    Duet 3 - Cooling fan configurations
    2.4k
      A Former User @kj3d
      @kj3d
      If you happen to have a permanent marker or a sticker I like to put that on the fan, that helps to be able to vaguely judge the running speed beside wetting a finger and putting it in front of it
      • kj3dundefined
        kj3d @Phaedrux
        @Phaedrux
        config.g:
        ; generated by RepRapFirmware Configuration Tool v3.2.2 on Wed Jan 27 2021 12:22:57 GMT+0000 (Greenwich Mean Time)
        M550 P"KJ3D Delta" ; set printer name
        M665 R227 L440 B185 H405 ; Set delta radius, diagonal rod length, printable radius and homed height
        M666 X0 Y0 Z0 ; put your endstop adjustments here, or let auto calibration find them
        M551 P"freddy5363" ; set password
        M586 P0 S1 ; enable HTTP
        M586 P1 S0 ; disable FTP
        M586 P2 S0 ; disable Telnet
        M584 X0.0 Y0.1 Z0.2 E0.3 ; set drive mapping
        M92 X80.00 Y80.00 Z80.00 E335.00 ; set steps per mm
        M566 X1200.00 Y1200.00 Z1200.00 E1200.00 ; set maximum instantaneous speed changes (mm/min)
        M203 X18000.00 Y18000.00 Z18000.00 E1200.00 ; set maximum speeds (mm/min)
        M201 X1000.00 Y1000.00 Z1000.00 E1000.00 ; set accelerations (mm/s^2)
        M906 X1000 Y1000 Z1000 E800 I30 ; set motor currents (mA) and motor idle factor in per cent
        M84 S30 ; Set idle timeout
        M208 Z0 S1 ; set minimum Z
        M574 X2 S1 P"io1.in" ; configure active-high endstop for high end on X via pin io1.in
        M574 Y2 S1 P"io2.in" ; configure active-high endstop for high end on Y via pin io2.in
        M574 Z2 S1 P"io3.in" ; configure active-high endstop for high end on Z via pin io3.in
        M558 P5 R0.4 C"io4.in+io4.out" H5 F1200 T6000 ; set Z probe type to effector and the dive height + speeds
        ;M558 H30 ;*** Remove this line after delta calibration has been done and new delta parameters have been saved
        G31 P500 X0 Y0 Z-0.232 ; set Z probe trigger value, offset and trigger height
        M557 R185 S20 ; define mesh grid
        M308 S0 P"temp0" Y"thermistor" T100000 B4138 ; configure sensor 0 as thermistor on pin temp0
        M308 S1 P"temp1" Y"thermistor" T100000 B4138 ; configure sensor 1 as thermistor on pin temp1
        M950 F0 C"out4" Q500 ; create fan 0 on pin out4 and set its frequency
        M950 F1 C"out5" Q500 ; create fan 1 on pin out5 and set its frequency
        M106 P1 S1 H1 T35 ; set fan 1 value. Thermostatic control is turned on
        • kj3dundefined
          kj3d @Phaedrux
          @Phaedrux
          M112 produced an interesting result (sent via consel)
          kj3dundefined 1 Reply Last reply Reply Quote 0
          • kj3dundefined
            kj3d @kj3d
            M122 was much better!!
            KJ3D Delta
            Send code...
            Status
            Idle
            Mode: FFF
            Tool Position
            X
            0.0
            Y
            0.0
            Z
            399.04
            Extruder Drives
            Drive 0
            0.0
            Speeds
            Requested Speed
            0 mm/s
            Top Speed
            0 mm/s
            Sensors
            Vin
            23.9 V
            V12
            12.1 V
            MCU Temperature
            29.5 C
            Z-Probe
            0
            Tools
            Extra
            Control All
            Tool Heater Current Active Standby
            Tool 0
            T0 - Sunlu - White Heater 1
            off 13.1 C
            0
            0
            Bed Heater 0
            off 15.4 C
            0
            0
            Temperature Chart
            M122
            29/01/2021, 18:43:40 M122
            RepRapFirmware for Duet 3 MB6HC version 3.01-RC9 running on Duet 3 MB6HC v1.01 or later
            Board ID: 08DJM-956BA-NA3TJ-6JKD4-3S46M-KB8USUsed output buffers: 1 of 40 (12 max)
            Static ram: 154572
            Dynamic ram: 161276 of which 44 recycled
            Exception stack ram used: 440
            Never used ram: 76884
            Tasks: NETWORK(ready,236) ETHERNET(blocked,444) HEAT(blocked,1184) CanReceiv(suspended,3824) CanSender(suspended,1436) CanClock(blocked,1428) TMC(blocked,80) MAIN(running,4532) IDLE(ready,80)
            Owned mutexes:
            Last reset 00:00:54 ago, cause: software
            Last software reset at 2021-01-29 18:42, reason: User, spinning module GCodes, available RAM 77060 bytes (slot 2)
            Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0444a000 BFAR 0x00000000 SP 0xffffffff Task 0x4e49414d
            Error status: 0
            Free file entries: 10
            MCU temperature: min 28.2, current 29.4, max 29.5
            Supply voltage: min 23.8, current 23.9, max 24.1, under voltage events: 0, over voltage events: 0, power good: yes
            12V rail voltage: min 12.0, current 12.1, max 12.2, under voltage events: 0
            Driver 0: standstill, reads 5931, writes 19 timeouts 0, SG min/max 0/166
            Driver 1: standstill, reads 5932, writes 19 timeouts 0, SG min/max 0/160
            Driver 2: standstill, reads 5932, writes 19 timeouts 0, SG min/max 0/158
            Driver 3: standstill, reads 5938, writes 14 timeouts 0, SG min/max 0/0
            Driver 4: standstill, reads 5942, writes 11 timeouts 0, SG min/max 0/0
            Driver 5: standstill, reads 5942, writes 11 timeouts 0, SG min/max 0/0
            Date/time: 2021-01-29 18:43:40
            Slowest loop: 8.89ms; fastest: 0.14ms
            Hiccups: 0(0), FreeDm: 375, MinFreeDm: 369, MaxWait: 13123ms
            === MainDDARing ===
            Scheduled moves: 5, completed moves: 5, StepErrors: 0, LaErrors: 0, Underruns: 0, 0 CDDA state: -1
            === AuxDDARing ===
            Scheduled moves: 0, completed moves: 0, StepErrors: 0, LaErrors: 0, Underruns: 0, 0 CDDA state: -1
            Segments left: 0
            Movement lock held by null
            HTTP is idle in state(s) 0
            Telnet is idle in state(s) 0
            File is idle in state(s) 0
            USB is idle in state(s) 0
            Aux is idle in state(s) 0
            Trigger is idle in state(s) 0
            Queue is idle in state(s) 0
            LCD is idle in state(s) 0
            SBC is idle in state(s) 0
            Daemon is idle in state(s) 0
            Code queue is empty.
            === Network ===
            Slowest loop: 10.27ms; fastest: 0.03ms
            Responder states: HTTP(0) HTTP(0) HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0) Telnet(0)
            HTTP sessions: 1 of 8
            • Ethernet -
              State: active
              Error counts: 0 0 0 0 0
              === CAN ===
              Messages sent 219, longest wait 0ms for type 0
              === Linux interface ===
              State: 0, failed transfers: 0
              Last transfer: 54411ms ago
              RX/TX seq numbers: 0/1
              SPI underruns 0, overruns 0
              Number of disconnects: 0
              Buffer RX/TX: 0/0-0
              29/01/2021, 18:42:49 Connection established
              29/01/2021, 18:42:49 Connection interrupted, attempting to reconnect...
              29/01/2021, 18:40:57 Emergency stop, attemping to reconnect...
              Phaedrux Moderator @kj3d
              @kj3d said in Duet 3 - Cooling fan configurations:
              Let's update your firmware.
              If you still have access to DWC. Upload these zip files, one at a time. Don't extract them. Reboot after each. Use M115 to verify the firmware has been applied.
              https://github.com/Duet3D/RepRapFirmware/releases/download/3.0/Duet2and3Firmware-3.0.zip
              https://github.com/Duet3D/RepRapFirmware/releases/download/3.2/Duet2and3Firmware-3.2.zip
              That will get your firmware and DWC up to date.
              • kj3dundefined
                kj3d @Phaedrux
                @Phaedrux said in Duet 3 - Cooling fan configurations:
                M98 P"config.g"?
                • kj3dundefined
                  kj3d @Phaedrux
                  @Phaedrux
                  Please confirm how the files are uploaded (DWC is connected)
                    Go to the system tab and use the upload file button.
                    • kj3dundefined
                      kj3d @Phaedrux
                      @Phaedrux
                      Thanks
                      • kj3dundefined
                        kj3d @kj3d
                        Updates done (very impressed at how easy that was!!)
                        • kj3dundefined
                          kj3d
                          Will test the revised Firmware in the morning and let you know how it is
                          Thanks for everyone's help today.
                          • kj3dundefined
                            kj3d
                            An Update
                            I am pleased with the results this morning. The firmware update has sorted out the issues (except in DWC with the two fan option for display) The part cooling fan and the hotend fan now behave exactly as they should when a print is running.
                            I only have one remaining question and that is with regards the RRF tool that I initially used. That did not seem to compile the firmware correctly, perhaps that was down to me extracting the contents of the zip file it created onto the SD card. I am certain that I had ticked the box to run the latest firmware option, yet it clearly did not. The update method suggested by @Phaedrux was much better.
                            Running M112 (instead of M122) blew the heatbed fuse, so I shall be more attentive in future!!
                            I am so pleased with the print results from the board that I have just ordered another one to update our corexy printer.
                            Thanks to everyone who offered advice on the forum - it helped a great deal.
                            • Vetiundefined
                              Veti
                              why would a stop blow the fuse?
                              • kj3dundefined
                                kj3d
                                I don't understand that either. Using the old firmware created an alarm situation shortly before the fuse blew saying that voltages had been exceeded. The power supply is fine so hard to understand.
                                  It includes the firmware bin file, and that's all. If you upload the complete zip file it produces to the system tab it will extract it for you and then prompt to update. However at the moment it only includes the firmware bin file, but not any of the required IAP files, so if those are missing the update would fail.
                                  If you extracted the zip file from the config tool and manually copied it onto the SD card it won't do anything until you tell it to update the firmware with M997.
                                  • kj3dundefined
                                    kj3d
                                    Thanks for that explanation - that makes a lot of sense.
                                    Regards - KJ3d
