    G32 ERROR
    5.1k
      Phaedrux Moderator @fcwilt
      @fcwilt said in G32 ERROR:
      I don't understand.
      They are listed together under Endstop Inputs for the DueX boards.
      They are listed as possible pins to use. They are not all equivalent in that list. For instance it lists pins on the Duet as well as the Duex. The exp pins are literally the pins on the expansion header, not the duex pins. The duex endstop pins are separate and routed differently.
      So originally when using those exp endstop pin names it was never going to work because he wasn't actually using those pins. (he was using the actual duex endstop headers).
      If he had 3 z axis motors and endstops instead of 4, we (you) never would have discovered this bug with the overflow.
      fcwiltundefined 1 Reply Last reply Reply Quote 2
      • moe.adams9093undefined
        moe.adams9093
        Ok I'm going to make some tests today and see what I'm going to end up with. I will keep you posted
        • fcwiltundefined
          fcwilt @Phaedrux
          @Phaedrux said in G32 ERROR:
          I had forgotten that was the case. I got distracted by the quest to figure out why the command was getting truncated.
          Perhaps you should update the documentation in that regard as there are some existing pin names that are marked with a ***** to reference a note above regarding their behavior.
          It wouldn't hurt to point out the difference in these end stop pins in much the same way.
          It would be more work but it might be best to have Duet pin names under a Duet heading and Duex pin names under a Duex heading.
            moe.adams9093
            Yeah I'm going to try 3.3 and do duex.e2stop all the way to duex.e6stop and see how its going to behave
              moe.adams9093
              @dc42 So I went ahead and did an update to 3.3. I have 2 problems now My driver Number 10 is an external driver it doesn't move at all it's getting a signal because it locks but no movement in any direction and regarding endstops still the same issue. I will post
              config. g
              homall. g
              M119
              M122
              M98P"config. g"
              config. g
              ; generated by RepRapFirmware Configuration Tool v3.1.4 on Tue Feb,04,2021 12:48.00 GMT-0500 (Central Daylight Time)
              G90                                                     	; send absolute coordinates...
              M83                                                     	; ...but relative extruder moves
              M550 P"DIVINCI-3D (MP4560)"                             	; set printer name
              M669 K1                                                 	; select CoreXY mode
              M552 P0.0.0.0 S1                                        	; enable network and acquire dynamic address via DHCP
              M586 P0 S1                                              	; enable HTTP
              M586 P1 S0                                              	; disable FTP
              M586 P2 S0                                              	; disable Telnet
              M569 P10  R1 T2:2:2:2  S1  									; physical drive 0 goes forwards
              M569 P11  R1 T2:2:2:2  S1  									; physical drive 1 goes forwards
              M569 P3 S1                                             		; physical drive 3 goes forwards
              M569 P4 S1                                              	; physical drive 4 goes forwards
              M569 P5 S1                                              	; physical drive 5 goes Forwards
              M569 P6 S1 													; physical drive 6 goes Forwards
              M569 P8 S1			          								; physical drive 7 goes Forwards
              M569 P9 S1                                              	; physical drive 9 goes Forwards
              M584 X10 Y11 Z5:6:8:9 E3:4                              	; set drive mapping
              M671 X5.0:455.0:455.0:5.0 Y25.0:25.0:455.0:455.0 S14    	; ZBelts Near Locations
              M350 X16 Y16 Z16 E16:16 I1                              	; configure microstepping with interpolation
              M92 X80.00 Y80.00 Z410.00 E415.00:415.00 					; set steps per mm
              M566 X900.00 Y900.00 Z12.00 E120.00:120.00              	; set maximum instantaneous speed changes (mm/min)
              M203 X6000.00 Y6000.00 Z400 E1200.00:1200.00        		; set maximum speeds (mm/min)
              M201 X500.00 Y500.00 Z40.00 E250.00:250.00           		; set accelerations (mm/s^2)
              M906 X1800 Y1800 Z1000 E500.00:500.00 I30                     	; set motor currents (mA) and motor idle factor in per cent
              M84 S30                                                 	; Set idle timeout
              M208 X0 Y0 Z0 S1                                        	; set axis minima
              M208 X460 Y460 Z460 S0                                  	; set axis maxima
              M574 X1 S1 P"!xstop"                                    		; configure active-high endstop for low end on X via pin !xstop
              M574 Y1 S1 P"!ystop"                                    		; configure active-high endstop for low end on Y via pin !ystop
              M574 Z1 S2 														  ;   configure Z-probe endstop for low end on Z
              M574 Z2 S1 P"!duex.e2stop+!duex.e3stop+!duex.e4stop+!duex.e5stop" ;   configure Z-probe endstop for low end on Z
              M558 P1 C"zprobe.in" H25 F600 T6000                      	; set Z probe type to unmodulated and the dive height + speeds
              G31 P500 X0 Y0 Z2.5                                     	; set Z probe trigger value, offset and trigger height
              M557 X20:440 Y20:440 S20                                	; define mesh grid
              M308 S0 P"bedtemp" Y"thermistor" T100000 B4725 C7.06e-8 	; configure sensor 0 as thermistor on pin bedtemp
              M950 H0 C"bedheat" T0                                   	; create bed heater output on bedheat and map it to sensor 0
              M307 H0 A11 C99000 D2000 B1                  				; enable bang-bang mode for the bed heater and set PWM limit
              M140 H0                                                 	; map heated bed to heater 0
              M143 H0 S120                                            	; set temperature limit for heater 0 to 120C
              M308 S1 P"spi.cs1" Y"thermocouple-max31856"             	; configure sensor 1 as thermocouple via CS pin spi.cs1
              M950 H1 C"e0heat" T1                                    	; create nozzle heater output on e0heat and map it to sensor 1
              M307 H1 B0 S1.00                                        	; disable bang-bang mode for heater  and set PWM limit
              M308 S2 P"spi.cs2" Y"thermocouple-max31856"             	; configure sensor 2 as thermocouple via CS pin spi.cs2
              M950 H2 C"e1heat" T2                                    	; create nozzle heater output on e1heat and map it to sensor 2
              M307 H2 B0 S1.00                                        	; disable bang-bang mode for heater  and set PWM limit
              M308 S3 P"duex.e2temp" Y"thermistor" T10000 B3950       	; configure sensor 3 as thermistor on pin duex.e2temp
              M950 H3 C"duex.e2heat" T3                               	; create chamber heater output on duex.e2heat and map it to sensor 3
              M307 H3 A11 C99000 D2000 B1                             	; enable bang-bang mode for the chamber heater and set PWM limit
              M141 H3                                                 	; map chamber to heater 3
              M950 F0 C"fan0" Q500                                    	; create fan 0 on pin fan0 and set its frequency
              M106 P0 S1 H-1                                          	; set fan 0 value. Thermostatic control is turned on
              M950 F1 C"fan1" Q500                                    	; create fan 1 on pin fan1 and set its frequency
              M106 P1 S1 H2 T45                                       	; set fan 1 value. Thermostatic control is turned on
              M950 F2 C"fan2" Q500                                    	; create fan 2 on pin fan2 and set its frequency
              M106 P2 S1 H1:2 T45                                     	; set fan 2 value. Thermostatic control is turned on
              M563 P0 S"MAIN EXTRUDER" D0 H1 F0                       	; define tool 0
              G10 P0 X0 Y0 Z0                                         	; set tool 0 axis offsets
              G10 P0 R0 S0                                            	; set initial tool 0 active and standby temperatures to 0C
              M563 P1 S"SECOND EXTRUDER" D1 H2 F0                     	; define tool 1
              G10 P1 X0 Y0 Z0                                         	; set tool 1 axis offsets
              G10 P1 R0 S0                                            	; set initial tool 1 active and standby temperatures to 0C
              M575 P1 S1 B57600                                       	; enable support for PanelDue
              M501                                                    	; load saved parameters from non-volatile memory
              M911 S10 R11 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000"      	; set voltage thresholds and actions to run on power loss
              T0                                                      	; select first tool
              Homeall.g
              ; homeall.g
              ; called to home all axes
              ; generated by RepRapFirmware Configuration Tool v3.1.4 on Tue Oct 13 2020 21:14:55 GMT-0500 (Central Daylight Time)
              G1 H1 Z500 F6000          ; lift Z relative to current position
              G1 H1 X-465 F8000 ; move quickly to X endstop and stop there (first pass)
              G1 H1 Y-465 F8000 ; move quickly to Y endstop and stop there (first pass)
              G1 H2 X5 Y5 F6000       ; go back a few mm
              G1 H1 X-465 F360        ; move slowly to X axis endstop once more (second pass)
              G1 H1 Y-465 F360        ; then move slowly to Y axis endstop
              G1 X235 Y235 F6000      ; Prob at Center
              M558 F600 A1 		    ; Dive fast once
              G30			            ; probe Z
              M558 F300 A10 		    ; Slow second dive with more accuracy
              G30			            ; probe z again
              HomeZ.g
              ; homez.g
              ; called to home the Z axis
              ; generated by RepRapFirmware Configuration Tool v3.1.4 on Tue Oct 13 2020 21:14:56 GMT-0500 (Central Daylight Time)
              G1 H1 Z-500 F3000 ; move Z down until the endstop is triggered
              G92 Z0            ; set Z position to axis minimum (you may want to adjust this)
              ;G91              ; relative positioning
              ;G1 Z0 F100       ; lift Z relative to current position
              ;G90              ; absolute positioning
              M122
              M122
              RepRapFirmware for Duet 2 WiFi/Ethernet version 3.3beta running on Duet Ethernet 1.02 or later + DueX5
              Board ID: 08DLM-996RU-N8PS0-7J9D8-3S86T-1B8VP
              Used output buffers: 6 of 24 (8 max)
              Static ram: 23436
              Dynamic ram: 70168 of which 24 recycled
              Never used RAM 18452, free system stack 206 words
              Tasks: NETWORK(ready,263) HEAT(blocked,315) DUEX(blocked,29) MAIN(running,450) IDLE(ready,19)
              Owned mutexes:
              Last reset 00:01:11 ago, cause: power up
              Last software reset at 2021-02-04 13:09, reason: User, GCodes spinning, available RAM 18452, slot 2
              Error status: 0x00
              Aux0 errors 0,0,0
              MCU temperature: min 23.6, current 25.7, max 26.1
              Supply voltage: min 25.0, current 25.0, max 25.1, under voltage events: 0, over voltage events: 0, power good: yes
              Driver 0: position 0, standstill, SG min/max not available
              Driver 1: position 0, standstill, SG min/max not available
              Driver 2: position 0, standstill, SG min/max not available
              Driver 3: position 0, standstill, SG min/max not available
              Driver 4: position 0, standstill, SG min/max not available
              Driver 5: position 0, standstill, SG min/max not available
              Driver 6: position 0, standstill, SG min/max not available
              Driver 7: position 0, standstill, SG min/max not available
              Driver 8: position 0, standstill, SG min/max not available
              Driver 9: position 0, standstill, SG min/max not available
              Driver 10: position 0
              Driver 11: position 0
              Date/time: 2021-02-04 13:12:44
              Cache data hit count 110185932
              Slowest loop: 6.92ms; fastest: 0.21ms
              === Storage ===
              Free file entries: 10
              SD card longest read time 3.8ms, write time 0.0ms, max retries 0
              === MainDDARing ===
              === AuxDDARing ===
              Bed heaters = 0 -1 -1 -1, chamberHeaters = 3 -1 -1 -1
              Heater 1 is on, I-accum = 0.0
              Segments left: 0
              Movement lock held by null
              HTTP is idle in state(s) 0
              Telnet is idle in state(s) 0
              File is idle in state(s) 0
              USB is idle in state(s) 0
              Aux is idle in state(s) 0
              Trigger is idle in state(s) 0
              Queue is idle in state(s) 0
              LCD is idle in state(s) 0
              Daemon is idle in state(s) 0
              Code queue is empty.
              === DueX ===
              Read count 45, 37.91 reads/min
              === Network ===
              Slowest loop: 11.52ms; fastest: 0.02ms
              HTTP sessions: 1 of 8
              Interface state active, link 100Mbps full duplex
              M119
              2/4/2021, 1:14:39 PM	M119
              Endstops - X: not stopped, Y: not stopped, **Z: no endstop**, Z probe: not stopped
              Problems Key
              Driver 10 external servo Motor with an encoder on 3.3FR Not moving
              Endstop Still Same issue string Can't take more than 50 Characters.
              Thank You
                moe.adams9093
                Sorry forgot to post M98
                M98P"config.g"
                HTTP is enabled on port 80
                FTP is disabled
                TELNET is disabled
                Error: Unknown pin name 'duex.e5sto'
                Error: bad grid definition: Too many grid points; suggest increase spacing to 21.0mm
                Warning: Macro file config-override.g not found
                • fcwiltundefined
                  fcwilt @moe.adams9093
                  @moe-adams9093 said in G32 ERROR:
                  It looks like that version of the firmware doesn't have the expanded command buffer - it's still dropping the last character.
                    moe.adams9093
                    I just found a solution to this problem. and it's a very simple fix. All I have to do is swap Driver 9 and Duex.e6stop to Z Drive and !Zstop that will put my string under 50 Char. But first I need to go back to 3.1.1 because 3.3 is acting a little weird.
                    • fcwiltundefined
                      Did you have a problem with the original driver assignments under 3.1.1?
                      I don't recall that you did.
                        moe.adams9093
                        Yes I did have a problem but I was using << !exp.e2stop to !exp.e6stop >> that was another issue. Anyway I haven't downgraded yet to 3.1 I will see if it works but I think it should
                          Maybe stick to 3.2 instead of 3.1.1
                          moe.adams9093undefined 1 Reply Last reply Reply Quote 0
                            moe.adams9093 @Phaedrux
                            @Phaedrux 3.2 for somereason my external driver Number 10 it won't work
                              moe.adams9093
                              So I downgraded to 3.1.1 and Main board is not working now YAT won't see it to enable ethernet via USB and can even erase firmware when i jump the reset pins deg light won't even turn red. Why did that happen
                                moe.adams9093
                                Never mind I figured it out
                                • fcwiltundefined
                                  Well don't leave us in suspense. What did you find?
                                    moe.adams9093
                                    One of my endstops connection was reversed accidentally and it caused a short so the board automatically shut down power to the CPU thats why it wasn't abel to communicate via USB. All up and running now endstops works fine as well. One single problem im having now is when the bed go back to the min side it won't stop by the IR sensor. Any idea on how I can fix this. Same homeall .g file I posted previously. Thanks again for keeping up.
                                    • fcwiltundefined
                                      Oops. I take if you are not using the mating connectors for the Duet which only go on one way?
                                      Glad to hear it.
                                      Questions:
                                      • So this file never works or only sometimes works?
                                      • Why so much movement in this command G1 H1 Z500 F6000?
                                      • Did you mean this to be a relative move G1 X235 Y235 F6000?
                                      ;  homeall.g
                                      G30			 ; probe Z
                                      G30			 ; probe z again
                                      Always willing to help when I can.
                                        moe.adams9093
                                        So when I press homeall
                                        These are the steps I wanted to do
                                        1. Bed travel to Zmax which is 500 ☑
                                        2. BED hit all four endStop at Zmax and stops axis individually ☑
                                        3. X&Y travel to the center (235,235) prob at center ❎
                                        So now X&Y are not traveling to (235,235) to perform probing sequence.
                                        • fcwiltundefined
                                          Questions:
                                          • Is there ANY movement at all on the X or Y axis in response to the G1 X235 Y235 F6000 command?
                                          • Is there ANY movement at all on the Z axis back towards the bed in response to the first G30 command?
                                          If I were trying to solve this I would first:
                                          • Comment out all of the commands starting with the G1 X235 Y235 F6000 command.
                                          • Perform a home all.
                                          • Verify that the X and Y axes homed and ended up at X=0 Y=0.
                                          So if you can provide those two answers and perhaps perform that test?
                                            I have increased the max length of the pin name string in the forthcoming 3.2.1 release.
