    Faulty Smart Effector
    Smart effector for delta printers
    775
      When and where did you purchase it?
      • tcjundefined
        tcj
        Sep '19 at filafarm.de
        I've already sent them a mail
          Photos? Maybe we can see something you can't?
          Wiring?
          Did anything change recently with the printer?
          When was it working last?
          • tcjundefined
            tcj
            Wiring is ok - worked for months
            Updated RRF a few days ago, but not yesterday
            Working last night at last
              Is that a scratch on the second photo on the bottom edge?
              • tcjundefined
                tcj
                yes, but it's there since I received it and it is only on the lacquer coat
                  What M672 are you using?
                  • tcjundefined
                    tcj
                    tried M672 S131:131 without success - even no flashing of the LED
                    and before you're asking 😉
                    ;### Z-Probe ###
                    M558 P8 R0.2 F1200 H2 C"zprobe.in"
                    G31 P100 X0 Y0 Z-0.19           		; Set Z probe trigger value, offset and trigger height
                    M557 R180 S40                          		; Define mesh grid
                    • Vetiundefined
                      Veti
                      @tcj said in Faulty Smart Effector:
                      this is missing the zprobe.mod to control the sensitivity
                      try C"zprobe.in+zprobe.mod"
                      tcjundefined 2 Replies Last reply Reply Quote 1
                      • tcjundefined
                        tcj @Veti
                        @Veti 😽
                        • tcjundefined
                          tcj @Veti
                          @Veti Thank you so much!
                          It works!
                          • Lightpathundefined
                            Lightpath
                            @Veti said in Faulty Smart Effector:
                            This should be in the documentation.
                              Phaedrux Moderator @Lightpath
                              @Lightpath said in Faulty Smart Effector:
                              Consider it done.
