    Duet 3 - Cooling fan configurations
    2.4k
    • kj3dundefined
      kj3d @Phaedrux
      @Phaedrux
      M112 produced an interesting result (sent via consel)
      kj3dundefined 1 Reply Last reply Reply Quote 0
      • kj3dundefined
        kj3d @kj3d
        M122 was much better!!
        KJ3D Delta
        Send code...
        Status
        Idle
        Mode: FFF
        Tool Position
        X
        0.0
        Y
        0.0
        Z
        399.04
        Extruder Drives
        Drive 0
        0.0
        Speeds
        Requested Speed
        0 mm/s
        Top Speed
        0 mm/s
        Sensors
        Vin
        23.9 V
        V12
        12.1 V
        MCU Temperature
        29.5 C
        Z-Probe
        0
        Tools
        Extra
        Control All
        Tool Heater Current Active Standby
        Tool 0
        T0 - Sunlu - White Heater 1
        off 13.1 C
        0
        0
        Bed Heater 0
        off 15.4 C
        0
        0
        Temperature Chart
        M122
        29/01/2021, 18:43:40 M122
        RepRapFirmware for Duet 3 MB6HC version 3.01-RC9 running on Duet 3 MB6HC v1.01 or later
        Board ID: 08DJM-956BA-NA3TJ-6JKD4-3S46M-KB8USUsed output buffers: 1 of 40 (12 max)
        Static ram: 154572
        Dynamic ram: 161276 of which 44 recycled
        Exception stack ram used: 440
        Never used ram: 76884
        Tasks: NETWORK(ready,236) ETHERNET(blocked,444) HEAT(blocked,1184) CanReceiv(suspended,3824) CanSender(suspended,1436) CanClock(blocked,1428) TMC(blocked,80) MAIN(running,4532) IDLE(ready,80)
        Owned mutexes:
        Last reset 00:00:54 ago, cause: software
        Last software reset at 2021-01-29 18:42, reason: User, spinning module GCodes, available RAM 77060 bytes (slot 2)
        Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0444a000 BFAR 0x00000000 SP 0xffffffff Task 0x4e49414d
        Error status: 0
        Free file entries: 10
        MCU temperature: min 28.2, current 29.4, max 29.5
        Supply voltage: min 23.8, current 23.9, max 24.1, under voltage events: 0, over voltage events: 0, power good: yes
        12V rail voltage: min 12.0, current 12.1, max 12.2, under voltage events: 0
        Driver 0: standstill, reads 5931, writes 19 timeouts 0, SG min/max 0/166
        Driver 1: standstill, reads 5932, writes 19 timeouts 0, SG min/max 0/160
        Driver 2: standstill, reads 5932, writes 19 timeouts 0, SG min/max 0/158
        Driver 3: standstill, reads 5938, writes 14 timeouts 0, SG min/max 0/0
        Driver 4: standstill, reads 5942, writes 11 timeouts 0, SG min/max 0/0
        Driver 5: standstill, reads 5942, writes 11 timeouts 0, SG min/max 0/0
        Date/time: 2021-01-29 18:43:40
        Slowest loop: 8.89ms; fastest: 0.14ms
        Hiccups: 0(0), FreeDm: 375, MinFreeDm: 369, MaxWait: 13123ms
        === MainDDARing ===
        Scheduled moves: 5, completed moves: 5, StepErrors: 0, LaErrors: 0, Underruns: 0, 0 CDDA state: -1
        === AuxDDARing ===
        Scheduled moves: 0, completed moves: 0, StepErrors: 0, LaErrors: 0, Underruns: 0, 0 CDDA state: -1
        Segments left: 0
        Movement lock held by null
        HTTP is idle in state(s) 0
        Telnet is idle in state(s) 0
        File is idle in state(s) 0
        USB is idle in state(s) 0
        Aux is idle in state(s) 0
        Trigger is idle in state(s) 0
        Queue is idle in state(s) 0
        LCD is idle in state(s) 0
        SBC is idle in state(s) 0
        Daemon is idle in state(s) 0
        Code queue is empty.
        === Network ===
        Slowest loop: 10.27ms; fastest: 0.03ms
        Responder states: HTTP(0) HTTP(0) HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0) Telnet(0)
        HTTP sessions: 1 of 8
        • Ethernet -
          State: active
          Error counts: 0 0 0 0 0
          === CAN ===
          Messages sent 219, longest wait 0ms for type 0
          === Linux interface ===
          State: 0, failed transfers: 0
          Last transfer: 54411ms ago
          RX/TX seq numbers: 0/1
          SPI underruns 0, overruns 0
          Number of disconnects: 0
          Buffer RX/TX: 0/0-0
          29/01/2021, 18:42:49 Connection established
          29/01/2021, 18:42:49 Connection interrupted, attempting to reconnect...
          29/01/2021, 18:40:57 Emergency stop, attemping to reconnect...
          Phaedrux Moderator @kj3d
          @kj3d said in Duet 3 - Cooling fan configurations:
          Let's update your firmware.
          If you still have access to DWC. Upload these zip files, one at a time. Don't extract them. Reboot after each. Use M115 to verify the firmware has been applied.
          https://github.com/Duet3D/RepRapFirmware/releases/download/3.0/Duet2and3Firmware-3.0.zip
          https://github.com/Duet3D/RepRapFirmware/releases/download/3.2/Duet2and3Firmware-3.2.zip
          That will get your firmware and DWC up to date.
          • kj3dundefined
            kj3d @Phaedrux
            @Phaedrux said in Duet 3 - Cooling fan configurations:
            M98 P"config.g"?
            • kj3dundefined
              kj3d @Phaedrux
              @Phaedrux
              Please confirm how the files are uploaded (DWC is connected)
                Go to the system tab and use the upload file button.
                • kj3dundefined
                  kj3d @Phaedrux
                  @Phaedrux
                  Thanks
                  • kj3dundefined
                    kj3d @kj3d
                    Updates done (very impressed at how easy that was!!)
                    • kj3dundefined
                      kj3d
                      Will test the revised Firmware in the morning and let you know how it is
                      Thanks for everyone's help today.
                      • kj3dundefined
                        kj3d
                        An Update
                        I am pleased with the results this morning. The firmware update has sorted out the issues (except in DWC with the two fan option for display) The part cooling fan and the hotend fan now behave exactly as they should when a print is running.
                        I only have one remaining question and that is with regards the RRF tool that I initially used. That did not seem to compile the firmware correctly, perhaps that was down to me extracting the contents of the zip file it created onto the SD card. I am certain that I had ticked the box to run the latest firmware option, yet it clearly did not. The update method suggested by @Phaedrux was much better.
                        Running M112 (instead of M122) blew the heatbed fuse, so I shall be more attentive in future!!
                        I am so pleased with the print results from the board that I have just ordered another one to update our corexy printer.
                        Thanks to everyone who offered advice on the forum - it helped a great deal.
                        • Vetiundefined
                          Veti
                          why would a stop blow the fuse?
                          • kj3dundefined
                            kj3d
                            I don't understand that either. Using the old firmware created an alarm situation shortly before the fuse blew saying that voltages had been exceeded. The power supply is fine so hard to understand.
                              It includes the firmware bin file, and that's all. If you upload the complete zip file it produces to the system tab it will extract it for you and then prompt to update. However at the moment it only includes the firmware bin file, but not any of the required IAP files, so if those are missing the update would fail.
                              If you extracted the zip file from the config tool and manually copied it onto the SD card it won't do anything until you tell it to update the firmware with M997.
                              • kj3dundefined
                                kj3d
                                Thanks for that explanation - that makes a lot of sense.
                                Regards - KJ3d
