Update CR-10+Duet wifi from 2.05.1 to 3.0 firmware
M552 S2
ok
WiFi module is providing access point DuetCr10, IP address 192.168.1.1when this was working properly, i use to have this same message repeatedly. Now just shows one time!
@Phaedrux allready clean my cache and the problem remains. About the replacement of the 3.2, im going to do it now
@Hélder-Rocha said in Update CR-10+Duet wifi from 2.05.1 to 3.0 firmware:
Alright, replace the contents of /www with the contents of this zip file.
https://github.com/Duet3D/RepRapFirmware/releases/download/3.2/DuetWebControl-SD.zip
@Phaedrux didnt change the problem. When this was working ok, usualy i had to eject M552 S2 twice. Pist an error appear, but at the second time, usualy the message shows pepeatedly. Now, whem i send the comand, goes strait to the message saying the module is providing access point!
could it be an error from firefox?
Well you are running newer firmware on both the duet and the wifi module, so the behaviour may be a bit different looking than you're used to.
Can you post a screen shot or photo of what the firefox error message is saying?
control-shift-K will open the dev console in firefox which may show any errors.
cant uload the image!!!! gives me an error.... looks this day is a complete error.
wait...to small
Its trying to use HTTPS. Change the url to use only http
the same appens on chrome!
@Phaedrux said in Update CR-10+Duet wifi from 2.05.1 to 3.0 firmware:
Going to check how that is done...
Just change the url.
HTTP: instead of HTTPS:
it changes again to HTTPS...i erase the "s" but doesnt work
@Hélder-Rocha I don't know if that's a problem or just what it normally does when it can't reach the site.
Are you able to connect the duet to your home wifi?
even if i try the duettest.local... it changes to the https followed by the ip number
no... i am trying by the access point given by the board
the blue led on the board is lit... the duet is working fine... after dinner ill try a different computer
Yes I understand that, but do you have a local WIFI network that you can test connecting to?
