    duet3d sd not detected, rejects http, com5 denied
    2.7k
      Phaedrux Moderator @radcad
      @radcad said in duet3d sd not detected, rejects http, com5 denied:
      the config im still unsure on some options to choose.
      Yes, but I mean what options are you unsure of?
      radcadundefined 1 Reply Last reply Reply Quote 0
      • radcadundefined
        radcad @Phaedrux
        @Phaedrux
        If I use the ender 3 pro preset. there is no expansion board config, but it allows me to add a dual stepper motor driver ?
        for the bed control do I select PID or bang bang. i have a upgraded bed that runs on mains.
        this part about which sensor location to read.
        i think the first 2 spi spots are for 1 daughter board and 3 - 4 are for a second board but Im not sure.
          Yes the highlighted option is for the first PT100 port on the daughterboard.
          • radcadundefined
            radcad @Phaedrux
            This post is deleted!
            • radcadundefined
              radcad
              @Phaedrux I see a option for pid / bang bang should i just select pid and raise the temp?
              Ive been following this guild for the bed set up, however he is using Marlion.
              https://www.youtube.com/watch?v=1VyFejiKkSQ
              • Vetiundefined
                Veti @radcad
                @radcad
                yes pid. once your printer is set up you have to run a pid tune.
                https://duet3d.dozuki.com/Wiki/Tuning_the_heater_temperature_control
                • radcadundefined
                  radcad
                  do i need to change any of this if i have a mains powered heatedbed?
                  NTC 100k 395 thermistor
                  120v 500watt bed
                    Change the B value to 3950 instead of 4092
                    • radcadundefined
                      radcad
                      @Phaedrux said in duet3d sd not detected, rejects http, com5 denied:
                      3950
                      I cant get the config to uplaod keeps saying network error. i can only get to 75%
                        What exactly are you trying to upload to where?
                        • radcadundefined
                          radcad
                          • radcadundefined
                            radcad @Phaedrux
                            @Phaedrux the config file.
                            i finally got it to upload! so what should i do next?
                              Do some commissioning tests?
                              https://duet3d.dozuki.com/Guide/Ender+3+Pro+and+Duet+Maestro+Guide+Part+3:+Commissioning/39
