Duet won't connect via usb
570
    wdenker @wdenker
    @wdenker bought from Filastruder in March of last year just haven't had time to do anything with this since then. Tried using bossa to flash new firmware and recover but won't connect via usb at all. @Phaedrux
    www.bd3dcustoms.com | BD3DCUSTOMS Supercube
    undefined 1 Reply Last reply 3 Feb 2021, 18:56 Reply Quote 0
      wdenker
        fcwilt
        We need a lot more info.
        Did the Duet 2 WiFi every work?
        Did it work with the Duex?
        What happened to make you think it took out the Duex as well?
        When you now connect the Duet 2 WiFi via USB does Windows show a new COM port appearing in Device Manager under Ports (COM & LPT)?
          wdenker
          If I remember right it started smoking no idea why as the replacement I used worked in same wiring configuration. Usb doesn't show any device. Tried to use the duet on the new board with no response from any of the fans or motors connected.
          undefined 1 Reply Last reply 3 Feb 2021, 03:25 Reply Quote 0
            fcwilt @wdenker
            @wdenker said in Duet won't connect via usb:
            Well you didn't exactly answer the questions as posted but let's see if we can make any progress.
            Are you connecting to USB2 or USB3 port on the computer?
            Are you perhaps connecting through a USB HUB - they often will not allow the connection to the Duet to work.
            Are you using a long cable? Sometimes you need to use a short one.
            undefined 1 Reply Last reply 3 Feb 2021, 03:27 Reply Quote 0
              wdenker @fcwilt
              @fcwilt same usb port that works for the rest of my boards I've setup. This will be like the 30th. Usb2 and supplied usb cord.
              undefined 1 Reply Last reply 3 Feb 2021, 04:04 Reply Quote 0
                fcwilt @wdenker
                Well that would suggest the board is fried.
                undefined 1 Reply Last reply 3 Feb 2021, 04:16 Reply Quote 0
                  wdenker @fcwilt
                  @fcwilt will we be able to warranty them?
                  undefined 1 Reply Last reply 3 Feb 2021, 04:19 Reply Quote 0
                    fcwilt @wdenker
                    I have no idea.
                    The terms of the warranty must be on the E3D web site somewhere.
                    And they are really pretty good about bending the rules on occasion.
                      A Former User
                      you followed https://duet3d.dozuki.com/Wiki/Installing_and_Updating_Firmware#Section_Fallback_procedure_Num_3 ?
                      if so odds are the cpu is fried indeed.
                      undefined 1 Reply Last reply 3 Feb 2021, 06:32 Reply Quote 0
                        wdenker @A Former User
                        @bearer yes
                          A Former User
                          Is this thread for the W00955 board shown in the other thread then? The one that might have a problem with u2, that would explain it not working with usb.
                          undefined 1 Reply Last reply 3 Feb 2021, 14:26 Reply Quote 0
                            @bearer yes I was told to start seperate threads.
                            undefined 1 Reply Last reply 3 Feb 2021, 14:45 Reply Quote 0
                              droftarts administrators @wdenker
                              @wdenker I'd guess there's a short through the driver to ground, though not sure why there's enough 3.3V for the LEDs and WiFi to come on. It's possible the main processor has failed, though the SD card and Wifi usually fail first if 3.3V is overloaded. Can you post a picture of the back of the board, too? Have you checked the fuses? The 7.5A possibly looks discoloured.
                              Did the board ever work, or did this happen at first power on?
                              I can't see much wrong with the Duex, but again, check the fuse (it doesn't look quite right).
                              undefined 1 Reply Last reply 3 Feb 2021, 18:33 Reply Quote 0
                                wdenker @droftarts
                                @droftarts all of the fuses are fine unfortunately.
                                  Phaedrux Moderator @wdenker
                                  So this is a Duet2Wifi and a Duex5 that both don't work?
                                  They were bought in March, but when did they stop working? Did they ever work?
                                  When the Duex is connected to a working Duet2, does it show up in the M122?
                                  undefined 1 Reply Last reply 3 Feb 2021, 19:02 Reply Quote 0
                                    wdenker @Phaedrux
                                    @Phaedrux they stopped working within an hour of being configured. I don't think the duex 5 ever worked.
                                    11 out of 18
