    G32 ERROR
    5.3k
    • moe.adams9093undefined
      moe.adams9093
      Yes I did have a problem but I was using << !exp.e2stop to !exp.e6stop >> that was another issue. Anyway I haven't downgraded yet to 3.1 I will see if it works but I think it should
        Maybe stick to 3.2 instead of 3.1.1
        moe.adams9093undefined 1 Reply Last reply Reply Quote 0
          moe.adams9093 @Phaedrux
          @Phaedrux 3.2 for somereason my external driver Number 10 it won't work
            moe.adams9093
            So I downgraded to 3.1.1 and Main board is not working now YAT won't see it to enable ethernet via USB and can even erase firmware when i jump the reset pins deg light won't even turn red. Why did that happen
              moe.adams9093
              Never mind I figured it out
              • fcwiltundefined
                fcwilt @moe.adams9093
                @moe-adams9093 said in G32 ERROR:
                Well don't leave us in suspense. What did you find?
                  moe.adams9093
                  One of my endstops connection was reversed accidentally and it caused a short so the board automatically shut down power to the CPU thats why it wasn't abel to communicate via USB. All up and running now endstops works fine as well. One single problem im having now is when the bed go back to the min side it won't stop by the IR sensor. Any idea on how I can fix this. Same homeall .g file I posted previously. Thanks again for keeping up.
                  • fcwiltundefined
                    Oops. I take if you are not using the mating connectors for the Duet which only go on one way?
                    Glad to hear it.
                    Questions:
                    • So this file never works or only sometimes works?
                    • Why so much movement in this command G1 H1 Z500 F6000?
                    • Did you mean this to be a relative move G1 X235 Y235 F6000?
                    ;  homeall.g
                    G91                      ; relative positioning
                    G1 H1 Z500 F6000         ; lift Z relative to current position
                    G1 H1 X-465 F8000        ; move quickly to X endstop and stop there (first pass)
                    G1 H1 Y-465 F8000        ; move quickly to Y endstop and stop there (first pass)
                    G1 H2 X5 Y5 F6000        ; go back a few mm
                    G1 H1 X-465 F360         ; move slowly to X axis endstop once more (second pass)
                    G1 H1 Y-465 F360         ; then move slowly to Y axis endstop
                    G1 X235 Y235 F6000       ; Prob at Center
                    M558 F600 A1 	         ; Dive fast once
                    G30			 ; probe Z
                    M558 F300 A10            ; Slow second dive with more accuracy
                    G30			 ; probe z again
                    Always willing to help when I can.
                      moe.adams9093
                      So when I press homeall
                      These are the steps I wanted to do
                      1. Bed travel to Zmax which is 500 ☑
                      2. BED hit all four endStop at Zmax and stops axis individually ☑
                      3. X&Y travel to the center (235,235) prob at center ❎
                      So now X&Y are not traveling to (235,235) to perform probing sequence.
                      • fcwiltundefined
                        Questions:
                        • Is there ANY movement at all on the X or Y axis in response to the G1 X235 Y235 F6000 command?
                        • Is there ANY movement at all on the Z axis back towards the bed in response to the first G30 command?
                        If I were trying to solve this I would first:
                        • Comment out all of the commands starting with the G1 X235 Y235 F6000 command.
                        • Perform a home all.
                        • Verify that the X and Y axes homed and ended up at X=0 Y=0.
                        So if you can provide those two answers and perhaps perform that test?
                          I have increased the max length of the pin name string in the forthcoming 3.2.1 release.
