    Cant find Endstop status on DWC
    Duet Web Control wishlist
    10
    21
    1.6k
    • OwenDundefined
      OwenD
      The object model browser probably isn't much use in this instance as it doesn't live update.
      It will show the state when you open the browser.
      To check you can use M119 or send
      echo sensors.endstops[0].triggered
      Where 0=X, 1=Y etc
        A Former User
        You might check out the macro from OwenD here https://forum.duet3d.com/topic/15420/object-model-endstop-switches/3
        For me that works nicely! Thanks everybody
        • 3DPrintingWorldundefined
          3DPrintingWorld
          Glad you can check status with the M119 but I'm confused as to why the visual status has been removed as it was a nice feature.
          fcwiltundefined Phaedruxundefined 2 Replies Last reply Reply Quote 1
          • fcwiltundefined
            fcwilt @3DPrintingWorld
            @3DPrintingWorld said in Cant find Endstop status on DWC:
            Here is where the Object Model state can be viewed BUT it is only in firmware 3.2 - as I recall.
            There is a "refresh" button you can use to update to the current state of the system.
              Phaedrux Moderator @3DPrintingWorld
              Indeed. And it should be making a comeback.
                deckingman @Phaedrux
                @Phaedrux said in Cant find Endstop status on DWC:
                If you have the ear of the relevant person responsible, tell them that it would be even better if one could see the status of the ends stop as they are assigned to axes, rather than by their index number. When they were displayed, it was by index number and it can be a real pain to find out which index number corresponds to which axis. It is almost impossible to work out the logic.
                3DPrintingWorldundefined 1 Reply Last reply Reply Quote 2
                  3DPrintingWorld @deckingman
                  @deckingman I agree with you, that would be a nice addition!
                  • Adamfilipundefined
                    Adamfilip
                    I feel just having a Small Dot Next to the XYZ and Probe areas would be very helpful
                    to have a quick visualization of endstop status
                    endstops.jpg image url)
                    deckingmanundefined 1 Reply Last reply Reply Quote 12
                    • Chrissundefined
                      Chriss
                      My voice on this feature request! This is a very handsome solution. 😉
                        deckingman @Adamfilip
                        @Adamfilip That gets my vote too - a very elegant solution. Hope it can be implemented.........
                        warpsterundefined Adamfilipundefined 2 Replies Last reply Reply Quote 0
                        • warpsterundefined
                          warpster @deckingman
                          That would be helpful. There are many docs around that say to reference the endstop status in the DWC but all of that documentation is wrong and confusing to a new user at this point. I think the proposed solution would be a great addition!
                          By the way I do not have the Object Model choice under Settings on 3.2 so is that an addon?
                          • fcwiltundefined
                            fcwilt @warpster
                            @warpster said in Cant find Endstop status on DWC:
                            It's a plug-in that needs to be started.
                            Navigate in DWC to here and you should see the start buttons on the right side.
                            warpsterundefined 1 Reply Last reply Reply Quote 1
                            • warpsterundefined
                              warpster @fcwilt
                              @fcwilt got it, thanks
                                Adamfilip @deckingman
                                +1 bumping
                                Wish this feature can be implemented. Feeling like DWC never seems to get any love or improvements, just my impression. (hope im wrong)
                                Adamfilipundefined 1 Reply Last reply Reply Quote 0
                                  Adamfilip @Adamfilip
                                  Please upvote the first post so hopefully this feature gets some traction
