duet3d sd not detected, rejects http, com5 denied
Look in the i/o mapping page.
Did you select firmware version 3.0+ at the start? You are on 3.2 now right?
it does not five me a option for that
@Phaedrux said in duet3d sd not detected, rejects http, com5 denied:
@Phaedrux I installed all the file you gave me. the config im still unsure on some options to choose.
@radcad Can you be more specific?
@Phaedrux
If this is what you mean, then yes.
sorry im a newb at all thius thank you for helping me out with this.
@radcad said in duet3d sd not detected, rejects http, com5 denied:
Yes, but I mean what options are you unsure of?
@Phaedrux
If I use the ender 3 pro preset. there is no expansion board config, but it allows me to add a dual stepper motor driver ?
for the bed control do I select PID or bang bang. i have a upgraded bed that runs on mains.
this part about which sensor location to read.
i think the first 2 spi spots are for 1 daughter board and 3 - 4 are for a second board but Im not sure.
Yes the highlighted option is for the first PT100 port on the daughterboard.
This post is deleted! -
@Phaedrux I see a option for pid / bang bang should i just select pid and raise the temp?
Ive been following this guild for the bed set up, however he is using Marlion.
https://www.youtube.com/watch?v=1VyFejiKkSQ -
yes pid. once your printer is set up you have to run a pid tune.
https://duet3d.dozuki.com/Wiki/Tuning_the_heater_temperature_control -
do i need to change any of this if i have a mains powered heatedbed?
NTC 100k 395 thermistor
120v 500watt bed
Change the B value to 3950 instead of 4092
3950
I cant get the config to uplaod keeps saying network error. i can only get to 75%
What exactly are you trying to upload to where?
@Phaedrux the config file.
i finally got it to upload! so what should i do next? -
Do some commissioning tests?
https://duet3d.dozuki.com/Guide/Ender+3+Pro+and+Duet+Maestro+Guide+Part+3:+Commissioning/39
