    Short-to-ground reported by driver(s) 0 1 2 3 4
    1.0k
    • Luk14undefined
      Luk14
      today I successfully setup the WIFI connection on my new DuetWifi and connected it to my 5V power supply. This worked very well, but after I connected my 24V power supply the web interface showed me the following error:
      Error: short-to-ground reported by driver(s) 0 1 2 3 4
      Error: over temperature shutdown reported by driver(s) 0 1 2 3 4
      I did not connect any motor.
      Is this normal or do I have a broken board?
      [spoiler]
      M122
      RepRapFirmware for Duet 2 WiFi/Ethernet version 3.2 running on Duet WiFi 1.02 or later
      Board ID: 08DLM-996RU-N85S4-7JKDG-3SD6P-KVARN
      Used output buffers: 3 of 24 (23 max)
      Static ram: 23460
      Dynamic ram: 73212 of which 40 recycled
      Never used RAM 15368, free system stack 189 words
      Tasks: NETWORK(ready,176) HEAT(blocked,323) MAIN(running,470) IDLE(ready,19)
      Owned mutexes: WiFi(NETWORK)
      Last reset 00:08:03 ago, cause: power up
      Last software reset at 2007-04-09 15:53, reason: HardFault, Platform spinning, available RAM 106588, slot 1
      Software reset code 0x4060 HFSR 0x40000000 CFSR 0x00080000 ICSR 0x00000803 BFAR 0xe000ed38 SP 0x2001ff90 Task none Freestk 228 bad marker
      Stack: 00000001 00000000 00000002 10807bf7 00000000 00456309 004483bc 41000000 dfeb33a4 159310b9 c9913a17 37fdbf95 00476ff0 00457b71 00000004 00474c1a 00474c26 00474c4e 00000000 00449361 200000a8 00000000 00000000 00000000 00000000 00456309 00000000
      Error status: 0x00
      Aux0 errors 0,0,0
      MCU temperature: min 29.1, current 29.5, max 29.9
      Supply voltage: min 24.0, current 24.1, max 24.3, under voltage events: 0, over voltage events: 0, power good: yes
      Driver 0: position 0, temperature-shutdown! short-to-ground, standstill, SG min/max not available
      Driver 1: position 0, temperature-shutdown! short-to-ground, standstill, SG min/max not available
      Driver 2: position 0, temperature-shutdown! short-to-ground, standstill, SG min/max not available
      Driver 3: position 0, temperature-shutdown! short-to-ground, standstill, SG min/max not available
      Driver 4: position 0, temperature-shutdown! short-to-ground, standstill, SG min/max not available
      Driver 5: position 0
      Driver 6: position 0
      Driver 7: position 0
      Driver 8: position 0
      Driver 9: position 0
      Driver 10: position 0
      Driver 11: position 0
      Date/time: 2021-02-08 17:14:31
      Cache data hit count 655813056
      Slowest loop: 6.25ms; fastest: 0.23ms
      === Storage ===
      Free file entries: 10
      SD card longest read time 3.8ms, write time 0.0ms, max retries 0
      === MainDDARing ===
      === AuxDDARing ===
      Segments left: 0
      Movement lock held by null
      HTTP is idle in state(s) 0
      Telnet is idle in state(s) 0
      File is idle in state(s) 0
      USB is idle in state(s) 0
      Aux is idle in state(s) 0
      Trigger is idle in state(s) 0
      Queue is idle in state(s) 0
      LCD is idle in state(s) 0
      Daemon is idle in state(s) 0
      Code queue is empty.
      === Network ===
      Slowest loop: 202.09ms; fastest: 0.10ms
      HTTP sessions: 1 of 8
      -WiFi -
      Network state is active
      Failed messages: pending 0, notready 0, noresp 1
      WiFi firmware version 1.25
      WiFi MAC address 50:02:91:e5:3f:91
      WiFi Vcc 3.39, reset reason Turned on by main processor
      WiFi flash size 4194304, free heap 27064
      WiFi IP address 19.3.95.62
      WiFi signal strength -61dBm, mode 802.11n, reconnections 0, sleep mode modem
      Clock register 00002002
      [/spoiler]
      • Vetiundefined
        Veti
        post a high resolution picture of your board
          dc42 administrators @Luk14
          @Luk14, it sounds as though the SPI communication between the MCU and the drivers has broken down. However, it's possible to get that error if the 24V PSU is overloaded, so that 24V power is applied briefly but disappears again when the MCU starts communicating with the drivers. Is the blue LED that indicates VIN power lit continuously?
          • Luk14undefined
            Luk14
            @dc42 said in Short-to-ground reported by driver(s) 0 1 2 3 4:
            Yes the LED lit continuously. The 24V PSU is a MeanWell RSP-500-24. The 5V on is a MeanWell RS-15-5. When I use the internal switching regulator the error message disappears. Is the 15W PSU too weak to power the board?
            • Luk14undefined
              Luk14
              *** push ***
                15W (3A @ 5V) is more than enough to power the Duet. However, the fact that it works OK when you use the internal 5V regulator suggests that there is a power issue with the 5V supply. How have you connected that 5V PSU to the Duet?
                • Luk14undefined
                  Luk14
                  I connect the 5V PSU directly to the board. I checked the wiring twice. I also tried to use a USB PSU. Same result...
                  I used this guide:
                  https://duet3d.dozuki.com/Wiki/Power_Wiring#:~:text=The Duet operates on two power circuits: a,or not an external power supply is attached).
                  engikeneerundefined dc42undefined 2 Replies Last reply Reply Quote 0
                  • engikeneerundefined
                    engikeneer @Luk14
                    @Luk14 do you have anything else on the 5v supply? LEDs etc. Also, are you using the 5v supply for anything else on the board (e.g. 5v fans)? Just wondering if any of them could be causing issues for the power supply?
                    i3 clone with a bunch of mods
                    • Luk14undefined
                      Luk14
                      I have just connected the board, no fans, motors, sensors etc.
                        @Veti said in Short-to-ground reported by driver(s) 0 1 2 3 4:
                        Post some photos we may be able to see a failed component.
                        • Luk14undefined
                          Luk14
                          IMG_20210213_111813.jpg IMG_20210213_111742.jpg IMG_20210213_111709 (2).jpg IMG_20210213_111813.jpg IMG_20210213_111723~2.jpg
                            @Luk14 said in Short-to-ground reported by driver(s) 0 1 2 3 4:
                            I used this guide:
                            Did you connect the PS_ON pin of the Duet to anything, or leave it not connected?
                            • Luk14undefined
                              Luk14
                              I leave it unconnected.
                                T3P3Tony administrators
                                can you confirm the board works as expected when using the internal regulator like you reported above? Please try with your 5V supply disconnected, the 24V supply connected and send M122
                                Thanks
                                Luk14undefined 1 Reply Last reply Reply Quote 0
                                • Vetiundefined
                                  Veti
                                  just to make sure. when put the jumper on the external 5v supply pins, you removed the jumper from the internal 5v supply pins?
                                  • Luk14undefined
                                    Luk14 @T3P3Tony
                                    @T3P3Tony
                                    Yes, without the 5V PSU the board works just fine and I am sure that i use the right jumper configuration(s).
                                    M122
                                    Used output buffers: 3 of 24 (11 max)
                                    Static ram: 23460
                                    Never used RAM 15368, free system stack 191 words
                                    Tasks: NETWORK(ready,160) HEAT(blocked,323) MAIN(running,452) IDLE(ready,19)
                                    Last reset 00:01:11 ago, cause: power up
                                    Last software reset at 2021-02-08 20:59, reason: User, GCodes spinning, available RAM 15368, slot 1
                                    Error status: 0x00
                                    Aux0 errors 0,0,0
                                    MCU temperature: min 25.5, current 30.0, max 30.2
                                    Supply voltage: min 23.9, current 24.1, max 24.4, under voltage events: 0, over voltage events: 0, power good: yes
                                    Driver 0: position 0, ok, SG min/max not available
                                    Driver 1: position 0, ok, SG min/max not available
                                    Driver 2: position 0, ok, SG min/max not available
                                    Driver 3: position 0, ok, SG min/max not available
                                    Driver 4: position 0, ok, SG min/max not available
                                    Date/time: 2021-02-20 19:12:18
                                    Cache data hit count 85795599
                                    Slowest loop: 4.85ms; fastest: 0.20ms
                                    === Storage ===
                                    SD card longest read time 4.0ms, write time 0.0ms, max retries 0
                                    === MainDDARing ===
                                    === AuxDDARing ===
                                    Segments left: 0
                                    === Network ===
                                    Slowest loop: 15.55ms; fastest: 0.00ms
                                    • WiFi -
                                      WiFi flash size 4194304, free heap 23832
                                      WiFi signal strength -66dBm, mode 802.11n, reconnections 0, sleep mode modem
                                    • Luk14undefined
                                      Luk14
                                      When i switch from the 24V to the 5V supply quickly (just change the jumper position while it is running) i don t get any error message.
                                      Edit:
                                      If i turn on the 24V PSU first and after some seconds the 5V PSU everything will work fine.
                                      • Luk14undefined
                                        Luk14
                                        * push *
                                          @Luk14 If its working fine using the internal 5V regulator then we need to work out why the external 5V supply is causing the issue. Please can you measure the voltage level between 5V and Ground on (e.g.) the PanelDue header using a multimeter to confirm that when the external 5V PSU is attached the Duet has 5V on its 5V rail (not just on the power supply input).
                                          • Luk14undefined
                                            Luk14
                                            @T3P3Tony said in Short-to-ground reported by driver(s) 0 1 2 3 4:
                                            PSU: 5,00V
                                            pin1/2: 4,65V
                                            I increased the voltage to (5,44V/5,05V) but the error message still occours.
