Update CR-10+Duet wifi from 2.05.1 to 3.0 firmware
i select on my PC that wifi connection... only after i have that wifi signal on my PC, o open the browser and try to connect to the IP. But never opens the DWC panel
@Phaedrux said in Update CR-10+Duet wifi from 2.05.1 to 3.0 firmware:
@Hélder-Rocha said in Update CR-10+Duet wifi from 2.05.1 to 3.0 firmware:
im confuse.
Agreed.
M552 S2 turns the Duet into it's own WIFI network.
You need to connect to that network on your PC or phone or whatever device that has wifi. From that device you will then be able to reach 192.168.1.1 for the DWC.
thats what i am doing
Ok, when you try to reach the IP of the DWC, what exactly does the error message say?
When you send M552 by itself at this point, what does it say?
Can you post M122 from this state as well please? -
@Phaedrux the message i get is "Enable to connect" .
im using a different PC to talk t you. Difficult to post anything. Im going to send the M122 now
@Hélder-Rocha ok...just change to the same PC with YAT app. How do i paste the message from yat?
=== Diagnostics ===<LF>RepRapFirmware for Duet 2 WiFi/Ethernet version 3.2 running on Duet WiFi 1.02 or later<LF>Board ID: 08DGM-917DA-G4MSD-6J1F2-3S06L-T9VVB<LF>Used output buffers: 1 of 24 (1 max)<LF>=== RTOS ===<LF>Static ram: 23460<LF>Dynamic ram: 77144 of which 40 recycled<LF>Never used RAM 11436, free system stack 183 words<LF>Tasks: NETWORK(ready,401) HEAT(blocked,323) MAIN(running,472) IDLE(ready,19)<LF>Owned mutexes: WiFi(NETWORK) USB(MAIN)<LF>=== Platform ===<LF>Last reset 00:12:12 ago, cause: power up<LF>Last software reset at 2021-01-30 15:46, reason: User, GCodes spinning, available RAM 15160, slot 2<LF>Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x00400000 BFAR 0xe000ed38 SP 0x00000000 Task MAIN Freestk 0 n/a<LF>Error status: 0x00<LF>Aux0 errors 0,0,0<LF>MCU temperature: min 23.6, current 26.0, max 26.5<LF>Supply voltage: min 1.4, current 1.7, max 1.8, under voltage events: 0, over voltage events: 0, power good: no<LF>Driver 0: position 0, ok, SG min/max not available<LF>Driver 1: position 0, ok, SG min/max n[Warning: Maximal number of bytes per line exceeded! Check the EOL (end-of-line) settings or increase the limit in the advanced terminal settings.]
Can you change your line endings in YAT so we can see the full response?
Set YAT to use <LF> as the end of line character. This will improve the readability of the messages coming from the Duet. Click "Text Settings" in the "Terminal Settings" and change "EOL sequence:" to <LF>. Click "OK" to close Text Settings. Click "OK" again to close Terminal Settings.
M122<CR>
Static ram: 23460
Error status: 0x00
Aux0 errors 0,0,0
Driver 1: position 0, ok, SG min/max not available
Driver 2: position 0, ok, SG min/max not available
Driver 3: position 0, ok, SG min/max not available
Driver 4: position 0, ok, SG min/max not available
Driver 5: position 0
Driver 6: position 0
Driver 7: position 0
Driver 8: position 0
Driver 9: position 0
Driver 10: position 0
Driver 11: position 0
Cache data hit count 989961302
Slowest loop: 2.22ms; fastest: 0.14ms
=== Storage ===
Free file entries: 10
SD card longest read time 0.5ms, write time 0.0ms, max retries 0
=== MainDDARing ===
=== AuxDDARing ===
Segments left: 0
Movement lock held by null
HTTP is idle in state(s) 0
Telnet is idle in state(s) 0
File is idle in state(s) 0
USB is ready with "M122" in state(s) 0
Aux is idle in state(s) 0
Trigger is idle in state(s) 0
Queue is idle in state(s) 0
LCD is idle in state(s) 0
Daemon is idle in state(s) 0
Code queue is empty.
=== Network ===
Slowest loop: 3.48ms; fastest: 0.00ms
HTTP sessions: 0 of 8- WiFi -
Network state is active
WiFi module is providing access point
WiFi firmware version 1.25
WiFi MAC address ce:50:e3:0d:1f:26
WiFi Vcc 3.36, reset reason Turned on by main processor
WiFi flash size 4194304, free heap 26720
WiFi IP address 192.168.1.1
Connected clients 1
Clock register 00002002
ok
- WiFi -
can you post a picture of it?
Ok, firmware version is good. Wifi server should be good. And it says it is in access point mode with the correct IP. You can connect to the wifi, but when trying to reach 192.168.1.1 in your browser you get an error message in your browser saying "enable to connect"?
Have you tried these suggestions from earlier yet?
Try clearing your browser cache.
And if that doesn't work, I would check the /www folder on the SD card and replace the files there with a fresh copy of DWC.
https://github.com/Duet3D/RepRapFirmware/releases/download/3.2/DuetWebControl-SD.zip
What url are you trying to reach exactly?
M552 S2
ok
WiFi module is providing access point DuetCr10, IP address 192.168.1.1when this was working properly, i use to have this same message repeatedly. Now just shows one time!
@Phaedrux allready clean my cache and the problem remains. About the replacement of the 3.2, im going to do it now
Alright, replace the contents of /www with the contents of this zip file.
@Phaedrux didnt change the problem. When this was working ok, usualy i had to eject M552 S2 twice. Pist an error appear, but at the second time, usualy the message shows pepeatedly. Now, whem i send the comand, goes strait to the message saying the module is providing access point!
could it be an error from firefox?
Well you are running newer firmware on both the duet and the wifi module, so the behaviour may be a bit different looking than you're used to.
Can you post a screen shot or photo of what the firefox error message is saying?
control-shift-K will open the dev console in firefox which may show any errors.
cant uload the image!!!! gives me an error.... looks this day is a complete error.
wait...to small
