    DuetLapse3
    Third-party software
    20
    296
    30.1k
    • PCRundefined
      PCR
      @stuartofmt only for history
      pi@duet3:~ $ ./1610998509032-sbctest.py -duet 192.168.140.126
      192.168.140.126 Determine API Version
      192.168.140.126 Testing: rr_model at address 192.168.140.126
      192.168.140.126 http://192.168.140.126/rr_model?key=boards
      192.168.140.126
      192.168.140.126 Testing: /machine/system at address 192.168.140.126
      192.168.140.126 http://192.168.140.126/machine/status
      192.168.140.126
      192.168.140.126 API model is: SBC   Version is: 3
      192.168.140.126 Status is :processing
      192.168.140.126 URL was: http://192.168.140.126/machine/code
      192.168.140.126 Send Gcode result: None
      192.168.140.126 Layer: 3
      192.168.140.126 Get Position X and Y: 96.787 119.675
      192.168.140.126 URL was: http://192.168.140.126/machine/code/
      no DWC message either
      • PCRundefined
        PCR
        @stuartofmt I changed this line
        logger.info('Send Gcode result: '+str(sendDuetGcode2(apiModel, 'M117 Test of SBC')))
        to
        logger.info('Send Gcode result: '+str(sendDuetGcode2(apiModel, 'M117 "Test of SBC"')))
        aand
        stuartofmtundefined 1 Reply Last reply Reply Quote 1
        • stuartofmtundefined
          stuartofmt @PCR
          @PCR said in DuetLapse3:
          aand
          ![a02d93f9-98a1-4404-bb9a-c67b729cac68-grafik.png](/assets/uploads/files/1611049373109-a02d93f9-98a1-4404-bb9a-c67b729cac68-grafik.png)
          Brilliant!.
          Last night (in my slumbers) I wonderer if the data=command in the push code needed to be encoded because of the spaces in M117 etc. In the various example code it seems only single gcodes have been passed and likely why those examples worked. Dueui was a bit different but that was javascript and I'm even more unfamiliar with that than I am with Python .....
          DuetLapse3 in its current form only needs to send single gcodes. So - as it stands we have a fully working DuetLapse3. The choice of M117 ... for testing turned out to be both good and bad.
          What I will do today is try and crack the encoding needs so that it does not break in the future. I've set up a simple webserver and can debug the incoming and see what happens. I have not yet updated the github but either way will do so later today
          @jay_s_uk and @PCR
          Thanks for being the remote testers.
            stuartofmt
            Version 3.0.4 released in github. All functionality should now work with SBC.
            The issues with SBC gcode appear to be due to differences in the way DWS was handling the test case.
              stuartofmt
              Version 3.1.1 released on github. This is pretty significant - the details are documented but here us a summary.
              ###Version 3.1.0###
              [1] Added support for Windows
              [2] Added automatic detection of operating system (Linux or Windows)
              [3] Added integrated http listener for basic browser based control
              [4] Changed file naming convention to make filenames unique if multiple instances of DuetLapse3 are running.
              An Integrated http listener is available for basic control of DuetLapse3 (not the attached printer).
              The http listener is activated by specifying a port number using the -port option.
              In conjunction with the -host option it provides the following functionality from a browser (or curl or other method of performing a http get).
              http://<ip-address><port>/?command=<valid command>
              *Valid commands are:
              start - Starts DuetLapse3 recording if the -stopcmd option was used or after a stop command
              standby - Stops (but does not terminate) DuetLapse3 recording and discards any images capture. Waits for a start command.
              status - returns brief information about the running state of DuetLapse3
              pause - causes DuetLapse3 to temporarily stop capturing images
              continue - causes DuetLapse3 to resume capturing images
              snapshot - causes DuetLapse3 to make an interim video and then continue
              restart - causes DuetLapse3 to stop capturing images, create a video and then restart with a new capture set
              terminate - causes DuetLapse3 to stop capturing images, create a video and then terminate the program. This is the same as CTRL+C or SIGINT.
              Note that depending on your system - it may take several minutes for the http listener to completely shutdown following a terminate request.*
              Note that the http listener will stop responding if DuetLapse3 is run from a command console that is then closed. This will happen even if started in background. To avoid this - use nohup (linux).
              Windows does not have an (easy) equivalent to nohup so you would need to leave the command console open. An alternative if you are on Win10 is to use Windows Subsystem for Linux (WSL) and run DuetLapse as a linux application inside WSL.
              If running in nohup mode CTRL+C cannot be used so you need to send the terminate command (?command=terminate) from the http listener
              Made an accommodation (in 3.1.1) for ffmpeg < 4.2 by using a simpler syntax if -extratime is not used.
                stuartofmt
                @fractalengineer
                Take a look at the post above. It does not provide a plugin but the http listener makes it easier to control remotely. It looks like the plugins require javascript and frankly - that's not something I want to get into.
                Someone else (with the skills) could create a simple plugin that calls appropriate urls and provide control that way.
                I will create a helper script that proved a separate http listener to remotely start DuetLapse3 - but that's a few days away.
                fractalengineerundefined 1 Reply Last reply Reply Quote 0
                • fractalengineerundefined
                  fractalengineer @stuartofmt
                  @stuartofmt Thanks Stuart; I did try installing the 3.04 earlier this weekend following each step but got stuck at ffmpeg install; doesn't return anything when checking version.
                  I guess I'm still way to beginner at linux terminal. I'll try again with the new version
                  Railcore II ZL
                  stuartofmtundefined 1 Reply Last reply Reply Quote 0
                    stuartofmt @fractalengineer
                    @fractalengineer said in DuetLapse3:
                    Don't worry - we will get you going.
                    I'm assuming you are using a raspberry pi ?
                    The latest version should work with the version of ffmpeg that installs by default with the pi. The only downside is not being able to use the -extratime option.
                    I'd recommend you reinstall the default ffmpeg and take it from there.
                    It sounds like you tried to follow my instructions and the installation of the latest ffmpeg failed somehow? If that is correct then lets try to clean it up and get you back to the default. Try the following in order (I just did this on my pi) 🙂
                    cd ~
                    sudo apt remove ffmpeg
                    I'm guessing this will say ffmpeg is not installed.
                    Next:
                    sudo find / -name ffmpeg
                    This will may give some output for example:)
                    find: ‘/run/user/1000/gvfs’: Permission denied
                    /usr/local/bin/ffmpeg
                    /usr/local/share/ffmpeg
                    /usr/local/share/doc/ffmpeg
                    for each of the files / directories - we'll first delete everything for EXAMPLE
                    sudo rm -rf /usr/local/bin/ffmpeg
                    sudo rm -rf /usr/local/share/ffmpeg
                    sudo rm -rf /usr/local/share/doc/ffmpeg
                    Next make sure everything is at the latest release level
                    sudo apt update
                    sudo apt upgrade
                    I just did this on my pi - it was quite the upgrade and took quite a while so be patient.
                    Finally, install the standard ffmpeg
                    sudo apt install ffmpeg
                    after that and assuming no errors
                    ffmpeg -version
                    should return a bunch of information.
                    Then reboot for luck 🙂
                      @stuartofmt aww mate you're a saint; didn't expect such a detailed help.
                      I went through those steps and when doing the find it didn't return anything; so I guess it didn't build properly in the first place (I used the cmake last time)
                      Seems like everything is installed now; just got to figure out the usage exactly
                      Thanks!
                      Railcore II ZL
                      • SIamundefined
                        SIam
                        @stuartofmt I have a Problem with layer capturing if i use this nothing will be captured i use the following command to start it
                        python3 DuetLapse3.py -port 8181 -duet 192.168.188.36 -detect layer -camera1 stream -weburl1 http://192.168.188.34:8081/
                        This result in
                        192.168.188.36 ################### Options selected for this run #####################
                        192.168.188.36 #Environment Settings:
                        192.168.188.36 # printer         = 192.168.188.36
                        192.168.188.36 # basedir         = /home/pi/DuetLapse
                        192.168.188.36 # poll            = 5
                        192.168.188.36 # logtype         = both
                        192.168.188.36 # verbose         = False
                        192.168.188.36 # os              = Linux
                        192.168.188.36 # host            = 0.0.0.0
                        192.168.188.36 # port            = 8181
                        192.168.188.36 # pid            = 7902
                        192.168.188.36 #Execution Setings:
                        192.168.188.36 # dontwait        = False
                        192.168.188.36 # seconds         = 0
                        192.168.188.36 # detect          = layer
                        192.168.188.36 # pause           = no
                        192.168.188.36 # standby     = False
                        192.168.188.36 #Camera1 Settings:
                        192.168.188.36 # camera1         = stream
                        192.168.188.36 # weburl1         = http://192.168.188.34:8081/
                        192.168.188.36 # Video Settings:
                        192.168.188.36 # extratime   =     0
                        192.168.188.36 ###################################################################
                        192.168.188.36
                        192.168.188.36
                        192.168.188.36
                        192.168.188.36 Connected to printer at 192.168.188.36 using version 3.2 and API access using rr_model
                        192.168.188.36
                        192.168.188.36
                        192.168.188.36 ***** Started http listener *****
                        192.168.188.36
                        192.168.188.36
                        192.168.188.36 Will start capturing images on first layer change
                        192.168.188.36
                        192.168.188.36
                        192.168.188.36 Video will be created when printing ends.
                        192.168.188.36 Or, press Ctrl+C one time to stop capture and create video.
                        192.168.188.36
                        192.168.188.36 ****** Printer State changed to waiting *****
                        192.168.188.36 ****** Printer State changed to printing *****
                        192.168.188.36 ****** Printer State changed to completed *****
                        192.168.188.36 End of Print Job - Post Processing
                        192.168.188.36 ++++++ Entering restart state ++++++
                        192.168.188.36
                        192.168.188.36 Camera1: Cannot create video with only 0 frames
                        If i use the Time capturing option it works as it should
                        /DuetLapse $ python3 DuetLapse3.py -port 8181 -duet 192.168.188.36 -seconds 20 -detect none -camera1 stream -weburl1 http://192.168.188.34:8081/
                        192.168.188.36
                        192.168.188.36 ****** Printer State changed to startnow *****
                        192.168.188.36 Camera1: capturing frame 0 at layer 72 after 20.0 seconds
                        192.168.188.36 Camera1: capturing frame 1 at layer 73 after 20.0 seconds
                        192.168.188.36 Camera1: capturing frame 2 at layer 74 after 20.0 seconds
                        192.168.188.36 Camera1: capturing frame 3 at layer 75 after 20.0 seconds
                        192.168.188.36 Camera1: capturing frame 4 at layer 76 after 20.0 seconds
                        192.168.188.36 Camera1: capturing frame 5 at layer 78 after 20.0 seconds
                        192.168.188.36 Camera1: capturing frame 6 at layer 79 after 20.0 seconds
                        192.168.188.36 Camera1: capturing frame 7 at layer 80 after 20.0 seconds
                        ^C192.168.188.36 !!!!!! Stopped by SIGINT - Post Processing !!!!!!
                        192.168.188.36
                        192.168.188.36 Camera1: Cannot create video with only 8 frames
                        192.168.188.36 Waiting for http listener to shutdown.
                        192.168.188.36 Program Terminated
                        The printer is on the latest stable:
                        RepRapFirmware for Duet 2 WiFi/Ethernet version 3.2 running on Duet WiFi 1.02 or later + DueX5
                        Can you please tell me what i did wrong?
                        Hypercube-Evolution-Hybrid, Piezo Orion, Orbiter
                        RepRapFirmware for Duet 2 WiFi/Ethernet 3.4.0beta4 (2021-09-27 11:30:36)
                        Duet WiFi Server: 1.26
                        Duet Web Control 3.4.0beta4 (2021-09-27)
                        • SIamundefined
                          SIam
                          my knowledge of python is not really available but when i look at this code:
                           #update the layer counter
                              global zo1, zo2
                              zn = getDuetLayer(apiModel)
                              if (cameraname == 'Camera1'):
                                  zo1 = zn
                              else:
                                  zo2 = zn
                              if ('layer' in detect):
                                  if ((not zn == zo1 and cameraname == 'Camera1') or (not zn == zo2 and cameraname == 'Camera2')):
                                      # Layer changed, take a picture.
                                      checkForPause()
                                      logger.info(cameraname+': capturing frame '+str(frame)+' at layer '+str(zn)+' after layer change')
                                      onePhoto(cameraname, camera, weburl, camparam)
                              elif ('pause' in detect and printerState == 'paused'):
                                      checkForPause()
                                      logger.info(cameraname+': capturing frame '+str(frame)+' at layer '+str(zn)+' at pause in print gcode')
                          So this script can't access to the take picture routine because zo1 and zn is always the same
                          I have now altered the code to:
                              global zo1, zo2
                             # if (cameraname == 'Camera1'):
                             #     zo1 = zn
                             # else:
                             #     zo2 = zn
                                      checkForPause()
                                      checkForPause()
                             # global zo1, zo2
                             # zn = getDuetLayer(apiModel)
                                  zo1 = zn
                              else:
                                  zo2 = zn
                          And for now it works (but i don't know if i have now added a new failure)
                            stuartofmt @SIam
                            @SIam
                            Hi Sam - sorry you are having problems. The changes you made to the code will most definitely cause problems 😞 That piece of code keeps track of layer changes.
                            Having said that it was my error ...
                            But first - I see you have started DuetLapse with:
                            You have BOTH your web camera (-weburl1) AND DuetLapse3 on the same port number. This is a no-no. They need to be different. In the next release (I am testing now) - I check to see if the port is already in use and if it is, prevent DuetLapse3 from starting. So please change the -port so that it is on a different and unused port number.
                            Second - on the layer change - yikes! This is definitely wrong and thanks for pointing it out. I must have copy/pasted that portion into the wrong place when I did some 'tidy up' . I will fix that today. If you want to fix it yourself - move the assignment so that it looks like this:
                                global zo1, zo2
                                        checkForPause()
                                elif ('pause' in detect and duetStatus == 'paused'):
                                        checkForPause()
                                    zo1 = zn
                                else:
                                    zo2 = zn
                            In any case, the change to -seconds 20 -detect none is working as it should but that is bypassing the layer check so the change you made has no effect.
                            • SIamundefined
                              SIam
                              Thank you for your assistance!
                              My start command is correct duetlapse runs on 8181 and the cam on 8081 😉
                              to your code change the only change i can see is that you have removed the comments is this right ?
                                stuartofmt @SIam
                                @SIam said in DuetLapse3:
                                Sorry - I misread the port numbers , you are of course correct.
                                As to the question on the code change - no.
                                This portion of code
                                        zo1 = zn
                                    else:
                                        zo2 = zn
                                needs to be after this portion (not before - which was the problem )
                                            checkForPause()
                                            checkForPause()
                                NOTE THAT THE INDENTING HAS TO BE EXACTLY THE SAME - Python is very particular in that regard - so be careful as you edit 🙂
                                • SIamundefined
                                  SIam
                                  ok! Thank you for your work i love it 😄
                                  • SIamundefined
                                    SIam
                                    is it possible to catch those errors in python ?
                                    Traceback (most recent call last):
                                      File "/usr/lib/python3/dist-packages/urllib3/connectionpool.py", line 600, in urlopen
                                        chunked=chunked)
                                      File "/usr/lib/python3/dist-packages/urllib3/connectionpool.py", line 384, in _make_request
                                        six.raise_from(e, None)
                                      File "<string>", line 3, in raise_from
                                      File "/usr/lib/python3/dist-packages/urllib3/connectionpool.py", line 380, in _make_request
                                        httplib_response = conn.getresponse()
                                      File "/usr/lib/python3.7/http/client.py", line 1336, in getresponse
                                        response.begin()
                                      File "/usr/lib/python3.7/http/client.py", line 306, in begin
                                        version, status, reason = self._read_status()
                                      File "/usr/lib/python3.7/http/client.py", line 267, in _read_status
                                        line = str(self.fp.readline(_MAXLINE + 1), "iso-8859-1")
                                      File "/usr/lib/python3.7/socket.py", line 589, in readinto
                                        return self._sock.recv_into(b)
                                    ConnectionResetError: [Errno 104] Connection reset by peer
                                    During handling of the above exception, another exception occurred:
                                      File "/usr/lib/python3/dist-packages/requests/adapters.py", line 449, in send
                                        timeout=timeout
                                      File "/usr/lib/python3/dist-packages/urllib3/connectionpool.py", line 638, in urlopen
                                        _stacktrace=sys.exc_info()[2])
                                      File "/usr/lib/python3/dist-packages/urllib3/util/retry.py", line 367, in increment
                                        raise six.reraise(type(error), error, _stacktrace)
                                      File "/usr/lib/python3/dist-packages/six.py", line 692, in reraise
                                        raise value.with_traceback(tb)
                                        chunked=chunked)
                                        response.begin()
                                    urllib3.exceptions.ProtocolError: ('Connection aborted.', ConnectionResetError(104, 'Connection reset by peer'))
                                      File "/home/pi/DuetLapse/DuetLapse3.py", line 964, in <module>
                                        duetStatus=getDuetStatus(apiModel)
                                      File "/home/pi/DuetLapse/DuetLapse3.py", line 694, in getDuetStatus
                                        r = requests.get(URL, timeout=120)  #Long timeout to handle restart of Duet
                                      File "/usr/lib/python3/dist-packages/requests/api.py", line 75, in get
                                        return request('get', url, params=params, **kwargs)
                                      File "/usr/lib/python3/dist-packages/requests/api.py", line 60, in request
                                        return session.request(method=method, url=url, **kwargs)
                                      File "/usr/lib/python3/dist-packages/requests/sessions.py", line 533, in request
                                        resp = self.send(prep, **send_kwargs)
                                      File "/usr/lib/python3/dist-packages/requests/sessions.py", line 646, in send
                                        r = adapter.send(request, **kwargs)
                                      File "/usr/lib/python3/dist-packages/requests/adapters.py", line 498, in send
                                        raise ConnectionError(err, request=request)
                                    requests.exceptions.ConnectionError: ('Connection aborted.', ConnectionResetError(104, 'Connection reset by peer'))
                                    ^C
                                    pi@raspberrypi:~/DuetLapse $ ./start-lapse stop
                                    192.168.188.36
                                    pi@raspberrypi:~/DuetLapse $ 192.168.188.36 Camera1: now making 29 frames into a video
                                    192.168.188.36 Video processing complete for Camera1
                                    192.168.188.36 Video is in file "/home/pi/DuetLapse/192-168-188-36/Camera17144-Mon-11-25.mp4"
                                    Exception ignored in: <module 'threading' from '/usr/lib/python3.7/threading.py'>
                                      File "/usr/lib/python3.7/threading.py", line 1281, in _shutdown
                                        t.join()
                                      File "/usr/lib/python3.7/threading.py", line 1032, in join
                                        self._wait_for_tstate_lock()
                                      File "/usr/lib/python3.7/threading.py", line 1048, in _wait_for_tstate_lock
                                        elif lock.acquire(block, timeout):
                                      File "/home/pi/DuetLapse/DuetLapse3.py", line 467, in quit_gracefully
                                        terminate()
                                      File "/home/pi/DuetLapse/DuetLapse3.py", line 798, in terminate
                                        sys.exit(0)
                                    SystemExit: 0
                                      stuartofmt
                                      Version 3.2.0 has been release.
                                      This is a significant upgrade and other than bug fixes I expect it will be stable for a while.
                                      I added a helper program startDuetLapse3 to enable remote start/stop of DuetLapse3 instances using a browser or similar (e.g. curl). This provides a lot of flexibility in that you can have the helper program set to run at boot time and then remotely start / stop DuetLapse3 instances when you need them without having to use additional scripts or SSH into the machine etc.
                                      ###Version 3.2.0###
                                      [1] Adds the ability to work with startDuetLapse3. See the description here:
                                      https://github.com/stuartofmt/DuetLapse3/blob/main/startDuetLapse3.md
                                      In summary startDuetLapse3 provides the ability to remotely start / stop DuetLapse3.
                                      [2] Changed the shutdown method to reduce low level 'noise' messages.
                                      [3] Restructured to provide better efficiency. Typically less than 1% CPU when idle.
                                      [4] Fixed a bug that was introduced in the prior version (not detecting layer changes)
                                      [5] Made further improvements to the handling of pauses.
                                      There are some edge cases where a printer can get stuck in a paused state.
                                      The documentation has been updated. See especially -dontwait
                                      [6]Added checks to prevent startup with ports that are already in use.
                                      I have done a lot of testing but as usual - something may have slipped through the cracks .....
                                      JohnOCFIIundefined 1 Reply Last reply Reply Quote 0
                                        stuartofmt @SIam
                                        Yes - it was one of the things that annoyed me too! one of those things that a 1000 google 'fixes' (all different) did not fix 😞 I found a way though 🙂
                                        Its part of the 3.2.0 release.
                                        Hope I got them all 🙂
                                        • JohnOCFIIundefined
                                          JohnOCFII @stuartofmt
                                          @stuartofmt I'm looking forward to testing this and eliminating my auto-start setup. I find my older setup is re-starting multiple times a day, and only noticed it doing longer prints, when the timelapse was only for the last period of time. Kind of sad after a 10 hour print yielded a timelapse of the last 4 minutes...
                                            stuartofmt @JohnOCFII
                                            @JohnOCFII said in DuetLapse3:
                                            ..... Kind of sad after a 10 hour print yielded a timelapse of the last 4 minutes...
                                            I hear ya! FWIW - I have "soak tested" this running overnight and into the next day with a small number of seconds (smaller than practical). 10K+ images and it was stable but I'm sure you can find something for me to fix 🙂
                                            Note that it also runs on WIN10 (and maybe earlier ??) as well as WSL (which I like a lot). So if the Pi becomes a limitation there are other options.
                                            Let me know how it works out.
