    Inconsistent results with optical encoder wheel filament sensor
    Filament Monitor
    9
    168
    12.0k
    • Nuramoriundefined
      Nuramori @JohnOCFII
      @JohnOCFII
      I made a version that uses bondtech’s hobbed gears to spin the optical wheel, since it has positive engagement. You may want to try that. I can also share the design. It otherwise uses the same/similar parts.
      • JohnOCFIIundefined
        JohnOCFII
        I figured out my issue with non-movement related false alarms: 🙂
        (The PTFE fell out in my repeated replacement of filament...)
        • alankilianundefined
          alankilian
          @JohnOCFII said in Inconsistent results with optical encoder wheel filament sensor:
          Gravity sucks!
          I'ts been a really fun ride watching you build/diagnose/deal-with-it and then show success with this project.
          Thanks for sharing your journey with us housebound folks.
          JohnOCFIIundefined 1 Reply Last reply Reply Quote 1
            JohnOCFII @alankilian
            @alankilian said in Inconsistent results with optical encoder wheel filament sensor:
            Gravity sucks!
            Indeed!
            Happy to share. I figure someone out there might benefit, so why not share?
            I'd be nowhere without you and @arhi and of course, the great design from @fractalengineer!
              JohnOCFII
              Just a quick update.
              The sensor continues to work well:
              Pulse-type filament monitor on pin e1stop, enabled, sensitivity 1.710mm/pulse, allowed movement 30% to 900%, check every 6.0mm, measured sensitivity 1.748mm/pulse, measured minimum 95%, maximum 102% over 255.9mm
              I hadn't been printing on this printer for a few weeks, and had left some PLA mounted. I started a print today, and on the first layer, I heard the print pause, and the print carriage start to move out of the way. My first thought was, "Oh oh -- a false alarm." Looking more closely, I saw it had triggered on a real filament failure. The filament in the feed tube had broken after the filament sensor, so the filament wasn't moving!
              Filament swapped, and print continues!
              And as @fractalengineer and I started to think about how to put the ST in the sensor package, he found a board on Ali Express that already had the ST as part of the optical sensor! He and I each ordered a few, and some day -- they will arrive.
              I'll report back when that happens.
              John
              fractalengineerundefined 1 Reply Last reply Reply Quote 1
              • fractalengineerundefined
                fractalengineer @JohnOCFII
                @JohnOCFII wow very nice and did that leave a mark on the print?
                or does it resume from the beginning of the layer/layer before?
                I'm thinking that with such tight measured error we could reduce the measurement distance to improve the reactivity
                Railcore II ZL
                JohnOCFIIundefined 1 Reply Last reply Reply Quote 0
                  JohnOCFII @fractalengineer
                  @fractalengineer said in Inconsistent results with optical encoder wheel filament sensor:
                  It resumes from where it senses the error, so with my configuration, that could be up to 6mm after the break. I don't know that I'd want to get any shorter than that, for fear of false alarms. I think I'd have to test with something like a vase-mode print to see what the possible imperfection could be.
                  Many times you'll get lucky, and a failure will happen on infill, and not an exterior perimeter. In that case, you shouldn't see anything. In this case, it was on a first layer and there was a tiny hole, but not something I'd be likely to see.
                  John
                    JohnOCFII
                    FYI -- still loving the results!
                    Pulse-type filament monitor on pin e1stop, enabled, sensitivity 1.710mm/pulse, allowed movement 30% to 900%, check every 6.0mm, measured sensitivity 1.727mm/pulse, measured minimum 87%, maximum 111% over 3654.4mm
                    @fractalengineer has received his new optical sensor with ST. Mine are still enroute.
                      JohnOCFII
                      Yes, maybe I am bragging a bit, but this was a team effort after all:
                      Longest print to date with the filament sensor:
                      M591 D0
                      check every 6.0mm, measured sensitivity 1.753mm/pulse, measured minimum 46%, maximum 140% over 52885.0mm
                      The new optical sensor with Schmitt Trigger has arrived -- now just waiting on the stars to align before I can test it.
                      John
                        This thread may be of interest https://forum.duet3d.com/topic/4498/filament-monitor-using-hc-020k-encoder. The issue was that the HC-020K optical sensor used a comparator with no hysteresis. That is an elementary design mistake, that causes the output to bounce between high and low many times whenever the output transitions, instead of providing a clean edge. Adding a resistor to the comparator circuit to provide positive feedback solved that.
                          JohnOCFII
                          I've got the new optical sensor with the integrated Schmitt Trigger installed and operating. Seems to be working fine, and showing clean signals.
                          Pulse-type filament monitor on pin e1stop, disabled, sensitivity 2.000mm/pulse, allowed movement 30% to 900%, check every 6.0mm, measured sensitivity 2.002mm/pulse, measured minimum 88%, maximum 123% over 758.9mm
                          Full Saleae log available on request.
                          John
                          arhiundefined 1 Reply Last reply Reply Quote 1
                          • arhiundefined
                            arhi @JohnOCFII
                            @JohnOCFII that is nice, obviously the encoder input is not having Schmitt trigger input so simple analog devices will not work. Not sure why 'cause if I remember correctly these inputs can have ST input turned on in port configuration. One hint - what logic analyzer sees and what duet sees are not identical!!! It is similar as you have a similar input port on the CY in the logic analyzer as is on the SAM in duet but they are not the same.
