundefined 2 Replies Last reply Reply Quote 0
          • Vetiundefined
            Veti
            the seckit is not a tool changer.
            there is this one
            https://jubilee3d.com/index.php?title=Main_Page
            • sungod3kundefined
              sungod3k @fcwilt
              @fcwilt yes core xy all the way.
              200-300 ish i would spend now.
              Vetiundefined fcwiltundefined 2 Replies Last reply Reply Quote 0
              • sungod3kundefined
                sungod3k @Veti
                @Veti alright thats now too bad.
                • Vetiundefined
                  Veti @sungod3k
                  @sungod3k said in Delta to Toolchanger -> Core X/Y or H-Bot framekit?:
                  for that price toolchange is not an option.
                  • fcwiltundefined
                    fcwilt @sungod3k
                    I don't think that will be enough for a tool changing printer.
                    • sungod3kundefined
                      sungod3k
                      my 300 budget is for the frame only.
                      • Vetiundefined
                        Veti
                        here is a brackdown of the jubilee
                        https://docs.google.com/spreadsheets/d/1pRzBQxVzL9c4T9b1RrKvSjlSwJJhJ7NcbSV6iJUv0X0/edit#gid=0
                        have a look
                        • sungod3kundefined
                          sungod3k @Veti
                          @Veti
                          Im just looking at the railcore 2 vs the jubilee for they use linear rails. I like the jubilees way of having the carriages ride on top of the printer. that saves quite some z space.
                          i also figured i probably can use all my delta frame parts to make a core xy frame, i only need z screws.
                          you seem to know the jubilee a bit, what would be the reason for the x and y motors to have an extra pulley just before the motor? why not end the belt loop directly on the motors driver pulley?
                          fcwiltundefined dc42undefined 2 Replies Last reply Reply Quote 0
                          • fcwiltundefined
                            fcwilt @sungod3k
                            It reduces the overall depth of the printer while still allowing a good range of belt tension adjustment.
                            • theruttmeisterundefined
                              theruttmeister @fcwilt
                              @fcwilt said in Delta to Toolchanger -> Core X/Y or H-Bot framekit?:
                              Isolate, substitute, verify.
                                dc42 administrators @sungod3k
                                Keep your delta intact, unless you have a another printer. You will need it to make parts for your new printer.
                                • sungod3kundefined
                                  sungod3k @dc42
                                  @dc42 yes 🙂 already printing parts
                                  RIP delta but now i cant wait to saw it in half^^
