duet3d sd not detected, rejects http, com5 denied
This post is deleted! -
@Phaedrux I see a option for pid / bang bang should i just select pid and raise the temp?
Ive been following this guild for the bed set up, however he is using Marlion.
https://www.youtube.com/watch?v=1VyFejiKkSQ -
yes pid. once your printer is set up you have to run a pid tune.
https://duet3d.dozuki.com/Wiki/Tuning_the_heater_temperature_control -
do i need to change any of this if i have a mains powered heatedbed?
NTC 100k 395 thermistor
120v 500watt bed
Change the B value to 3950 instead of 4092
@Phaedrux said in duet3d sd not detected, rejects http, com5 denied:
3950
I cant get the config to uplaod keeps saying network error. i can only get to 75%
What exactly are you trying to upload to where?
@Phaedrux the config file.
i finally got it to upload! so what should i do next? -
Do some commissioning tests?
https://duet3d.dozuki.com/Guide/Ender+3+Pro+and+Duet+Maestro+Guide+Part+3:+Commissioning/39
