Short-to-ground reported by driver(s) 0 1 2 3 4
15W (3A @ 5V) is more than enough to power the Duet. However, the fact that it works OK when you use the internal 5V regulator suggests that there is a power issue with the 5V supply. How have you connected that 5V PSU to the Duet?
I connect the 5V PSU directly to the board. I checked the wiring twice. I also tried to use a USB PSU. Same result...
I used this guide:
https://duet3d.dozuki.com/Wiki/Power_Wiring#:~:text=The Duet operates on two power circuits: a,or not an external power supply is attached). -
@Luk14 do you have anything else on the 5v supply? LEDs etc. Also, are you using the 5v supply for anything else on the board (e.g. 5v fans)? Just wondering if any of them could be causing issues for the power supply?
I have just connected the board, no fans, motors, sensors etc.
@Veti said in Short-to-ground reported by driver(s) 0 1 2 3 4:
post a high resolution picture of your board
Post some photos we may be able to see a failed component.
@Luk14 said in Short-to-ground reported by driver(s) 0 1 2 3 4:
I used this guide:
https://duet3d.dozuki.com/Wiki/Power_Wiring#:~:text=The Duet operates on two power circuits: a,or not an external power supply is attached).Did you connect the PS_ON pin of the Duet to anything, or leave it not connected?
I leave it unconnected. -
Yes the LED lit continuously. The 24V PSU is a MeanWell RSP-500-24. The 5V on is a MeanWell RS-15-5. When I use the internal switching regulator the error message disappears. Is the 15W PSU too weak to power the board?
can you confirm the board works as expected when using the internal regulator like you reported above? Please try with your 5V supply disconnected, the 24V supply connected and send M122
Thanks
just to make sure. when put the jumper on the external 5v supply pins, you removed the jumper from the internal 5v supply pins?
Yes, without the 5V PSU the board works just fine and I am sure that i use the right jumper configuration(s).
M122
RepRapFirmware for Duet 2 WiFi/Ethernet version 3.2 running on Duet WiFi 1.02 or later
Board ID: 08DLM-996RU-N85S4-7JKDG-3SD6P-KVARN
Used output buffers: 3 of 24 (11 max)
Static ram: 23460
Dynamic ram: 73212 of which 40 recycled
Never used RAM 15368, free system stack 191 words
Tasks: NETWORK(ready,160) HEAT(blocked,323) MAIN(running,452) IDLE(ready,19)
Owned mutexes: WiFi(NETWORK)
Last reset 00:01:11 ago, cause: power up
Last software reset at 2021-02-08 20:59, reason: User, GCodes spinning, available RAM 15368, slot 1
Error status: 0x00
Aux0 errors 0,0,0
MCU temperature: min 25.5, current 30.0, max 30.2
Supply voltage: min 23.9, current 24.1, max 24.4, under voltage events: 0, over voltage events: 0, power good: yes
Driver 0: position 0, ok, SG min/max not available
Driver 1: position 0, ok, SG min/max not available
Driver 2: position 0, ok, SG min/max not available
Driver 3: position 0, ok, SG min/max not available
Driver 4: position 0, ok, SG min/max not available
Driver 5: position 0
Driver 6: position 0
Driver 7: position 0
Driver 8: position 0
Driver 9: position 0
Driver 10: position 0
Driver 11: position 0
Date/time: 2021-02-20 19:12:18
Cache data hit count 85795599
Slowest loop: 4.85ms; fastest: 0.20ms
=== Storage ===
Free file entries: 10
SD card longest read time 4.0ms, write time 0.0ms, max retries 0
=== MainDDARing ===
=== AuxDDARing ===
Segments left: 0
Movement lock held by null
HTTP is idle in state(s) 0
Telnet is idle in state(s) 0
File is idle in state(s) 0
USB is idle in state(s) 0
Aux is idle in state(s) 0
Trigger is idle in state(s) 0
Queue is idle in state(s) 0
LCD is idle in state(s) 0
Daemon is idle in state(s) 0
Code queue is empty.
=== Network ===
Slowest loop: 15.55ms; fastest: 0.00ms
HTTP sessions: 1 of 8- WiFi -
Network state is active
WiFi firmware version 1.25
WiFi MAC address 50:02:91:e5:3f:91
WiFi Vcc 3.39, reset reason Turned on by main processor
WiFi flash size 4194304, free heap 23832
WiFi IP address 19.3.95.62
WiFi signal strength -66dBm, mode 802.11n, reconnections 0, sleep mode modem
Clock register 00002002
- WiFi -
When i switch from the 24V to the 5V supply quickly (just change the jumper position while it is running) i don t get any error message.
Edit:
If i turn on the 24V PSU first and after some seconds the 5V PSU everything will work fine.
* push *
@Luk14 If its working fine using the internal 5V regulator then we need to work out why the external 5V supply is causing the issue. Please can you measure the voltage level between 5V and Ground on (e.g.) the PanelDue header using a multimeter to confirm that when the external 5V PSU is attached the Duet has 5V on its 5V rail (not just on the power supply input).
@T3P3Tony said in Short-to-ground reported by driver(s) 0 1 2 3 4:
PSU: 5,00V
pin1/2: 4,65VI increased the voltage to (5,44V/5,05V) but the error message still occours.
@luk14, just to be clear: when do you see this error message? Is it:
- Just once when you apply external 5V power, when VIN power is not already applied;
- Just once when you apply external 5V power, when VIN power is already applied;
- More than once; and if so, when?
Nr.1 and when i apply 5V and VIN simultaneously.
Any further ideas?
We're not sure what is going on. I've tried to replicate the issue by applying USB power, connecting with DWC, and then applying 24V power, but this didn't cause the fault. I had the internal regulator still enabled, but this shouldn't make any difference given that 5V power was already provided via USB.
So I suggest we try replacing your Duet. Please contact your supplier to request a replacement under warranty, referring them to this post as authorisation.
I'm sorry it has taken so long to reach a decision about this.
I got a replacement two days ago. With the new board everything works like i expected.
One more question. My 24V PSU can be turned on and off by a external signal. I wired it up and it works, but unfortunately the PSU is not a ATX one and turns off if it gets the 5V signal from the Duet. Is there a setting in the firmware where i can invert the ATX_ON pin?
