    Faulty Smart Effector
    Smart effector for delta printers
    823
    • tcjundefined
      tcj
      Sep '19 at filafarm.de
      I've already sent them a mail
        Photos? Maybe we can see something you can't?
        Wiring?
        Did anything change recently with the printer?
        When was it working last?
        • tcjundefined
          tcj
          Wiring is ok - worked for months
          Updated RRF a few days ago, but not yesterday
          Working last night at last
            Is that a scratch on the second photo on the bottom edge?
            • tcjundefined
              tcj
              yes, but it's there since I received it and it is only on the lacquer coat
                What M672 are you using?
                • tcjundefined
                  tcj
                  tried M672 S131:131 without success - even no flashing of the LED
                  and before you're asking 😉
                  ;### Z-Probe ###
                  M558 P8 R0.2 F1200 H2 C"zprobe.in"
                  G31 P100 X0 Y0 Z-0.19           		; Set Z probe trigger value, offset and trigger height
                  M557 R180 S40                          		; Define mesh grid
                  • Vetiundefined
                    Veti
                    @tcj said in Faulty Smart Effector:
                    this is missing the zprobe.mod to control the sensitivity
                    try C"zprobe.in+zprobe.mod"
                    tcjundefined 2 Replies Last reply Reply Quote 1
                    • tcjundefined
                      tcj @Veti
                      @Veti 😽
                      • tcjundefined
                        tcj @Veti
                        @Veti Thank you so much!
                        It works!
                        • Lightpathundefined
                          Lightpath
                          @Veti said in Faulty Smart Effector:
                          This should be in the documentation.
                            Phaedrux Moderator @Lightpath
                            @Lightpath said in Faulty Smart Effector:
                            Consider it done.
