    Will not load mesh using G29 S1 command
    My Duet controlled machine
    1.2k
    • PaulHewundefined
      PaulHew
      For some reason, it will not load the height when requested from a gcode file.
      heightmap.csv is present, works if I manually command it either from the command line or the GUI.
      Even put it in twice, but still does not load.
      Regards
      Paul.
      ; generated by PrusaSlicer 2.3.0+linux-x64-GTK3 on 2021-02-06 at 12:40:56 UTC
      ; external perimeters extrusion width = 0.30mm
      ; perimeters extrusion width = 0.30mm
      ; infill extrusion width = 0.45mm
      ; solid infill extrusion width = 0.45mm
      ; top infill extrusion width = 0.22mm
      ; support material extrusion width = 0.40mm
      ; first layer extrusion width = 0.40mm
      M107
      ;TYPE:Custom
      ; Multi-temp start code - 5 September 2020
      ; Raise bed temp to profile requested bed temp
      M140 S105 ; Raise bed temp to profile requested bed temp
      M104 S150 T0 ; Raise hot-end temp to 150C for G32 auto-calibration
      M190 S105 ; Wait for bed temp to rise
      M109 S150 T0 ; Wait for hot-end temp to rise to 150C
      G29 S2
      G28 ; home all axes
      G28 Z
      ;G32 ; Autocalibrate bed
      G32 ; Autocalibrate bed a second time
      G28 Z ; Home Z after bed leveling
      G1 Z20 F600 ; Move bed down 20
      M104 S245 T0 ; Raise hot-end temp to profile requested hot-end layer 1 temp
      M109 S245 T0 ; Wait for hot-end temp to rise to profile requested hot-end layer 1 temp
      G1 X0.0 Y0.0 Z1.0 F2000.0 ; prepare to prime
      G92 E0 ; reset extrusion distance
      G1 Z0.2 F600
      G1 X60.0 E9.0  F1000.0 ; priming
      G1 X125.0 E12.5  F1000.0 ; priming
      G1 Z0.5 F600
      G29 S1
      G29 S1
      ; end of start code
      • fcwiltundefined
        fcwilt
        Was that code generated by the slicer?
        It's not very efficient.
        Still G29 S1 should load heightmap.csv if it is the system directory.
        Please post your homeALL.g and homeZ.g files using the </> tag
        • Vetiundefined
          Veti
          G28 ; home all axes
          G28 Z
          G28 should home z as well.
          what firmware version are you running?
          how did you check that the heightmap was not loaded?
            @PaulHew, which Duet are you using, with which firmware revision, and in standalone or SBC mode?
            • PaulHewundefined
              PaulHew
              It is not loading the mesh compensation. using the G29 S1 command.
              Yes the code is generated by the slicer, top line of the GCode I posted states PrusaSlicer
              I checked using the GUI, 'Compensation in use: none.
              I noticed also that my leadscrews were not moving.
              Duet2 with Duex5 in standalone mode. (not enough info for me to do the DIY conversion)
              RepRapFirmware for Duet 2 WiFi/Ethernet version 3.2 running on Duet Ethernet 1.02 or later + DueX5
              Board ID: 08DGM-917DA-G4MS8-6JKDL-3SN6N-TVVB9
              Regards,
              Paul
                Thanks. Have you checked the GCode file to make sure that your start GCode is present in it, and that the slicer hasn't inserted a G28 or other relevant command in the GCode file after the start code?
                • PaulHewundefined
                  PaulHew
                  In the first post it has my start gcode from the actual file I am printing.
                  G29 S1 is the last line of my start gcode.
                  These are the subsequent lines.
                  End of the gcode - It has already printed the prime line  by this point.
                  G29 S1
                  G29 S1
                  ; end of start code
                  G21 ; set units to millimeters
                  G90 ; use absolute coordinates
                  M83 ; use relative distances for extrusion
                  ;Filament gcode
                  ;G29 S1 P"100.csv"
                  ;LAYER_CHANGE
                  ;Z:0.24
                  ;HEIGHT:0.24
                  ;BEFORE_LAYER_CHANGE
                  ;0.24
                  G1 Z0.240 F18000.000
                  ;AFTER_LAYER_CHANGE
                  ;0.24
                  G1 E-0.80000 F2700.000
                  G1 X28.309 Y27.729 F18000.000
                  G1 E0.80000 F2400.000
                  M204 S2000
                  ;TYPE:Skirt
                  ;WIDTH:0.4
                  G1 F1500.000
                  G1 X29.242 Y27.142 E0.03719
                  G1 X30.320 Y26.890 E0.03734
                  So, no other commands to negate the G29, as far as I know.
                  Also had no errors that it could not load the file.
                  Going to try G28 S1 P"heightmap.csv"
                  Regards,
                  Paul.
                  • PaulHewundefined
                    PaulHew
                    No, G29 S1 P"heightmap.csv" did not work either.
                    had to manually load it.
                    • fcwiltundefined
                      fcwilt
                      We really need to see your homing files
                      • homeX.g
                      • homeY.g
                      • homeZ.g
                      • homeALL.g
                        This is strange. I just added G28 followed by G29 S1 to the start of one of my GCode files that didn't have any start GCode, and ran it. It worked as expected, M122 went from reporting "bed compensation in use: none" to "bed compensation in use: mesh". This is on a delta with a Duet WiFi running firmware 3.2.1.
                        • PaulHewundefined
                          PaulHew
                          @dc42 said in Will not load mesh using G29 S1 command:
                          G28
                          The last G28 I have is in bed.g, these tramming functions are before running G29 S1.
                          rename to a .zip
                          Homing Files.txt
                          ABS Shape-Box-2.04683g-17m.gcode
                          I have included the gcode file, You can clearly see there are no G28s after the G29
                          Just reloaded 3.2, full power reboot, just incase
                            Can you check if it's enabled in M122 in case it's a display issue in DWC?
                              Why has this thread been marked as solved?
                              • Arakahnundefined Arakahn referenced this topic
